View Full Version : Solving Pad Knockback
silver69camaro
05-27-2010, 08:30 AM
As our R&D Camaro has progressed, we've been increasing front and rear grip by a fair amount. Late last year, I've been battling some pad knock-back that's been driving me nuts. This car uses modified C6 front suspension with a 9" axle and tapered bearings. Knock-back is more noticeable if you have manual brakes, because there is more pedal travel needed to overcome the pad-to-rotor gap. If you are experiencing a soft brake pedal after a hard corner, follow this to hopefully solve your problem.
First, find out which side is having the problem. Does the brake go to the floor immediately after a hard left turn, or right?
Second, find out if it's the front or rear. I do this by turning hard, then shutting the engine off while in gear, coasting to a stop. Jack the car up, remove the wheels, and you should see daylight between the pads on the offending corner. Typically you'll see .010" gap or so - it doesn't take much. Obviously this requires an area you can safely do this in. A guy could find a parking lot at night and run a tight circle to accomplish the same thing.
Now that you know if it's front or rear, you can start to diagnose the problem. If it's a front wheel, replace the hub assembly if you have C6 hubs. If you have a spindle pin & bearing, the bearings and races probably need to be replaced.
The rear is a bit more difficult. Possible causes are:
1. Axle flex: Happens typically if R-compound tires are used on stock axles with heavy cars. Aftermarket axles tend to have more material that negate this problem.
2. Improper bearing preload: If the bearing isn't held tight enough in the housing end (press-on bearings only), it can move around causing the rotor to kick the pads into the calipers. Try adding some 12-bolt carrier shims between the bearing and housing end.
3. Excessive c-clip clearance: For guys that run c-clips, you may need to run thicker clips to keep the axles walking laterally. I've heard of people making a thick clip, then shaving it down a couple thou at a time until it fits snug.
4. Axle retainer flex: For axles with press-on bearings, check the axle retainer plate. This was the problem I was having, which the retainer would flex enough to allow the axle to move. The Wilwood retainers are pretty thin and are prone to flexing. Mine was pretty bad, and replaced it with a 1/4" retainer plate. Problem solved! Currie makes a nice thick retainer for about $16, but is a full-circle type retainer so you have to put it on before the bearings are installed.
Here's the set that I made. It ended up working very well and I didn't have to remove my bearings.
Brakes in question
Old, Bent Retainer Plate
New Retainer
Hopefully this helps. It's nice to fix this problem without resorting to piston springs or residual valves.
Bow Tie 67
05-27-2010, 10:02 AM
Nice work Matt.
Quick question: What is your axle axial play before and after the fix?
silver69camaro
05-27-2010, 10:07 AM
Tough to say. After a hard corner, the pads would be moved back about .015", but I couldn't move the axle by hand at all...it felt pretty solid.
The new retainer eliminated the knockback entirely.
silver69camaro
05-27-2010, 10:40 AM
Update: Talked to the folks at Wilwood and turns out they've been aware of the issue. As of about 10 months ago, all brake kits have an updated retainer that should take care of the problem in most cases. It increases the preload for better retention. If you have an older kit (like I did), just order one up.
Something else we talked about that I didn't mention on this post. If you have a heavy car with 335's with minimal backspace, it's possible that you're overloading the axle and bearing which could cause flex.
Vegas69
05-27-2010, 10:41 AM
Nice Matt, but I caused Wilwood to re design that bracket. It's nearly as thick as the Currie now. I also tweaked mine a little. I had Currie plates on my old roller bearing axles but decided to use the updated thicker Wilwood retainer when I changed to the tapered bearing setup. I also can't feel any end play in either axle. I do have the shims needed to put behind the bearing race, it just feels tight now. I'll post back on the 1" bore master.
Vegas69
05-27-2010, 10:58 AM
Here are two videos I did over a year ago. This was with the thin retainers that came with the kit and roller bearings. The problem was the retainers had no preload on the axle bearing. In fact there was a small gap between teh bearing race and retaining clip. That's when I contacted Wilwood and they started working on a fix. Unfortunately that meant I had to purchase Currie plates and pay to have my bearing pressed off and on.In fact I paid for new bearings as well. That change did cure the no pre load issue and retainer flex, but it didn't totally solve the problem. I'd say cut it in half.
