View Full Version : Different size wheels in front vs rear i.e. 16F / 17R
68 SuperRam
08-27-2004, 09:36 AM
Was curious to know if anyone uses different size wheels in the front vs the rear - I am currently using 16x8 all around - but I am considering using 17x7 in the rear, and keeping the 16X8 in the front.
Gonzostyle
08-27-2004, 09:59 AM
On my 62 Nova I am running 15X7 on the front and 16X8 in the rear. I went this way because of the difference in the fender opening front to rear (Well that and I was on a tight schedule/budget). I think when I pull the car apart again, I will do 17s and maybe 18s.
-Jeremie
(I LOVE this new board, uploading pics is easy!!)
dennis68
08-27-2004, 10:57 AM
Running 16X8 in the front and 17X7 in the rear would make for a very strange handling beast. Why in the world would you want to run a narrower rim in the back?
Drewhelm
08-30-2004, 08:58 AM
I'm currently running a 16x8 front and 17x8 rear.
Woudl like to switch to a 17 18 combo at some point.
68 SuperRam
08-30-2004, 09:06 AM
The reason why I am asking - is because - I can get a good deal on 17x7 wheels and rubber for the rear - as my current rear which is 16x8 with a 4 in backspacing - disc brakes - stock 12 bolt leaf rear - NON rolled quarter lip - as such - on occassion the rear tires rub against the bottom of the quarter panel - the price it would cost me to buy two new 16X8 with a larger backspacing would be about the same as purchasing the two 17X7 with a 5 in BS. I was wondering from an appearance standpoint - if anyone else was running larger wheel sizes in the rear and smaller in the front - almost like a "hot rod" style.
Robert E. Stauffer Jr.
08-30-2004, 03:32 PM
It can work...I would only do it if the rear was going to be wider....say 17x9.5. If I had the 17x7 choice I would stick with the 16x8 and massage the inner fender. :)
bob
