View Full Version : More sidewall
critter
05-05-2010, 06:42 PM
I have 255/35/18 KDW2 tires on the front of my car and would like to have more sidewall on thoses front tires. How much do I gain by going to a 40 aspect ratio?
MCMLXIX
05-05-2010, 07:04 PM
go here: click on SPECS tab...
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+T%2FA+KDW+2
looks about 1" total diameter so maybe 1/2" taller....
FatfreeGTO
05-05-2010, 10:47 PM
This is off the top of my head but I think the math is right.
255/35/18 means 255mm wide tread / 35% sidewall of your tread / in an 18 wheel
Take your 255mm (treadwidth in mm) divide by 25.6 (converts mm to inches) 255/25.6 = 9.96" of tread width
9.96" x .35 (35% of treadwidth) 9.96 x .35= 3.486" of side wall your 40 series will equal 9.96 x .40 =3.984" of sidewall. So yes MCMLXIX its a 1/2" taller sidewall. Hope this helps.
MonzaRacer
05-06-2010, 12:29 AM
235/35/18 section width 9.3 shoulder height 3.2 OD 24.5
235/40/18 section width 9.3 shoulder height 3.7 OD 25.4
235/45/18 " " 9.3 " " 4.2 OD 26.3
235/50/18 " " 9.3 " " 4.6 OD 27.3
Now dont forget taller tire=larger foot print also. Added a few extra sizes for your use.
critter
05-06-2010, 02:37 AM
You folks are great. Thanks for the help.
LSx_88_Ciera
05-06-2010, 04:45 AM
Everything is correct other than 1" is 25.4mm not 25.6.
buickfunnycar.com
05-06-2010, 07:39 AM
compare here too as well...:smoke:
http://www.1010tires.com/tiresizecalculator.asp
FatfreeGTO
05-06-2010, 08:01 AM
Ahh damn I was close and it was late :)
AintQik
05-06-2010, 01:03 PM
I always use this one.
http://www.miata.net/garage/tirecalc.html
Samckitt
05-06-2010, 01:10 PM
The middle number is the number used for the sidwall height calculation. The sidewall height is figured by using this as a percentage of cross sectional width. For example, 255 width, 255X35% is the sidewall width.
255X35%=89.25mm or 3.5"
255X40%=102mm or 4"
DriverzInc
05-07-2010, 12:53 PM
255X40%=102mm or 4"
Exactly right!
