View Full Version : Who sell the best
Roadrage David
05-22-2010, 11:09 PM
2 inch drop first gen leaf spring to be used for roadracing!!.
i use the DSE 2 inch drop rear leafs that ofers a firm but not harsh ride. but afther 4500 mile hard fast driving and testing the car out, the left rear side is douwn and the right side hase come up!!!!.(stance wize) i also feel i could use a ""stiffer"" rear leaf . dont whant a 3 inch drop tho.. any sirguestions????...
Gitter Dun
05-22-2010, 11:15 PM
I'm driving a '69 camaro and liked the stock springs but car was too high in rear so I went to the Hotchkiss springs and rear bar but was too loose. Went to Global West springs with 2" drop and asked them to de-arch them another inch. I left the Hotchkiss rear bar in. car corners very well now at road courses.
Lowend
05-23-2010, 07:10 AM
If you want an off-the-shelf leaf spring for roadracing. There is nothing better than the Global West Cat V (http://globalwest.net/1967-69_Camaro-Firebird_springs_and_rear_leaf_bushings.htm)
To really get proper motion in the rear suspension, you have to run a spherical bearing in the front spring eye. CatV is one of the only setups out there that does this. They also use a thicker gauge steel than anyone else I've seen. Combine that with an extra leaf on the front of the spring, and you have a pretty damn nice setup.
Now, that said; with your ride height differences side to side: I could line up 10 cars with the same setup and they'd all sit differently. I'm curious if you may have damaged a leaf... are you running traction bars? If a traction bar is setup wrong (and most of them are), it can hit the spring in the wrong area and destroy them.
Can you post the rest of your setup, and some pics so we can get a better idea of what is going on?
Roadrage David
05-23-2010, 09:36 AM
Bred Very intresting!! defenatly a step up.. but they dont sell 2 inch drop leafsprings.
Lowend
05-23-2010, 12:13 PM
You can't ID any spring by its advertised drop... You'd have to know how the car was sitting to start with when you tool'd up
Gitter Dun
05-23-2010, 08:50 PM
I'm pretty sure they do sell 2" drop leaf's.