Next I switched to tapered bearing axles from moser. At that time Wilwood had came out with the updated retainer so I used it and found that the pre load machined into the surface was identical to the Currie plates. So I used the wilwood plate to keep from needing to press bearings off and on. This didn't totally cure it either. It did cut it in half again.
I just switched to a 1" bore master to attemp to make up for some of the rest by providing more volume. I haven't driven the car but will this weekend. At this point I feel it's a combination of axle flange and bearing flex. I have 33 spline axles. Part of me wonders if the deep dish wheel and parking brake rotor offset effects it as well. Bottom line is I hope the 1" bore makes it decent until Wilwood comes out with a floating caliper or rotor. That's the real fix in my opinion.
http://www.youtube.com/watch?v=Ff0fkCmHNWk
http://www.youtube.com/watch?v=4d98pjx6sz8&NR=1
silver69camaro
05-27-2010, 11:04 AM
Todd, what is your wheel size and backspace? I'm wondering if you're overloading the bearing...
Also, you probably don't want to hear this, but some people have had to actually mix and match bearings and races...meaning, you may have to have a handful of races and find out which one allows the tightest fit. It's hard to imagine, but it's true.
Vegas69
05-27-2010, 11:11 AM
It's an 18x12 with a 5.25 BS. Mine will do it on the street in what I wouldn't consider close to race loads. With the offset of the wheel putting more stress on the bearing and the rotor being recessed more due to the parking brake, I think we may be onto something. I was sitting in the garage a few weeks ago just looking at the setup and it got my wheels spinning. Any axle flange deflection would be amplified the farther the rotor is from the axle flange. I'm interested to hear what you have to say on the bearing load.
silver69camaro
05-27-2010, 11:38 AM
This drawing shows your 18x12 with a 5.25" B.S. using the Wilwood 13" Pro Street brake. You have a 4.088" lever-arm between wheel C/L and bearing C/L, which I know doesn't sound like much but it's about 2.25 times more than what it should be. I think you're in full-floater territory there...
As you know, the bigger the rotor, the bigger the knockback...
Vegas69
05-27-2010, 03:55 PM
Good stuff Matt! I appreciate you taking the time. I'm going to limp through with my 1" master until they come out with a floating caliper or rotor.(Supposed to be in the works) The problem with a floater rear end is my 4 link mounting points are to close to the axle flange. I'm glad my hunch was correct.
parsonsj
05-27-2010, 04:10 PM
Hey Matt,
Did our phone conversation a couple of months ago lead you down this path? I want credit, dammit!!! :)
Seriously, glad you found the problem. When I replaced my front wheel bearing and fixed the knockback on II Much it was such a great improvement.
jp
parsonsj
05-27-2010, 05:02 PM
Lever arm, eh? My 7 3/8 BS (11") wheel would have approximately half that, I think. That's gotta be why the original Wilwood bearing retainers didn't cause me any problems.
Very nice analysis.
jp
Ron.in.SoCal
05-27-2010, 05:31 PM
Nice job you guys. I read about Todd's issues/videos/resolutions over on Lat-G and it got me thinking about how to avoid it. This just adds to the body of knowledge.
Matt - nice diagram, as usual. Now i have two from you...:idea:
Todd- give me your take on the 1" master when you get a chance?
Vegas69
05-27-2010, 09:54 PM
The 1" master totally transformed my car. I beat it as hard as I could on the street with not a hint of knockback. I can't believe the difference. I like the feel better as well. It firmer but with a much higher pedal and it gives me way more confidence. I don't know if the 7/8 was never right or this one made that much difference. There was no fluid behind the bore and the seals looked fine. The bore was scored and the front fluid was nasty with some fine particles. I think it was from the excessive pumping I did in my 8-10 races and street driving. Bottom line is, I'm happy !!!
Payton King
05-28-2010, 06:39 AM
for the above write up. That will help a lot of people. I had sized my masters down too small trying to get the car to stop. Changed brands of pads and went to a .70 for the front and .75 on the rear per Tobin's recs and my car has never stopped better. Not getting the knock back I was...I changed my Wilwoods to the Currie retainer last year. Before I changed the retainer I would knock the pads back pulling out of the driveway.
