View Full Version : 70 Chevelle 4 wheel Drum to Disk Brake Kit Suggestions?
Bigmanz
05-09-2010, 04:51 PM
Building a 70 Chevelle and would like to know if there are any kits out there for converting from drum to disk brakes on all 4 wheels?
L & H Kustoms
05-10-2010, 08:36 PM
There are alot of 4 wheel disc kits available and they all differ on budget ans style. I am a dealer for Baer brakes and Wilwood. I can save you alot of $ on either. PM me or give me a call and we can discuss your options.
1badchevelle
05-10-2010, 09:16 PM
call Tobin @ Kore3
http://www.kore3.com/
ProdigyCustoms
05-11-2010, 04:15 AM
No one has our Prodigy Customs Total Car G Machine Brake Packages.
More information here
https://www.pro-touring.com/forum/showthread.php?t=62697&highlight=wilwood
brans72
05-11-2010, 05:05 PM
Whats that kit run pictured Frank?
ProdigyCustoms
05-11-2010, 05:16 PM
Base kit is only $1800 and includes the polished master, not the Corvette master in the pic.
Add red calipers and polished stainless booster and you add $400, so $2200!
FREE POLISHED OR BLACK WILWOOD TANDEM MASTER UPGRADE, $200 VALUE IN OUR KITS. THIS IS the $239 POLISHED OR BLACK MASTER CYLINDER!
POLSIHED
BLACK
brans72
05-11-2010, 05:22 PM
not a bad price!
raustinss
05-21-2010, 06:45 PM
Hey I got a 70 SS I did a cheap stock set up til money comes for a Kore 3 set up . the back uses 77-79 seville (with disc option). Brackets and calipers. The rotors can be used but they have a 5-5 bolt pattern . 79-81 firebird ws-6 rear rotors fit and have a 43/4-5 bolt pattern . The caddy calipers also have a rear park brake built in which is awesome if you have a stick. For the fronts use a "big bearing" B body spindle 77-89 . Use 70-76 F body calipers and 70-74 master cylinder. Use 88-92 camaro 1LE rotors (GM 18016035). Other then neding global west or other tubular upper a arms you will also need a wilwood pn260-2220.proportioning valve. And enjoy stock cheap 12" discs. A lot of other aftermarket companies use their own version of this . If you can afford it get kore 3 they use c5-c6 brakes which can range in size from 12-13-14 then do it . Stock stuff is nice because if there is ever a problem its easy to get parts or replacements. Any questions email me
[email protected]
good luck Ryan Austin
1BAGTO
06-02-2010, 12:13 PM
I have a 1970 GTO and have Baer 4 wheel discs, I haven't had any problems. The Prodigy Customs kit seems like a great buy though.
