View Full Version : C5/C6 caliper to guide pin bolt
bochnak
05-28-2010, 04:19 AM
What size/type is the caliper to guide pin bolt?
I believe the GM p/n is 14067559, and are $3.57 ea. I will need 8 if they same F/R.
If it is a standard fastener, I’d rather source from Fastenal.
JEFFTATE
05-28-2010, 05:59 AM
PN-14067559 is the caliper guide pin bolt..
bochnak
05-28-2010, 06:03 AM
Thanks. Does the bolt have a flange head or std hex head?
regal454
05-28-2010, 07:42 AM
Std. hex head
bochnak
05-28-2010, 08:02 AM
Std. hex head
Thanks!
gort69
05-28-2010, 10:06 AM
I replaced mine with grade 8 (probably overkill) flange head bolts from the hardware store. I think the total for all 8 was less than $3.57. I used blue loctite.
bochnak
05-28-2010, 10:21 AM
I'm thinking a 35mm L and a flat washer or a 30mm no washer:
http://www.fastenal.com/web/products/detail.ex?sku=11103697&ucst=t
http://www.fastenal.com/web/products/detail.ex?sku=0154002&ucst=t
http://www.fastenal.com/web/products/detail.ex?sku=0154001&ucst=t
Apogee
05-28-2010, 12:03 PM
If you're talking about the fasteners that attach the C5/C6 calipers to the guide pins, those are Class 10.9 M8x1.25 x 20mm hex head cap screws (HHCS) with pre-applied threadlocker. The only reason that I can see why GM recommends replacing those fasteners (and supplies them with new calipers) is due to the threadlocker. The front and rear C5/C6 calipers use the same fasteners.
Tobin
KORE3
bochnak
05-29-2010, 03:33 AM
Tobin
KORE3
What type of threadlocker?
GenPac
06-01-2010, 09:09 AM
Loctite blue, medium strength.
bochnak
06-01-2010, 09:21 AM
Thanks. I have some 242 laying around.
JEFFTATE
06-01-2010, 11:01 AM
Tobin
KORE3
Oh crap !!!
I gave the wrong information !!!
What was I thinking. ???
I made a mistake , and looked at the wrong line..when I was readind the specs for that bolt ...
Sorry
Thanks Tobin !
JEFFTATE
06-01-2010, 11:02 AM
It's specs are M12-1.75 x 33.1
This is the wrong info .. sorry ..
I need to get more sleep ...
I don't know how I messed this up .
Hope it didn't send you down the wrong path ...
bochnak
06-01-2010, 11:19 AM
No worries Jeff.
Apogee
06-02-2010, 12:00 PM
De nada...I got your back Jeff. Matt, thanks for the email and let me know if you want to take some of those bolts off my hands.
Tobin
KORE3
bochnak
06-02-2010, 12:04 PM
Tobin
KORE3
Tobin,
I'll take 8 when I place my order for brackets. Thanks!