Todd, glad your problem is fixed. If you are going on that long trip and will just be autocrossing, switch the AX6's into the front. It will stop way better than the XP10's on the street and autocross.
Vegas69
05-28-2010, 06:42 AM
I still haven't put them out back. LOL Been busy.
Skip Fix
05-28-2010, 08:33 AM
My TA when new had so much free play the drum would wear on the backing plate! The dealer never figured it out under warranty where the rubbing sound came from , rebuilt the posi, put new sway bar bushings etc. Found it when I added semi metallic shoes a few years later.
Payton King
05-28-2010, 08:35 AM
about you pulling the 10's out of the front and putting the AX6's in there for the weekend. Leave whatever you are running in the rear. Easy swap.
I am interesting in knowing which pads you used for the .7 and .75 Mu. From my searches Wilwood has decent graphs of pad performance vs temperature. And EBC has performance graphs for their Bluestuff pads.
But for others such as Hawk's, CarboTech, Porterfield, and others, there isn't any real information on the friction levels.
Bob.
Vegas69
05-28-2010, 11:16 AM
Ya, I already have the wheels back on. haha
Payton King
05-28-2010, 11:31 AM
re-read my post and it was not clear. The .70 and .75 is the master bore size that i am running. I have twin masters with a balance bar.
I was runnng the Wilwood BP10's and they never stopped well. Went to a Carbotech pad and it was night and day difference. The Carbotech Ax6 is an autocross pad that you can also use on the street. Easy on rotors, they are dusty and every once in a while I will get a small amount of noise. The cold mu on those are .52. I believe the cold on the bp10's is .32 or .35.
Per Carbotech's rec these are not a track pad for the front and will not handle the heat. Running street tires on the track they reccommended XP10's for the front and AX6's on the rear. If I move up to more aggressive rubber or a really tough braking track I will need to move up their line.
Give Carbotech a call and they can give you the info that you are looking for....
OK, thanks for the info on the M/C bore size. That makes sense.
The AX6 at .52 mu puts them in the upper range of a G rating. Good friction level for street use.
Bob.
Van B
05-28-2010, 05:21 PM
What master did you go with? What did you have on the car. I am fighting the same thing. Here is my current setup. I think it is a 15/16 bore.
MarkM66
05-29-2010, 02:58 AM
Very nice analysis.
jp
I'm confused, wouldn't more backspacing cause more 'lever arm', so yours would be twice that...
More back space moves the wheel in on the axle. The mounting flange of the wheel is closer to the outside.
Bob.
Vegas69
05-29-2010, 06:04 AM
Hang in there. I'm running a 1" bore Wilwood now. However, I found out yesterday that there is some residual pressure in the system at all times. The piston design was different from the 7/8 to 1" and I used the same push rod which seemed fine. One it's in the car the angle isn't perfect between the rod and pedal arm and puts just a touch of pressure on the system.(Atleast that's what I think) My brakes locked up yesterday and nearly stranded me. Strange since the night before it seemed fine after an adjustment in the rod length. Must of been the temp difference. Anyway, I'm not sure it's fixed my problem totally until I get the pressure out of the system at rest. So I get to start over and re bleed the system and bench bleed.:1st:
parsonsj
05-29-2010, 06:25 AM
wouldn't more backspacing cause more 'lever arm'Only after a point. Matt's lever arm measurement is from the wheel centerline. Todd's wheel's backspacing has the bearing retainer 4.088" inboard of the wheel centerline. More backspacing will move the bearing retainer closer to the wheel centerline, reducing that lever arm, and the force with which the axle is pulled from the center as the car goes around a turn.
I doubt the M/C bore size has anything to do with knockback unless there is some residual pressure in the system.
jp
Van B
05-29-2010, 08:26 AM
I doubt the M/C bore size has anything to do with knockback unless there is some residual pressure in the system.jp
Probably not, but if the MC is not moving enough volume it will be harder to overcome knockback. I have been going through this for three plus years now. I thought I found a bad MC last year but when I ran at Faceoff at Road America I realized my problem was not cured.
The manufacurer of my brakes can't even tell me for sure. They are guessing...
...One it's in the car the angle isn't perfect between the rod and pedal arm and puts just a touch of pressure on the system.(Atleast that's what I think) My brakes locked up yesterday and nearly stranded me...
