View Full Version : What Cam Is This? Number 221508
toofun
05-04-2005, 02:56 AM
OK,
Got the cam out(STUPID FUEL PUMP!!!) But want to know what cam I have. The only markings on the back of the cam are 221508 Thats it. Also a light tan dot but other than that...nothing. How do I determine what cam this is OR what manufacturer made it? Any help would be appreciated. It came out of a goodwrench 350 chevy but it definately does not sound stock.
Mark
TOOFUN
toofun
05-04-2005, 12:15 PM
Looked closer at the cam and found this on it between the lobes CWC 1539. Does that help?
toofun
05-04-2005, 01:09 PM
Got this info from another site. Can anyone elaborate?
"That's the type of the numbering system that GM set up with CMC (Camshaft Machine Co.) for the cams that went into their products. I have no (specific) info with those numbers anymore, but that's what it looks like! They closed about 15 years ago, and made the cams available through the Wolverine/Blue-Racer line, but used an entirely different numbering system. And as far as I know there never was an interchange system set up."
toofun
05-05-2005, 01:25 AM
Alrighty then.....guess this question is either too hard or not worth someones time.....
apex69
05-05-2005, 03:06 AM
According to my clock its only been 24 hours, dam you can't even report a person missing in that time let alone a camshaft ID. :seizure:
I looked through my limited library of old cam info to no avail. I had this 800# to the GM Past Component History line but hadn't used it since 96 and just was not able to find it.
Lastly the right people may not have had a chance to get on the board to see this mysterious question. You know mothers day is Sunday, and some take all week to focus on what to get her.
toofun
05-05-2005, 04:46 AM
Cant help myself, once I lock my mind to something I cant break away from it until I figure it out.... On that note, found the CAMSHAFT MACHINE COMPANY after searching numerous other search engines with no success on DOGPILE.COM LOVE THAT SEARCH ENGINE!! Anyways, called them and they punched in the six digits and TADAAAA!! IT CAME UP!!! They are faxing over the specs today so should have them soon. Just in case anyone else ever runs into this problem, I have posted their contact info below.
Firm Type: Private Company, Headquarters Location
Address: 717 Woodworth Rd.
City / State / Zip: Jackson MI 49202-1654
Country: United States
Main Phone: 517 787-2040
THANKS
MARK
TOOFUN
toofun
05-05-2005, 05:04 AM
FAX JUST CAME IN. ANYONE CARE TO DIGEST THIS FOR ME? Thinking of going with an XE-268H COMP CAM?
CAM LIFT VALVE LIFT LOBE CENTERS
INT EXH INT EXH INT EXH
.325 .325 .488 .488 106 110
ADV.DURATION SAE DURATION 050 DURATION
292 300 300 308 232 234
SAE TIMING LASH
BTC ABC BBC ATC HYD
39 81 79 49
050 TIMING
BTC ABC BBC ATC OVERLAP 80
10 42 47 7 SPREAD 108
ADV TIMING
BTC ABC BBC ATC
39 73 79 41
