View Full Version : Fuel Pump sizing for 700HP
I know this topic gets beat to hell but I have been researching this for a week and still dont know what to order. I know what I need for flow but I am having a heck of a time deciding which pump to run. I am ready to plumb a fuel system in my Camaro project. 700hp seems to be a breaking point for a lot of pumps, I choose a smaller pump and run on the verge of being not enough or choose a bigger pump and have overkill with noise and heat. for example, the Aeromotive pumps, the "700HP" pump is good up to 700 and the "A1000" is way to big. I have considered both of those and also the Mallory 110FI, and the Barry Grant Mighty Sumo. I have a Ricks tank with a sump and will run an inline pump out of the tank with a return but with the regulator at the back with only a single -8 to the front. I will drive my car long distance at times and dont want the problems I here about with heat and reliability. I dont want to have to put a controller in if I dont have to, would like to keep it simple if I can. Sorry for yet another FP question but if I have 500hp or 800hp it would be very clear but 700 seems to be right in the middle of alot of good pumps. thanks for the help guys.
DB Z28
05-23-2010, 02:54 PM
I run 2 gss340 walbro in tank pumps and have it set up that one pump runs all the time and the second pump kicks on when fuel pressure drops with a hobbs switch . 3 3/8 line going to a 1/2 to the engine
https://static1.pt-content.com/images/pt/2010/05/DSC_0130-1.jpg
Wicked
06-08-2010, 11:55 AM
I was also going to suggest dual intank Walbros.
I have yet to hear a quiet non-annoying external pump but I haven't been around many either.
I have used a single Walbro 255lph to make 532whp on a turbocharged 3.5 V6 pushing 18psi of boost. A naturally aspirated engine will require less fuel pump than a force induction engine. Two of the walbros would work just fine.
You could potentially wire a throttle switch to switch on a relay at
about 75% or more throttle to control the second pump.
Too much pump will just require a larger regulator and will heat the fuel. Being able to shut off the secondary pump would be beneficial.
Skip Fix
06-19-2010, 06:11 AM
FWIW the similar non EFI pressure Mallory pumps are pretty quiet.
I also was wondering what the Mallory 110 FI could handle HP wise.
1 Bosch 044 pump.
http://cgi.ebay.com/ebaymotors/BOSCH-044-0580254044-100-GENUINE-PERFORMANCE-FUEL-PUMP-/280509497731?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item414fab4183
