View Full Version : Project SideOiler 66 F100
ProjectSideOiler
05-19-2010, 10:33 PM
My build is a 1966 F100 Short Bed Custom Cab
Kind of a Sleeper Build but getting a infusion of MORE power, Better Brakes, Lower Ride Height, Updated Suspension, Tires & Wheels.
The wheels for now are going to be custom made steels until its back on the road and I can find a step up again for better brakes for a 5 on 5 wheel "OR" I can find brakes and go to 5 on 4 1/2. Once its on the road that will be the next step.
Engine is a 427 Side Oiler which will be displacing 482 Cubes
4.25 x 4.25.
Engine base is a new Genesis Block, 4.25 Stroker kit, CNC'd Edelbrock Heads, Custom Quick fuel carbs (750+cfm each). Intake manifold is a Factory Ford Tunnel Wedge Dual Quad. Oil Pan is a Custom 7qt Road Race Unit.
Trans is a 1969 428 Cobra Jet C-6 with a custom Converter
Rear is a 9" with a Yukon gear Posi Unit (tight version) Running 3:50 Gears
This is prior to teardown. Other pic links lost. Updating links. 4/8/18
A very long project. 1st pic my middle daughter who is getting married next weekend. Older daughter married with family. Where does the time go?
https://static1.pt-content.com/images/pt/2010/05/b50a41c84a604aac87dba4efe5a70406_zpsccbc-1.png
https://static1.pt-content.com/images/pt/2010/05/5f306c9e61754e719bd61c14e6164cb5_zpse7db-1.png
https://static1.pt-content.com/images/pt/2010/05/ad64e435e27849449920bc16747d15a5_zpsfa27-1.png
https://static1.pt-content.com/images/pt/2010/05/IMG_0397_zps92a7dc0f-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0326_zps9f657d9f-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0311_zps83db7e92-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0273_zps6d874145-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0272_zpsa7b1ed14-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0265_zps4db782a1-1.jpg
From outside and a quick view of interior it will look stock. With exception of being a fair amount lower along with tire wheel package.
ProjectSideOiler
05-19-2010, 10:59 PM
Teardown time. Front clip is off and so is the cab along with the original
300 6 cyl
https://static1.pt-content.com/images/pt/2010/05/IMG_0328_zpsd1eaacba-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0376_zps8061b2e4-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0362_zps6b759ac3-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0409_zps9dc850a1-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0417_zps8ed59f1b-1.jpg
Building carts to hold the box and cab. The cab cart fits on top of the box cart for sandblasting etc
https://static1.pt-content.com/images/pt/2010/05/IMG_0557_zps6855c9ef-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0402_zps40919f82-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0764_zps3b7a6dfc-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0498_zps1baf868a-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0393_zpsc645f90b-1.jpg
ProjectSideOiler
05-19-2010, 11:06 PM
Engine Mock~up
https://static1.pt-content.com/images/pt/2010/05/IMG_0728_zpsfe2df7ca-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0726_zpsff75a28f-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0733_zps702d0ed9-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0732_zps24d43554-1.jpg
Sand Blasted Frame
https://static1.pt-content.com/images/pt/2010/05/IMG_0821_zps40973836-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0831_zps98bc6d54-1.jpg
ProjectSideOiler
05-19-2010, 11:24 PM
This was pre-fitting the engine and trans. Close but it Fits!
Pics above. Try;ing to edit broken links
ProjectSideOiler
05-19-2010, 11:27 PM
Frame and other chassis components back from the Powder Coater
https://static1.pt-content.com/images/pt/2010/05/IMG_1015_zps743c5df9-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_1036_zpsf68d1044-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_1459_zps202b95bd-1.jpg
ProjectSideOiler
05-19-2010, 11:32 PM
I started to build this car but when I moved had to give it up.
If anyone knows where its at I would like to buy it back. Last I knew it was in Tennesee
https://static1.pt-content.com/images/pt/2010/05/66Cyclone036_zps8cb47b58-1.jpg
https://static1.pt-content.com/images/pt/2010/05/66Cyclone039_zps31bf4f0e-1.jpg
https://static1.pt-content.com/images/pt/2010/05/66Cyclone020_zps886bfc2a-1.jpg
https://static1.pt-content.com/images/pt/2010/05/66Cyclone019_zps245e6990-1.jpg
ArtosDracon
05-20-2010, 01:37 AM
Looks nice, those trucks had pretty impressive suspensions from the factory, at least for a truck. Are you planning any mods?
ProjectSideOiler
05-20-2010, 07:32 AM
Mods are: The 482" motor, adding 77 F150 power disc brakes, dropped I beams in the front, Power Steering.
Also plan on adding front and rear bars but have not figured out exactly what yet. I expect it to handle pretty well as you say for a
"truck". I will need help on chosing the proper sway bars. Not much made for these trucks in performance suspension or brakes.
I expect the weight to be around 3650lbs. My modern day shelby is 3900...
The engine is set back as far as I can get it without chopping the firewall. #1 plug is back of axle centerline which is good compared to most cars but still a truck. I would like to "track" it once its done then get into tuning the chassis.
Close-up of carts
stripping of paint
Arizona Truck so sheet metal is very nice for a starting point.
Box floor had many small little dents. Started to shrink each one but decided to install new floor after finding out the 2008 Super Duty floor were near exact dimensions. 225 spot welds later...
ProjectSideOiler
05-20-2010, 08:14 AM
Engine, Trans and Rear Axle parts start to show up
Very unfortunate someone put a bottle jack under the trans and popped a hole in it. Nothing a little Tig'n could not take care of
My first Auto trans rebuild so lets hope it works.
ProjectSideOiler
05-20-2010, 08:19 AM
Engine Time!