If manual brakes (I think they are and didn't go back reading posts to find out), is there a return spring for the brake pedal? It may be that the weight of the pedal is tapping the M/C piston as the car gets bumped around.
Bob.
Vegas69
05-29-2010, 12:28 PM
Wilwood has a stiff spring on the piston. They don't recommend a return spring and I never has any issue with the 7/8. I'm pretty sure I know why....
05-29-2010, 01:48 PM
Steve Rupp chaged the Willwood 7/8" master to a 1" and his brakes locked up too. Now that the pushrod was shortened it's OK.
The GMR
05-29-2010, 04:29 PM
Very good thread. Surprised I just stumbled onto this.
I have been talking to Wilwood about this very issue for some time now.
One solution is to upgrade to a Full-Floater system for the rear end. :)
Jason
Vegas69
05-30-2010, 07:55 AM
It's weird, I adjusted it shorter the night before and drove for 30-40 minutes with no problems. When I got home I did roll the car back and forth and I could hear the front brakes drag which was strange I thought. The next day is was hotter and I didn't make it more than 5-6 miles and they locked up solid. I tried going shorter to no avail... I'm going to swap over to a factory type pushrod instead of the beveled aftermarket. I wasn't thrilled when I put it together and didn't think about the slighty angle needed to put in the clevis pin. On the bench when I moved the rod up or down it pushed the piston. Should of known but....
dontlifttoshift
05-03-2011, 02:25 PM
Soooo, I don't have a knock back problem (drum brakes) but my retainers are bent and this seemed like a relevant thread. It's a currie 9" with their axles and Timken set 20 tapered bearings. I have the 360 degree "heavy duty" retainer plates. When I pulled the car apart I noticed some play in the axles but didn't really worry about it. i got all my rear suspension sorted out, welded all my brackets on, and had the housing straightened. The races were trashed by the time they got out so I bought new bearings and noticed the retainers rocking on the bench. When I assembled the rear end originally it went together very well, I pushed the axles home by hand and "set" them with a deadblow hammer and tightened up the hardware.
Any ideas on how I can prevent these retainers from bending again?
Donny
dontlifttoshift
05-03-2011, 02:46 PM
I just got off the phone with Currie. They told me it was normal to bow a little, about .015", and that would happen on assembly. I get that.
These measure .065" at the middle. That seems excessive to me and hardly normal.
46536
Bryce
05-04-2011, 06:43 AM
how much does your bearing protrude from the axle ends. I think .020" is about normal. If you have more than that then maybe when you torque the retainers on you bent them.
Vegas69
05-04-2011, 06:44 AM
That's what I was thinking. ARe you sure you have the right retainers?
dontlifttoshift
05-04-2011, 07:53 AM
Yeah, everything went together fine the first time. I dont recall the plates bending when I tightened them but I do remember that the axles were nice and tight with no endplay and then they were loose when I took them apart. I am not sure what the right retainer would be. It's just a flat plate, no relief cut into the back. I need to measure the bearings/seals and the depth on my housing but I can't believe it would be wrong. This entire assembly came from currie.
Donny
mwhizard
06-05-2011, 08:27 AM
I had bad knockback on my wilwood rears and narrowed it down to my axle float. I bought new moser axles, and at the time put in a truetrac. I still had enough float with all new hardware to lose pedal feel. I am running the clip axles still so what I did was made my own spacer that goes between the axles on the truetrac. Basically took feeler gauges and figured out how much clearance there was on the supplied spacer, then made a new one on a lathe out of steel. It made a world of difference, but I still have a bit. I've heard of using a 2pound residual valve, is that something I should consider? Oh, and the system is 7/8 master, manual brakes, disk brake proportioning valve plus inline adjustable proportioning valve, 6 piston wilwoods up front and 4 piston wilwoods on the back.
https://static1.pt-content.com/images/pt/2011/06/IMG_3806-1.jpg
https://static1.pt-content.com/images/pt/2011/06/IMG_3981-1.jpg
Vegas69
06-05-2011, 10:05 AM
If you have one of the older Wilwood kits, the retainer was wrong and they have an updated retainer that has the proper lip and is thicker steel. I've shimmed by axles and have a 2psi residual. I didn't find that either did much good. I'm getting ready to convert to a floating caliper.
