CamaroAJ
05-05-2010, 04:20 AM
have the whole car bolted and sheet metal screwed together and looks good. before i go and weld this thing together i would like to get the tram gauge out and double check all the measurements with the factory ones. does anyone have the measurements for all the rear sheet metal, roof hights and for square? the oldest i can find here at the shop is 1981. kinda need these today if at all possible.
Jim Nilsen
05-06-2010, 08:46 PM
you can still check them and see how they come out. If it looks good and they seem to all be within +- 1/8 you are as good as stock.
I always worried about getting it right and then I discovered the laser level and it made it easy to see if it was level in its own plane and when it was level it was right on, if the parts are not in the same level plane for the body lines you will notice it everywhere else.
If it looks good , weld it !!!