Assy process
ProjectSideOiler
05-20-2010, 08:22 AM
All bare metal and time for primer
ProjectSideOiler
05-20-2010, 08:27 AM
Finally in primer
ProjectSideOiler
05-20-2010, 08:31 AM
After sanding each nook and cranny, re-prime, then sand again its finally ready for sealer and paint
ProjectSideOiler
05-20-2010, 08:54 AM
About the only real repair on cab was the cutout for radio that was kind of hacked. Easy fix.
Chassis going back together
Dons67
05-20-2010, 09:14 AM
Nice work -- My first vehicle was a Ford F-100. I loved that truck and hope to have another some day. This would do :)
ProjectSideOiler
05-20-2010, 09:23 AM
Thanks! My dad brought a new 66 F100 home October of 1965 and I fell in love with them way back then. Its what I learned how to drive in and what I used. He then gave me the truck around 1984.
Engine going together
CruizinKev
05-20-2010, 09:24 AM
wow killer project! looks great so far!!! :twothumbs
ProjectSideOiler
05-20-2010, 09:30 AM
Thanks!
Cab ready to go back onto completed chassis
6'9"Witha69
05-20-2010, 09:33 AM
I love it. Makes me want to redo my '62 F100. Camaro is first in linr though.
ProjectSideOiler
05-20-2010, 09:34 AM
This is where its at right now. Still a ton of work left to do but finally looking like something has been done.
Trying to do the complete truck for under 25k. Looks like it may be possible. A HUGE chunk of that was spent on the engine. Close to 50%
ProjectSideOiler
05-20-2010, 09:36 AM
Thanks! I really like the 61-66 F Series trucks. Have another too that will get my other Side Oiler soon.
ProjectSideOiler
05-20-2010, 09:43 AM
restored dash and seat
csx4766
05-20-2010, 01:02 PM
Beautiful. father had a 66 he used as a delivery truck for the rental business he had owned. Leaned how the trive a standard trans with that truck.
Looks like you are running my friend Doug Garifo's rockers (Precision Oil Pumps).
Phantom_LS2
05-20-2010, 01:27 PM
It may just be the angle of the picture, but how are you planning on changing out the oil filter?
ProjectSideOiler
05-20-2010, 01:57 PM
Thanks!
I actually bought them from Cam Research and they would not tell me who's they are... I would like to find out for sure if they are from Doug as have a few questions on setup.
It does look close but there is a fair amount of room.
Enough where I can actually fit my hand underneath it.
ProjectSideOiler
05-20-2010, 02:04 PM
The last photo is a bit of trick photography as my hand is actually in a pocket I build for just that. The truck oil adaptor has the filter pointing out but did not want to have a major oil spill each time I removed the filter.
Also had to notch the frame for the road race type "T" oil pan.
Good eye though! lol
ProjectSideOiler
05-20-2010, 02:18 PM
All hardware back from the plater. Most is electroless nickel as will hold out the elements so I can actually "drive" this thing.
another time consuming job was restoring the gauges.
6'9"Witha69
05-20-2010, 02:56 PM
You didn't want to convert to rear sump? I have to as my I beam hits the sump (slightly) at full bump.
Tiger
05-21-2010, 01:08 AM
LOVE the truck, beautiful (and fast) work.
It might just be the pic but to me it looks like the engine is not centered (moved towards the left part of the pic..
68firebird
05-21-2010, 03:24 AM
I love the choice of truck and I really like this build thread, alot of pics and very detailed. thanks for sharing!!
ProjectSideOiler
05-21-2010, 09:05 AM
Andre, Yes you would be correct. I had just dropped the engine and trans along with the cab back on to chassis and jumped the gun taking the pic.
Also the engine is not level in the pic but it was the best pic I had to show the build. Thanks all for the kind words.
A couple pics when I was leveling it up.
The mounts are still not bolted up at this point, the cab is not 100% squared either. Kind of a test fit to make sure is all ok. Brake booster is only 1/4" from valve cover less gasket so I need to make a wedge for it etc. The intake manifold is also just sitting there... The tailshaft-rear needs to go to drivers side by about 1/2. crossmember not bolted in yet...
Its really a struggle trying to do everything yourself. Especially when dropping in the engine/trans or installing/removing the cab or bed along with a zillion other tasks. Its taking a long time trying to do it all myself to save $$ as do not have the funds to farm anything out. That includes, engine, trans, body & paint, interior etc. Also the weather here really sucks so doing any blasting, painting etc has to be on a few and far between nice day. Last night it was down well below freezing and its getting close to the end of May! lol
More updates soon. Getting a tad excited to actually hear it run.
ProjectSideOiler
05-26-2010, 10:55 AM
After 10yrs of looking and debating with myself on wheel choice & purchasing a custom set of wheels I liked but not my real choice but by $$ I have finally found a set of wheels to go on the truck and to fit the rest of my theme.
A email was sent to Schott wheels to see if they could do it in a 5 on 5 bolt pattern. Its simply amazing the fast and personal response I rec'd this morning from Dave at Schott Wheels.
I still need to determine exact sizing, spacing etc but need a little help.
I now have a 15" wheel with major caliper clearance issues along with being very heavy. I was thinking on going to 17x10 & 17 x 8's. Also the 15" has such a poor tire selection.
I need a little help as I plan on Autocross with this truck.
I am afraid a 18" wheel would look too big? This is the wheel in question. Whats a good all around tire to use with autox in mind too?
This is the wheel. A pic from Dave and hope it is ok to use. Thanks Dave! I really appreciate all the time you have taken so far to help out especially when other companies just laughed at me.
ProjectSideOiler
05-26-2010, 10:59 AM
I have never seen a wheel that looked so "CLEAN".
I viewed pics many times before I caught on what was doing it.
Its like whoa where are the lug nuts... LOL
A link to how its done.
http://www.schottwheels.com/cover-loc.cfm
Amazing service so far from this company and am happy to have found them here on another members ride.
Fast68back
05-26-2010, 11:58 AM
Wow....coolest thing about this truck is EVERYTHING!
ArtosDracon
05-27-2010, 06:40 AM
You should definitely go with the classic knock offs for the center nut with those wheels!
