JRouche
05-18-2010, 08:21 AM
I have my front end all built now and need to align it. It has such a variety of parts that taking it to an alignment shop is outta the question. So I looked into some of the caster/camber gauges available. There are alot out there. They are simple and not too expensive. But most of them work with wheels that have a lip to capture the arms. My wheels dont have a lip. So I was gonna have to make one for my wheels. I though about making one that would set on the spokes of the wheels. That was gonna be my first choice. Then I saw a hub mounted one from Longacre.
https://static1.pt-content.com/images/pt/2010/05/LA-1.jpg
That looked like the sweet setup. Theirs is a magnet mounted one. No good for me, I have all aluminum. But I saw that my Wilwood brake hubs have a threaded cap and hub. Perfect!!! So the measuring and building began...
Oh, and their setup is just a toe gauge, but you can buy an adapter to use it with their digital camber/caster gauge. I had a couple of new SPI digital protractors hanging around waiting for a use. So here is the use. Long thread and many large pictures.
So it started out with me measuring the thread of the brake hub cap. Once that was set I needed to make an adapter for the hub. All the stock used was on hand so I didnt make it as custom as it could be, just using material that was on the shelf in my house garage. And its just a tool, not jewelry :)
I needed alot of clearance on the inside of the thread to clear the castle nut and spindle. So alot of aluminum got hogged out.
Why the spacers? Back to material on hand. I happened to have a 2" bar that when split in half was just too short to clear the sidewall of the tires. So spacers were needed.
https://static1.pt-content.com/images/pt/2010/05/a1-1.jpg
Next was a housing for the digital protractors. There are alot of ways to do it. I do have a cnc milling machine. But to be honest, Im still learning to draw parts up in the cad program and Im not all that proficient. So welding up a box was an option. And again, welding aluminum is new to me. So I needed the practice. Glad I did. I need to get used to welding aluminum. Steel is so different and Im comfortable TIG welding steel, time to branch out.
So I cut some plates of aluminum and clamped them up for welding. The beads weren't too bad. I HATE grinding welds down, it shows that the weld wasn't very nice. Well you get the idea, I ground down my welds LOL
https://static1.pt-content.com/images/pt/2010/05/b1-1.jpg
https://static1.pt-content.com/images/pt/2010/05/c1-1.jpg
Next was the vertical bars for the toe gauge. Simple cutting, drilling and sanding.
https://static1.pt-content.com/images/pt/2010/05/d1-1.jpg
The lower cross bars for the toe gauge. My car has 26" diameter tires so the lower bars are 26" long for proper toe setup.
https://static1.pt-content.com/images/pt/2010/05/e1-1.jpg
All the bits and pieces done.
https://static1.pt-content.com/images/pt/2010/05/f1-1.jpg
This is how the protractors or digital levels set in the boxes. They are captured by small set screws that align with the Vee on the body of them. Keeps them from flopping out. The reference plane that is tight to the vertical plane is the bottom of the box. When I welded the box up I made sure the upper and lower plates of the box were perfectly square with the end plate that mates to the round spacer.
https://static1.pt-content.com/images/pt/2010/05/g1-1.jpg
Then when assembled off the car this is what the whole thing looks like.
https://static1.pt-content.com/images/pt/2010/05/h1-1.jpg
To mount it to the car the spud goes on first.
https://static1.pt-content.com/images/pt/2010/05/i1-1.jpg
Then the 3/4" bolt is put into the box before the protractor and thread the entire assembly to the car.
Why a large 3/4" bolt? Nuther screw up. When I was boring the threaded side of the spud I ran the drill bit all the way through. Knowing I would need a hole for the connector bolt. But dummy me, I went a couple sizes too large for what I needed. I was hogging out the OD threaded side and didnt want to have to bore alot. So I used a large drill bit to remove a major portion of material. I should have stopped at the major depth on the OD thread side and kept the other sides hole smaller to tap it for a 1/2" bolt. No loss for me. But just shows planning actually works. I didnt draw it up or plan it. I just went to town cutting metal.. Just showing, it is ALWAYS a good idea to put yer build on paper.
https://static1.pt-content.com/images/pt/2010/05/j1-1.jpg
https://static1.pt-content.com/images/pt/2010/05/k1-1.jpg
Ok... Now the sweet part of this rig. The toe measuring. Thats why I made two of these fixtures. Hook a tape on the right side of the car and measure the left side. Its really nice. The lines are sharp enough that you can get a toe reading to within a 1/32" if you need to. And the lower arms dont flex during measuring. Its pretty stout.
https://static1.pt-content.com/images/pt/2010/05/m1-1.jpg
https://static1.pt-content.com/images/pt/2010/05/l1-1.jpg
https://static1.pt-content.com/images/pt/2010/05/n1-1.jpg
So Im gonna go ahead and do an alignment. You see the turn plates under there. They are a must IMO. Those are full floaters. Meaning they will slide fore and aft and in and out (sideways) along with rotation all on a BIG bearing. Some Bear plates I picked up on the cheap.
Anyway, this alignment tool can be made by anyone with some simple tools. And even easier if you have a lipped wheel. No need to go with a hub mount. Hope you enjoy the pics as much as I enjoyed making this tool. JR
