View Full Version : Write-up on C5/Z06 brake conversion on 1st gen?
elitecustombody
05-02-2010, 02:54 PM
Hey guys, tried searching for instructions and tips how to convert drum brakes to a set of C5 brakes ,
Should I buy a generic disc brake conversion first and then upgrade rotors and calipers? Would that eliminate the hassle of dealing with machining,pulling axles and replacing studs ?
Thanks.
brans72
05-02-2010, 04:03 PM
I just bought a set of turned down front hubs for my chevelle and got the Kore3 Bracket for the C5 caliper and then got a set of Brackets made for rear ($10.00) Test mule here and they fit perfect. I measure rear axle flange area where studs go and they fit the specs for the rotors. I have yet to tst package cause car is getting body work etc but so far so good. I would talk to Tobin from Kore3 if you want the true facts!
Chad-1stGen
05-02-2010, 04:39 PM
Here is a nice writeup for you
https://www.pro-touring.com/forum/showthread.php?t=61780&highlight=brakes+pete
elitecustombody
05-02-2010, 05:46 PM
Thank you,sir.I guess I didn't search hard enough
MonzaRacer
05-02-2010, 05:51 PM
yep kore3.com
Tobin IS the man!
05-03-2010, 12:54 PM
for the rear
https://www.pro-touring.com/forum/showthread.php?t=65112&page=2
https://www.pro-touring.com/forum/showthread.php?t=60029&page=2
be prepared that you might have to space the rear disc backing plate to center the caliper properly. Some cars took 3/16" and a few went with a 1/4" spacer. the guy in the last link said he did not require a spacer at all.
Vince