Ripped
05-27-2010, 08:02 AM
Nice build
Love the "mercury" valve covers.
I have the same pan as you
I like the wheels
I'd say go 17's
Nice balance of rubber and rim, visually
Brandon Miller
05-27-2010, 12:55 PM
Personally I think the 18" wheel would look much better than the 17s. 17s on those trucks look too small to me.
6'9"Witha69
05-27-2010, 01:54 PM
Agreed.
ProjectSideOiler
05-27-2010, 06:35 PM
Agreed.
Its looking like 18's. I just need to sort out which tires to use etc. I also need more wheel to fit the bigger brakes.
It will be a week or so as have to finish up on a couple other projects to really get back heavy on this one.
Can anyone help me with sway bar size?
Jims78elky
05-28-2010, 01:41 AM
Got Nuts?
:) lol..J/K..
Wow..just a awesome project!
-Jim
DaviRotten
05-28-2010, 10:14 AM
Badass
ProjectSideOiler
05-28-2010, 12:56 PM
A few pics. Wheel I was going to use to try to stay within my 25k budget
This is a 10" x 15 Steel with NOS OEM Hubcap. Wheel would have been powdercoated or painted body color (orange)
Next is a 18" x 9 put in place to see what it would look like. I think the 18's would be as large a wheel as I would use. Total height is 1" taller than other tire pictured 25.5 vs 26.5. I still need to figure out exactly which tires and wheels to use.
Comparing the diff tires/wheels. It for sure needs something other than original plan.
ProjectSideOiler
05-28-2010, 01:05 PM
Another issue I ran into is the I beams. The DJM's were absolute junk (the silver splatter paint version) The dark/black are current AIM's.
Turns out the AIM's are giving me 2"+ additional track throwing off all my measurements which came from the stock beam.
Here you can see how crappy the DJM beams were. Welded together so crooked and the main part where kingpin is is just plates tacked together along with having .050" of slop in pins. Also there was no caster built in and was different side to side. Sent em' back as scrap.
Here is a better engine pic (my camera lens is toast and does not want to focus) also a rear spring mount prior to going off to powder coater
ProjectSideOiler
05-28-2010, 01:11 PM
close up shot of rear end detail.
Once the truck is mostly done the rear end will have to be re-visited as started out with a stock 427 making 425hp. Add 50% more HP to that and now I will most likely change center and axles to ensure no issues. A simple deal once the rest is completed.
ProjectSideOiler
05-28-2010, 01:33 PM
Got Nuts?
:) lol..J/K..
-Jim
Nuts bolts and all four shocks?
wellis77
05-29-2010, 10:54 AM
I like the 18" wheels. Are those FR500's? Would definitely be a different look for a truck.
ProjectSideOiler
05-29-2010, 07:57 PM
That wheel for demo purposes and to see fit etc is specific to a
GT500 "KR". its a 5 on 4 1/2.
If you look close its just sitting there. I am using it to help me get proper size and look.
This is the wheel I am using
From Schott Wheels.
dmc69
05-30-2010, 07:35 AM
That schott wheel is Nice:cool::cool:
Ripped
06-05-2010, 09:39 AM
Like I said, I really like those wheels (your wheel choice), different, and look great, although so do the classic hubcaps on a nice rim.
I admire you patience in restoring all the old hardware. That's a crazy amount of work
windsor
06-05-2010, 11:33 AM
awesome ride and work! Love those old Ford trucks!
what kind of power is the motor putting out? What kind of cam is in it?
jake72ss
06-05-2010, 12:37 PM
nice Johnny Cash ref, one piece ata time.
joemac
06-05-2010, 01:37 PM
This is an awesome build. My first truck(vehicle) was a '66 except it was a long bed and black with a white roof. It also had the 300 I6 but the previous owner I bought it from gave me a 352FE to put in it's place. Needless to say I sold it before I ever installed that motor. Too bad, I still kick myself for getting rid of it.
ProjectSideOiler
06-05-2010, 02:16 PM
Thanks All!
Lets just say the power is something north of 600hp...
The cam is a Custom Grind (street) solid roller. Fairly heavy truck with estimate around 3600-3750lbs the cam is made for T O R Q U E .. Powerband should be pretty stout from 2000 up to 6200. (comp ration of 10.6 to 1) Do not plan on turning it past 6500rpm. With a cam change it would probably gain 100hp but want driveability. I expect the truck to run 11's in the 1/4 when done. Also hope it will do well in autox for a truck.
I had BIG plans for past couple weeks for some more body work and paint but ended up pulling the 352 out of my 65 F250 to fix some oil leaks. Ended up going thru the engine to make it fresh again. Now I am debating to pull the front clip and do the engine bay because the engine
detail is making the bay look bad. LOL It always starts out as a carb rebuilt and escalates from there!
The 66 482 project is where my heart is but just so much other stuff to do. Hard to keep up with it all. Closing in on it though as just finished a major project yesterday.
joemac
06-05-2010, 02:33 PM
Priorities, priorities lls
sgt d
08-16-2010, 06:36 PM
updates? i see you have a shelby, are you over on svtp too? great looking project, i just got rid of my shelby and this project has me considering doing a resto mod on a 74 f100 in the back yard, good looking work.
csx4766
08-16-2010, 08:43 PM
great looking truck. I have always been a fan of the F-100. The first vehicle I lerned how to drive was a 66 F-100 my father used as a shop truck.
ProjectSideOiler
08-16-2010, 09:11 PM
I have been away from home for nearly a month and 2 months on another project. It was Just today when I emailed Dave @ Schott wheels to say I am ready to go on the wheels.
I recently sold my KR and also my '32 3w coupe. Trying to clear out so I can get serious about finishing this truck. With only 1 project to deal with instead of a bunch it should make things much more simple.
Today was first time since my last post I had time to even think about this project. Amazing someone should ask the same day I decide to go at it again!
