View Full Version : Suggestion on -8 line over axle
Mr Nick
05-28-2010, 01:50 PM
I'm looking for suggestions (pictures too) of how you ran fuel lines from the tank over the axle to frame rail.
I'm running q.2 -8 AN lines, no way they will both fit in stock locations.
Car is a 69 Cutlass, I'd imagine any 64+ GM would be similar.
Nick
wmhjr
05-28-2010, 02:06 PM
I ran one -8 and one -4 in stock location in my '66 GTO. I did it with the body off though, which may make it a bit easier. I think it might be pretty tough to get 2 -8s there otherwise, though I have a boxed frame which is even more difficult. If your frame is not boxed I would think it's not a big deal.
Take a look at http://www.photobucket.com/1966pontiac and look at the categories on the left. I think there were some pics in there, but here's one:
https://static1.pt-content.com/images/pt/2009/04/4April2009GTO010-1.jpg
Mr Nick
05-31-2010, 09:33 AM
Thanks for the suggestion, but I'm running Aeroquip rubber lines with outer shield, pretty big O.D. on this stuff. And... I'm not taking the body off for this project!
Nice ride by the way!
Mr Nick
05-31-2010, 03:30 PM
Here are some better pictures:
Stock tank with RobbMc Pick Up, here you can see the feed outlet on the pick up looping over the the filter/inlet side of the pump.
I have a 45* outlet here, but can be changed if needed. I need to get the outlet ran from here, over the axle, the passenger frame rail.
wmhjr
06-01-2010, 07:58 AM
Did you box your frame? If the frame isn't boxed, I would think you have plenty of room. There should be plenty of room directly above the rear axle for you to come out of the RobbMC sender (same thing I'm using, BTW) to the reg. I mounted my prefilter offset but above the rear end and it's all -8AN Braided, which I would guess is close to the same OD as what you're using. I just happen to connect to hard lines above there as well. Where is your clearance problem? I'm sorry - I just realized I had not taken pics of that assembly.
