View Full Version : DBW throttle quits after flooring it
69cutlassrkt
05-29-2010, 05:24 PM
After I floor the gas pedal the throttle quits working. If I turn it off then start it back up it works again.
Anyone know what might be causing this?
neki67
05-30-2010, 03:30 AM
I have the GMPP E67 controller and had the same problem. I changed the tune to a newer version and the problem disappeared.
Hope that helps.
69cutlassrkt
05-30-2010, 08:24 AM
Hope that helps.
How do you change it to a newer version?
I have a diablosport programmer.
69cutlassrkt
05-30-2010, 10:17 AM
Also if i rev it in park it doesn't mess up, only when I floor it in gear. And my diablo sport says unsupported vehicle when I try to tune it, so maybe my computer isn't the one that came with the engine. My PCM was tuned before I bought it. IT has emissions and TM deleted off of it.
neki67
05-30-2010, 11:16 AM
Don't know 'bout the Diablo. I'm using EfiLive. Got the tune-file from a friend (prob. also to be found on the net) and just reflashed PCM with it. Used a 'tuned' CTS-V file prior to that. My friend suggested it might be corrupted by the tuning. In my case the problem was constant and not intermittent and/or under certain conditions.
Bow Tie 67
05-30-2010, 01:50 PM
Diablo wont work with the GMPP computer, it does not have a norm vin#.
The code it is throwing is most likely a P2101. I have been fighting this and still dont know if its cured.
69cutlassrkt
05-30-2010, 07:32 PM
I get a CKP sensor code and a P0654 and the throttle module to PCM P1518
69cutlassrkt
06-09-2010, 12:52 PM
Replaced my TAC module with this one -12588923. Now it works right.