We have had our house for sale for nearly 4yrs and today had a little nibble. If that happens it will be panic mode trying to get things done in short order before a move because I may not be blessed with such a nice home shop setup at the next place. I promise more very soon.
A couple of the current almost done project a ORIGINAL PAINT 1965 Deluxe Camper Special which I pulled the engine on Memorial Day to fix a couple oil leaks. Like most projects I get my hands into they balloon to major projects.
Just sold this on Thursday (Monterey)
This one is gone as of a week ago
Need to slim down the heard a bit more but getting there.
LineUPP
08-17-2010, 05:46 AM
badass truck!
78 Type-LT
08-17-2010, 06:13 AM
I love these truck..my uncle had 66 LWB 390 C/6..we rode it tha back of that thing everywhere
ProjectSideOiler
09-03-2010, 01:42 AM
Its been far too long since I had a chance to work on this project but today was the day! Hopefully now I can keep at it for a while.
Finally got the solid roller lifters and custom pushrods. Installed along with the intake, rockers have to be shimmed for proper alignment with valve stem and to make sure the pushrods clear the holes in intake manifold.
Valves are now adjusted, oil added and primed. Hopefully within the next couple weeks I can fire it... A couple pics of todays progress.
I am getting a tad excited to say the least as this has been a dream since 1966.
sgt d
09-03-2010, 02:24 AM
looking good
ProjectSideOiler
04-15-2016, 11:59 AM
Oh Wow, Going on 6 years since a update. Had some major issue's with PhotoBucket, All the pic links were lost. Thought I would revive this thread as so much has happened since.
In next week will try to figure out how to replace the lost links.
Our Spokane house sold February of 2011. Moved into apartment. Made the move back to Phoenix stayed in a rental with no room for projects. Then finally bought a house in Phoenix with a decent yard but crappy garage. It has taken a long time to get going again. Then health issue's kicked in. Lost nearly 6 years. I now have 2 other MAJOR projects I have started.
This is what the '66 427 Project truck looks like now.
https://static1.pt-content.com/images/pt/2016/04/IMG_6215-1.png
https://static1.pt-content.com/images/pt/2016/04/IMG_6216-1.png
https://static1.pt-content.com/images/pt/2016/04/DSC00305-1.jpg
Jetfixr320
04-15-2016, 08:19 PM
That thing looks Sweet! Glad you are back at it.
ProjectSideOiler
02-15-2018, 02:48 PM
Just over 18 years since I last drove this truck! No $ time or health issues have really put a damper on this project.
I was finally able to get the truck out of another long time storage and slowly trying to finish the truck for my Middle daughters wedding mid April. Although still plagued with continued health issues have made some progress.
I was able to have Baer Racing make me up a custom set of 14" 6 Piston brakes for the project and they are now installed although still have to run the brake lines and hook up the E-brakes.
https://static1.pt-content.com/images/pt/2018/02/017-1.jpg
https://static1.pt-content.com/images/pt/2018/02/015-1.jpg
https://static1.pt-content.com/images/pt/2018/02/032-1.jpg
https://static1.pt-content.com/images/pt/2018/02/031-1.jpg
https://static1.pt-content.com/images/pt/2018/02/036-1.jpg
https://static1.pt-content.com/images/pt/2018/02/012-1.jpg
ProjectSideOiler
02-15-2018, 02:51 PM
https://static1.pt-content.com/images/pt/2018/02/039-1.jpg
Rotor inside a 15" wheel
https://static1.pt-content.com/images/pt/2018/02/037-1.jpg
ProjectSideOiler
02-15-2018, 02:57 PM
Refresher because so many photo's are missing
Still remains the 482" FE Dual Quad with a Cobra Jet C-6. I have now added a GV OD unit also.
https://static1.pt-content.com/images/pt/2018/02/IMG_2830_zpsccc17e48-1.jpg
https://static1.pt-content.com/images/pt/2018/02/IMG_2596_zps1f64a0c6-1.jpg
https://static1.pt-content.com/images/pt/2018/02/IMG_2604_zps4c1f4ba4-1.jpg
https://static1.pt-content.com/images/pt/2018/02/IMG_4393-1.jpg
I do have some Mercury script covers I had Show Chromed that will go on near end of build.
https://static1.pt-content.com/images/pt/2018/02/IMG_4622-1.jpg
ProjectSideOiler
02-15-2018, 03:05 PM
Plenty of clearance for the GV OD unit!
https://static1.pt-content.com/images/pt/2018/02/009-1.jpg
https://static1.pt-content.com/images/pt/2018/02/011-1.jpg
https://static1.pt-content.com/images/pt/2018/02/012-2.jpg
https://static1.pt-content.com/images/pt/2018/02/022-1.jpg
I also upgraded the Rear center to a Nodular 31 Spline with 4340 Chromemoly axles
https://static1.pt-content.com/images/pt/2018/02/032-2.jpg
https://static1.pt-content.com/images/pt/2018/02/033-1.jpg
Driveshaft is only 36" long. Quite short for a pickup truck
ProjectSideOiler
02-15-2018, 03:12 PM
I also found another really nice short bed box that I have blasted top n bottom inside and out. I had replaced the original box floor with a late model F150 and although quite happy with how it turned out the shape of ribs is way different so elected for the more OEM look. It only took 18yrs to find the proper box!
https://static1.pt-content.com/images/pt/2018/02/001-1.jpg
https://static1.pt-content.com/images/pt/2018/02/018-1.jpg
https://static1.pt-content.com/images/pt/2018/02/046-1.jpg
ProjectSideOiler
02-15-2018, 03:18 PM
These are the home brewed Step Headers I did. Just today a bunch of 3" 304 Stainless showed up to build remainder of exhaust system.
https://static1.pt-content.com/images/pt/2018/02/IMG_7049-1.jpg
https://static1.pt-content.com/images/pt/2018/02/IMG_7047-1.jpg
https://static1.pt-content.com/images/pt/2018/02/DSC03711-1.jpg
ProjectSideOiler
02-15-2018, 03:27 PM
Almost forgot the best upgrade!
I ordered a pair of these wheels from Schott! Hope they look as good on truck as I envision! Expecting them to be done in next 2-3 weeks as a 6-7 week turnaround.
I had to change bolt pattern on truck with a lot of custom parts just to get these wheels.
Front wheels are 18 x 8 and will be getting Continental Extreme Contact Sport 245/45ZR18 Tires
Rear Wheels are 18 x 10 and will get Continental Extreme Contact Sport 285/40ZR18's About the largest I can do and still have proper clearance.
https://static1.pt-content.com/images/pt/2018/02/030-1.png
https://static1.pt-content.com/images/pt/2018/02/032-1.png
ProjectSideOiler
02-15-2018, 03:35 PM
I also have a Twin Turbo 540" Boss9 truck build that I started a year ago. Takes so long just to gather parts!
C & C Alum Block
Bryant Billet Crank
Carrillo Rods
Kaase B9 Heads
Custom Turbo's
Finally have all pieces to get going on engine.
Wish It would have gone in this truck but too buried in this 482" FE to change now.
https://static1.pt-content.com/images/pt/2018/02/2B673EECA26840DA9DCB2DEB15F1C3D9-1.jpg
https://static1.pt-content.com/images/pt/2018/02/0981BFA59EFF4065A8AC5E4A3190C9DF-1.jpg
https://static1.pt-content.com/images/pt/2018/02/B70736826BE2406D9D8FF29ED5C2C996-1.jpg
https://static1.pt-content.com/images/pt/2018/02/B81C0EE6BE4C47A5BB4DC7910284D15E-1.jpg
https://static1.pt-content.com/images/pt/2018/02/28E323EFF46849759B6A5663AACFF3C4-1.jpg
https://static1.pt-content.com/images/pt/2018/02/02CBE2A082354196BF08C0A419A7EB4B-1.jpg
https://static1.pt-content.com/images/pt/2018/02/45A7D46243DC4001AAFD67495638EEA2-1.jpg
https://static1.pt-content.com/images/pt/2018/02/2BAB5304C75B4015BC9FBF1B09B4CFD9-1.jpg
https://static1.pt-content.com/images/pt/2018/02/423C0674686644FE8F02014188BB8A92-1.jpg
https://static1.pt-content.com/images/pt/2018/02/FF5B0F4D6F33418CB5AEE3FC3D477AC6-1.jpg
https://static1.pt-content.com/images/pt/2018/02/1105B742A95741BFAAEE4014F2693CFE-1.jpg
https://static1.pt-content.com/images/pt/2018/02/2CC50601F0954BBB97FE6A2BA8E9E2CC-1.jpg
https://static1.pt-content.com/images/pt/2018/02/502C35E2970C40C3BF4DEF4001DBB8A8-1.jpg
wfo guy
02-15-2018, 03:59 PM
Nice parts! I had a long history with Fords years ago, all the way from boss 302 to 427 sohc. It's always good to see someone restart. I'm sure I didn't need to tell you that. :)
ProjectSideOiler
02-15-2018, 06:25 PM
I have been messing with fords for over 45yrs. Same from Boss 302 to 427 SOHC and B9. Winding down now with only a year or so left before I hang up the toolbelt. Just current projects to finish then thats it.
ProjectSideOiler
03-10-2018, 07:47 AM
The custom wheels from Schott showed up, tires mounted. Schott knocked it out of ballpark on the wheel build!
Making progress but pretty slow . .
I finished up building the 304 Stainless Exhaust. The home made headers got ceramic coated. Ready to start assy
Decided to go with a Dual Quad EFI, that is now here also
https://static1.pt-content.com/images/pt/2018/03/034-1.jpg
https://static1.pt-content.com/images/pt/2018/03/81740584DC534C5580C7718B2CAEAE88-1.jpg
https://static1.pt-content.com/images/pt/2018/03/021-1.jpg
https://static1.pt-content.com/images/pt/2018/03/E5E7BA75A8664432AF420A9181F33835-1.jpg
https://static1.pt-content.com/images/pt/2018/03/015-1.jpg
https://static1.pt-content.com/images/pt/2018/03/007-1.jpg
https://static1.pt-content.com/images/pt/2018/03/006-1.jpg
ProjectSideOiler
03-10-2018, 08:00 AM
https://static1.pt-content.com/images/pt/2018/03/047-1.jpg
https://static1.pt-content.com/images/pt/2018/03/039-1.jpg
https://static1.pt-content.com/images/pt/2018/03/049-1.jpg
https://static1.pt-content.com/images/pt/2018/03/052-1.jpg
This last pic wheel obviously not in place. Gotta jack body up from frame to get it in place
wfo guy
03-10-2018, 10:51 AM
Waiting to hear your review on the Fitech. A few years ago I ran into a man with a Falcon that had an Easy efi dual quad setup on a tunnel ram sbf. He was very happy. He had a street tune and a race tune loaded in the controller. He was real pleased with the way he could swap.
ProjectSideOiler
03-10-2018, 09:43 PM
Hopefully will know in a couple weeks or so
https://static1.pt-content.com/images/pt/2018/03/010-1.jpg
HotRod47
03-11-2018, 02:52 AM
Love the build!!
ProjectSideOiler
03-25-2018, 06:17 PM
Love the build!!
Thanks Glenn! I kept up with your entire build on the MAV. Congrats for the sweeping 5 Awards at the big show! Much deserved!
ProjectSideOiler
03-25-2018, 06:20 PM
Its back on all 4 wheels for the first time in months!
https://static1.pt-content.com/images/pt/2018/03/032-1.jpg
https://static1.pt-content.com/images/pt/2018/03/027-1.jpg
https://static1.pt-content.com/images/pt/2018/03/DBB18AA6064246419DEFA6D32420D883-1.jpg
https://static1.pt-content.com/images/pt/2018/03/034-2.jpg
ProjectSideOiler
03-25-2018, 06:22 PM
Short video of the 304 Stainless exhaust and custom headers. Home brewed of course
https://www.youtube.com/watch?v=npZDMwMClTc
https://www.youtube.com/watch?v=Lqc0nkIMYik
ProjectSideOiler
03-25-2018, 06:25 PM
few undercarriage pics. Getting close on the bottom side. Just gotta finish up making the trans cooling lines and ebrake cables. Then go around and tighten everything up.
https://static1.pt-content.com/images/pt/2018/03/EE071C7C8C4D4A43818359CCB13EE78B-1.jpg
https://static1.pt-content.com/images/pt/2018/03/5243E1026A5040BCA0EF8444FC0D0178-1.jpg
https://static1.pt-content.com/images/pt/2018/03/C6508999ECB94D54879A2558C51BF699-1.jpg
ProjectSideOiler
04-08-2018, 08:57 AM
1st attempt at uploading pics directly from computer. Making very very slow progress. Things always take 10x longer than I think. Truck as is weight 3239 lbs. Exhaust, Brakes, Tire/wheel package along with the Gear Vendors OD added a lot of weight. Looking like curb will be around 3650 lbs or so
wfo guy
04-08-2018, 09:13 AM
I find it interesting that my 32 Ford pickup and 51 Ford pickup both are within 100 lbs. of yours. One is a 302 and tremec 3550 and the other is a 4.6 2v and tremec 3650. They both have ac and stereo equipment. :)
ProjectSideOiler
04-08-2018, 09:33 AM
Within 100 of the 3239? or projected done weight of 3650? It may even end up 3750 a lot of weight to add yet.
Fenders etc not much but by the time I add tailgate, Grille, bumpers, fluids, fuel tank it will get up there. SHould have gone with a aluminum block . .
wfo guy
04-08-2018, 09:52 AM
3239. The 32 has a 9" rear with Mark vi discs that are real heavy. The 51 has a 8.8 rear with light calipers and discs. The 32 also has an alum. flywheel. :) The 51 sits on a custom chassis that I fabbed out of 2 x 6 and 2 x 4 rectangle tubing. They both have a metal bed floor that is similar to a 70's series F100. Your engine surely has 200 lbs on the 4.6 and 100 on the 302. :)
ProjectSideOiler
04-08-2018, 10:11 AM
My engine was under 500 lbs. Don't let all that "painted" aluminum fool you . . That's lighter than a 4.6. A stock 352/390 is only 625. The FE engines are not as heavy as most think.
ProjectSideOiler
04-08-2018, 10:14 AM
Thinking what all I need to add. this truck could be 3700 lbs. Will soon find out!
I have 4 certified scales so I weigh everything.
ProjectSideOiler
06-26-2018, 06:33 PM
First startup is always fun!
https://www.youtube.com/watch?v=G4uESPCdk04
https://www.youtube.com/watch?v=ZXsDeROuLjk
the dan
06-27-2018, 07:51 AM
I feel like this project is underrated on here. These side oiler engines are really cool! Pumped you stuck with a Ford motor! the dual fitech is sweet too! ill be following this one
Jetfixr320
07-02-2018, 04:25 AM
Randy
Looks awesome!
ProjectSideOiler
07-11-2018, 08:30 PM
I feel like this project is underrated on here. These side oiler engines are really cool! Pumped you stuck with a Ford motor! the dual fitech is sweet too! ill be following this one Thanks Dan! so close to that first test drive! Thinking maybe tomorrow if the rain stops and things clear up a bit. At least the driveway will not be dusty . .
Randy
Looks awesome! Thanks!
Undercarriage video
https://www.youtube.com/watch?v=R_w2rejZ4-8
ProjectSideOiler
08-15-2018, 08:27 PM
Drove it around yard a couple weeks ago. Now doing final assy.
Running vid
https://www.youtube.com/watch?v=jq5u4VG446I
Short drive around yard
https://www.youtube.com/watch?v=yWumZOTUZsk
Turn up volume! done on cell phone
ProjectSideOiler
08-15-2018, 08:32 PM
Hoping to do GoodGuys Scottsdale AutoCross & Show November 2018 and maybe GNRS January 2019
Resto update very short version
https://www.youtube.com/watch?v=iFyZH2ygb8Y
More update vid to close to where its at right now
https://www.youtube.com/watch?v=IcTdSmeXGOQ
ProjectSideOiler
08-15-2018, 08:34 PM
a few detail pics. Hoping to have all done but box and tailgate by end of this month.
https://static1.pt-content.com/images/pt/2018/08/4C88F58BE6D04B24B7A193F4FE184DDD-1.jpg
https://static1.pt-content.com/images/pt/2018/08/C90FD93AC7E94A0AAB77DC0178AD6B5A-1.jpg
https://static1.pt-content.com/images/pt/2018/08/2B5D7B41384F40B1822A9AB7279BD3BB-1.jpg
https://static1.pt-content.com/images/pt/2018/08/93B892A8432940BD96665B4DB3BE114B-1.jpg
https://static1.pt-content.com/images/pt/2018/08/163F71C6F4314B95B08F6D6110D8708E-1.jpg
https://static1.pt-content.com/images/pt/2018/08/587783F6D1794876BB17741917F28373-1.jpg
https://static1.pt-content.com/images/pt/2018/08/FE934784C48D42CEA1702A7980C7D557-1.jpg
https://static1.pt-content.com/images/pt/2018/08/14A72E724B264B248145D9D820330567-1.jpg
https://static1.pt-content.com/images/pt/2018/08/B9D804890DC543899AC821EEDB458EE6-1.jpg
https://static1.pt-content.com/images/pt/2018/08/5EB0B78DE3F64B03969DFC90E680ED32-1.jpg
https://static1.pt-content.com/images/pt/2018/08/31682F449CF9444BA1D45979F715A78F-1.jpg
https://static1.pt-content.com/images/pt/2018/08/058B5365617344758C8A3B329F3CFEA8-1.jpg
ProjectSideOiler
08-15-2018, 08:43 PM
https://static1.pt-content.com/images/pt/2018/08/4AAC75409C4B4165B0E098F7874969F2-1.jpg
https://static1.pt-content.com/images/pt/2018/08/F0EFEF2A7E364ED5A96A7602C4CC39DE-1.jpg
https://static1.pt-content.com/images/pt/2018/08/91A2ED947A5F4463B0E215FEFCEAE194-1.jpg
https://static1.pt-content.com/images/pt/2018/08/EF20192A2B0D4DB7B59F71DC505B0BE1-1.jpg
https://static1.pt-content.com/images/pt/2018/08/15B65BDC6B0442AC897EC8FB1D64FA9F-1.jpg
HotRod47
08-18-2018, 02:30 AM
I love this truck!!!
ProjectSideOiler
08-26-2018, 08:31 PM
Thanks Glenn! Looks like you are getting a lot of enjoyment out of that Maverick!
Updated video on my truck
https://www.youtube.com/watch?v=a3v3l9-5Nmw
Bossed
08-27-2018, 05:31 PM
That's a beautiful truck, you've done a great job !!
ProjectSideOiler
08-30-2018, 05:53 PM
Thanks!
A few updated pics from today. Finally got it out in the sun vs shop lights.
https://www.youtube.com/watch?v=fS7PQRLvu_A
New video uploaded
https://static1.pt-content.com/images/pt/2018/08/6C94001E87DA4C2B8E54DEF4FE5A84E1-1.jpg
https://static1.pt-content.com/images/pt/2018/08/98CBE9BDBE5C4DEAA3DD89B185AFDFCD-1.jpg
https://static1.pt-content.com/images/pt/2018/08/9831911B9B2A4BCEA5EAF915465C1354-1.jpg
https://static1.pt-content.com/images/pt/2018/08/9047C2E24F004C52A153F628A868680A-1.jpg
https://static1.pt-content.com/images/pt/2018/08/ADE53EE166204CF1B6A172F09DCDA6A0-1.jpg
https://static1.pt-content.com/images/pt/2018/08/8D4AFECB32F9445F8EBB64797091B496-1.jpg
https://static1.pt-content.com/images/pt/2018/08/3E59D15C79E74825B67F6FF9B45D5612-1.jpg
ProjectSideOiler
11-24-2018, 09:16 AM
Was able to drive it down road for first time Thanksgiving Day!
Bit of a update where it's at right now. Still need to add remaining trim, finish up interior, wiring for GV OD but oh so close! after a 40+ yr wait its looking like a truck once again. Takes a long time doing it all myself with help from friends vs farming anything out.
https://static1.pt-content.com/images/pt/2018/11/B654B7A8FA2D435FA5CCAFA11604E1D1_1-1.jpg
https://static1.pt-content.com/images/pt/2018/11/3977E040FD0049B5B624699F0ED6FFDB-1.jpg
https://static1.pt-content.com/images/pt/2018/11/7F4E40E703734A398025C5E71138F603-1.jpg
https://static1.pt-content.com/images/pt/2018/11/BC57A3CCAF1349CCBD7B2E8EC3AEE9CA_1-1.jpg
https://static1.pt-content.com/images/pt/2018/11/A887F8773852454DB44DEA07D3764BE4-1.jpg
https://static1.pt-content.com/images/pt/2018/11/9D078FC96C2F48239E5FD1D716A3BDB2-1.jpg
- - - Updated - - -
Short 5 minute video
https://www.youtube.com/watch?v=SunGDCYUoME
wfo guy
11-24-2018, 10:39 AM
That gave you one more reason to be thankful! Very good! :)
ProjectSideOiler
12-01-2018, 07:48 PM
New video on YouTUbe
https://www.youtube.com/watch?v=YPX1DeDw7_I
Sbeck09
12-01-2018, 09:06 PM
This is so freaking cool! Nice work. I'm like you in that I do everything myself.
So crazy that you're probably a few minutes down the road from me! If you ever need a helping hand or someone to hold a camera let me know.
ProjectSideOiler
12-02-2018, 12:15 PM
Thanks! I am CC rd & Tatum area. How close are you?
Sbeck09
12-02-2018, 10:35 PM
Not sure what CC rd is. Probably a brain fart for me.
I'm just west of Metro Center. 35th ave/Peoria.
Steve Chryssos
12-15-2018, 11:18 AM
Beautiful truck. Great attention to detail. I'm Scottsdale Rd. & Pinnacle Peak Rd
Steve
ProjectSideOiler
12-15-2018, 01:45 PM
First exit going east from 7th on 101
ProjectSideOiler
12-15-2018, 01:47 PM
Steve
Thanks!
I buy most of my fuel especially when E54+ needed from Chevron
Just south of you.
https://static1.pt-content.com/images/pt/2018/12/D967E0C1722A4EAF96BFD228B6BE5F69-1.jpg (http://smg.photobucket.com/user/CalypsoCoralBoss302/media/1966%20F100%20482/D967E0C1-722A-4EAF-96BF-D228B6BE5F69.jpg.html)
I live near this spot if you recognize it.
