brans72
05-24-2010, 03:31 PM
I was wondering if anyone could measure there front and rear pistons on there C5 calipers? When I say measure this would be with the piston out of the caliper itself. Also anyone know where to pickup new ones or aftermarket ones besides the factory? Thanks Brandon
nor_cal_67rs
05-25-2010, 10:11 AM
I have a set of front and rear C5 calipers that are in great shape and only have 11,000 miles on em' that I don't need if your interested... are you looking for the piston diameter?
https://static1.pt-content.com/images/pt/2010/05/Ebay021-1.jpg
https://static1.pt-content.com/images/pt/2010/05/Ebay022-1.jpg
https://static1.pt-content.com/images/pt/2010/05/Ebay023-1.jpg
https://static1.pt-content.com/images/pt/2010/05/Ebay024-1.jpg
gort69
05-25-2010, 12:03 PM
This took about 30 seconds using the search key. Copied and pasted here:
CALIPERS:
C#, RPO, Front/Rear # and size of pistons, Mfg, Colour
C5, Base, Front x2 40.5mm pistons, P.cast PBR, black
C5, Z06, Front x2 40.5mm pistons, P.cast PBR, red
C5, Base, Rear x1 45 mm piston, P.cast PBR, black
C5, Z06, Rear x1 45 mm piston, P.cast PBR, red
C6, Base, Front x2 40.5mm pistons, P.cast PBR, black
C6, Base, Rear X1 45mm piston, P.cast PBR
C6, Z51, Rear, X1 42.5mm pistons, P.cast PBR
C6, Z06, Front x6 33mm pistons, P.cast monoblock PBR, red
C6, Z06, Rear x4 30mm pistons, P.cast monoblock PBR, red
Apogee
05-26-2010, 12:52 PM
Al already posted diameters...are we correct to assume you don't need the lengths, weights, etc?
Tobin
KORE3
brans72
05-26-2010, 05:22 PM
I am good with Al's info. I did try searching on google.
