View Full Version : Master cylider question
SHOUGHTON
05-29-2010, 11:41 AM
I recently purchased a C5 front disc upgrade for my 67 Camaro and I had to change my old drum/drum master cylinder to a new style disc/disc adding a RPV to the rear brake feed because I'm still running rear drums. My question is: Does it matter which port feeds the front brakes? I've always assumed the the outer most port feeds the front and the port closest to the firewall feeds the back. The fitting sizes on my new master cylinder are the opposite of my old setup. Do I replace the fittings to match the new master cylinder or can I just switch to the opposite ports?
SHOUGHTON
05-30-2010, 12:59 AM
Disreguard my post. Tobin from Kore 3 set me straight. Larger fitting supplies the rear. I know it has been said here many times before but Tobin at Kore 3 if awesome to deal with.
:1st:
