View Full Version : Low tension hood lift struts for G-body
topher455
05-18-2010, 11:43 AM
Im having trouble finding some low tension hood struts for my 86 Regal. I tried the old worn out ones but they are a bit too worn. Im not sure who made the hood since I bought it used. It 2 1/2" cowl induction and is a bolt on in the back and pin front. I called Tamraz and they said use the regular ones but VFN said use a prop rod. Well first they said use low tension struts then when I asked for a part number they put me on hold and said upon return use a prop rod. IIRC Poston enterprises used to sell some but I think they are out of business. Any suggestions? Thanks
200horse
05-18-2010, 07:54 PM
have you tried harwood?
topher455
05-19-2010, 04:32 AM
No but I will. Tks.
toxicz28
05-19-2010, 05:39 AM
'82-'84 Z-28's had an optional plastic hood. If the steel hood struts are the same p/n between the 2 cars, the low tension struts will work for you.
John Wright
Are you able to use any of these?
https://www.rvupgradestore.com/detail_JR-BNGS__145.html
topher455
05-19-2010, 07:59 AM
Hmm I'll check out the z28 thing. The rv store ones all seem to use the ball stud whereas mine bolt on. Im sure I can find some ballstuds if necessary though. I like that they list the weight though.
John Wright
05-19-2010, 08:01 AM
Need ball studs?...or ball stud brackets?
https://www.rvupgradestore.com/items_145__gas%20strut,%20gas%20spring,%20pnuemati c%20spring,%20pnuematic%20strut.html
topher455
05-19-2010, 08:04 AM
Sweet!! Thanks for the help!!!