ProjectSideOiler
12-15-2018, 01:56 PM
https://static1.pt-content.com/images/pt/2018/12/B7C01D5F12344AF8B015981548887B66-1.jpg (http://smg.photobucket.com/user/CalypsoCoralBoss302/media/1966%20F100%20482/Basic%20Upload%20Distribution/B7C01D5F-1234-4AF8-B015-981548887B66.jpg.html)
https://static1.pt-content.com/images/pt/2018/12/816EFAA881774BA7981E623FAA8436DB-1.jpg (http://smg.photobucket.com/user/CalypsoCoralBoss302/media/1966%20F100%20482/Basic%20Upload%20Distribution/816EFAA8-8177-4BA7-981E-623FAA8436DB.jpg.html)
https://static1.pt-content.com/images/pt/2018/12/BF1513605CD144DB8EEBC9A6240D606C-1.jpg (http://smg.photobucket.com/user/CalypsoCoralBoss302/media/1966%20F100%20482/Basic%20Upload%20Distribution/BF151360-5CD1-44DB-8EEB-C9A6240D606C.jpg.html)
- - - Updated - - -
https://static1.pt-content.com/images/pt/2018/12/11443E542CD446AFA3FC0114258D2D04-1.jpg (http://smg.photobucket.com/user/CalypsoCoralBoss302/media/1966%20F100%20482/Basic%20Upload%20Distribution/11443E54-2CD4-46AF-A3FC-0114258D2D04.jpg.html)
https://static1.pt-content.com/images/pt/2018/12/AFF97BF4B2694DEBA5C008C1B473816F-1.jpg (http://smg.photobucket.com/user/CalypsoCoralBoss302/media/1966%20F100%20482/Basic%20Upload%20Distribution/AFF97BF4-B269-4DEB-A5C0-08C1B473816F.jpg.html)
ProjectSideOiler
07-16-2019, 01:15 PM
Pretty much finished it up with just a few little things left like antenna.
https://www.youtube.com/watch?v=yzBUxWvnHzU
Now building a new engine as sold the 482 FE.. Up next is a 180 opposite 410 FE. Waiting on bore n hone, balance.
ProjectSideOiler
07-16-2019, 01:23 PM
New project may not be much interest in the "truck" but some may like the Engine. All Aluminum Boss 429 based 540" but with twin turbo's. Dialed down it should make around 1500 flywheel. Parts all good to 3000 hp but injectors only good for around 2450. Should make 1500 on fairly low boost.
Engine now fitted to truck. Next up is to build the custom stainless manifolds/headers to mount the turbos.
https://static1.pt-content.com/images/pt/2019/07/A65BBBBC961742BB84AB350F44B89570-1.jpg
https://static1.pt-content.com/images/pt/2019/07/226FDC68F6D94BC19D58950B317DFF7C-1.jpg
https://static1.pt-content.com/images/pt/2019/07/12901495902C45BEAA3F69A039B1DC51-1.jpg
https://static1.pt-content.com/images/pt/2019/07/D35AFFD98E7049BDA99F96D2B87F1B03-1.jpg
- - - Updated - - -
turbo's will most likely end up about right here.
https://static1.pt-content.com/images/pt/2019/07/3507B88A646C44C08E399EA4F4BD3BC0-1.jpg
Tincup
07-17-2019, 03:26 AM
Your 66 is gorgeous, you did a great job. looking forward to see the new project.
Sbeck09
07-17-2019, 06:27 AM
OMG that new engine is a MONSTER!!! How the hell do you plan to put that power down?
blade
07-17-2019, 09:49 AM
He just has to lock it in 4lo LOL
Awesome builds!
ProjectSideOiler
09-16-2019, 11:20 PM
First time using new phone app.
So much has happened once again.
Machine shop ruined the FE block for my 410 FEbuild along with my last 2 FE blocks.
Time to start from scratch once again.
I bought a wrecked 2018 F150 with the GEN3 5.0 Coyote 10 spd from Auction but was such minimal damage I fixed it in a couple days. Long story.
After putting on 5k mi in just 3months I decided the low rpm power was just not there.
Being used to big block power and after a bunch of searching I heard rumors Ford Performance released 5 450 hp 510 TQ Raptor 3.5 crate engines. I was able to purchase engine #4!
With just a basic tune it should put down 500 HP and 550 TQ to the tires. Plan is to use the 10 spd auto and stock PCM.
ProjectSideOiler
09-16-2019, 11:29 PM
167494
167495
167496
Raptor 450/510 crate engine
ProjectSideOiler
09-16-2019, 11:31 PM
167497
The Twin Turbo 540” boss9
Header build starts this week.
ProjectSideOiler
09-16-2019, 11:33 PM
167498
The ‘18 150 5.0 I bought for engine and transmission but ended up just fixing it.
ProjectSideOiler
09-17-2019, 09:31 AM
Your 66 is gorgeous, you did a great job. looking forward to see the new project. Thanks Much!
I figured the wheel spin should stop by 100 mph just not sure what will happen when it shifts to 2nd gear! LOL
Awesome builds!
Thanks! such a zoo and so much changing on a daily basis.
ProjectSideOiler
09-17-2019, 09:40 AM
I am only 25 min from you
Sbeck09
09-17-2019, 10:45 AM
Awesome! Any time you feel like you don't have enough projects of your own come on over and you can help with mine. Haha. Or I'm always happy to help as well.
ProjectSideOiler
04-03-2020, 09:28 PM
174370174371174372
Progress on the 1 of 5 Raptor 450/510 crate engines & 10 spd auto. Engine and transmission now installed. Exhaust done. Now building a new fuel system with 45 gallon capacity.
ProjectSideOiler
01-14-2021, 11:47 PM
I am signed up for both the show and ProTouringTruckShhotout
Continuous health issues have really slowed the process but still hoping to have it on road
By then.
No clue what to expect as main purpose of truck is long distance cruising.
All stock suspension with added front sway bar plus brake upgrade.
ProjectSideOiler
01-14-2021, 11:52 PM
https://youtu.be/NYULddd6mYU
Sbeck09
01-15-2021, 07:20 AM
Glad to hear you'll be joining the fun down at Wild Horse in April! We are all going to have soooo much fun!
ProjectSideOiler
01-26-2021, 08:49 PM
I have been out of commission for nearly 4 months so not looking good on getting my truck done.
ProjectSideOiler
03-17-2021, 06:29 PM
first startup of the 1966 Raptor Powered F100!
Maybe I can make it to the Pro Touring Truck Shootout
https://www.youtube.com/watch?v=gZ4XnzQLnyQ&t=2s
