View Full Version : 2010 Camaro Brembo front brakes?
Samckitt
05-02-2010, 11:10 AM
What size are the discs, # of pistons in the calipers? Are the worth looking into to upgrade over C5 brakes.
Rick D
05-02-2010, 11:31 AM
Do a serch it has been beat down a few times. If I remember the out come is you need like 22" rims or something like that. It's because of the way thar the calipers mount.
CamaroAJ
05-02-2010, 02:55 PM
and they are 6 lug rotors that weigh a ton.
1badchevelle
05-02-2010, 03:29 PM
wonder if someone make a bracket to fit my escalade.
Samckitt
05-02-2010, 03:47 PM
They are the 5 lug version.
realsquash
05-21-2010, 01:30 PM
5x120mm bolt pattern, 14" diameter, 4-piston Brembo calipers...
Andy
ryeguy2006a
05-21-2010, 07:38 PM
Hey at least the BMW Rims will fit properly.
realsquash
05-22-2010, 08:17 AM
As long as the rotor is centered on the hub you could drill the holes out to run a 5x4.75" pattern, or they might be oversized enough already since they run a 14mm stud on the Camaro. 120mm is 4.724".
Andy
durrettcustoms
08-31-2010, 05:48 PM
Anyone know if these can be made to fit 1969 camaro?! Ive searched the forum for a while and cant find anything.
durrettcustoms
11-10-2010, 08:34 PM
Anyone!!! I almost responded to my own question above!!!
robertjra
11-10-2010, 09:57 PM
the new camaro is not 6 lug it is 5 lug 5-120 and you can fit a 19" wheel if the off set is right
CreepinDeth
11-11-2010, 12:58 AM
Regarding the 5th gen Camaro,
A magazine did a write up on taking the 20" rims and big brakes off,
and going with IIRC 4th gen brakes and 17" rims.
Of course I don't think you'll see much advertising of this.
Bonzohansen on Nastyz28 found it and posted it.
It was .2 sec faster in the 1/4 because it shed something like 200lbs.
wrkcar
11-12-2010, 05:42 PM
Check out this link http://www.lateral-g.net/forums/showthread.php4?t=29304 he has first gen CTS-V Brembos on a first gen Camaro. First gen Cts-v and 10 Camaro Brembos calipers are the same.
durrettcustoms
11-15-2010, 04:24 PM
Thanks but he changed his rear end to a 8.5" Im using the stock 12 bolt!
BonzoHansen
11-15-2010, 06:26 PM
the ends are the same, no?
Apogee
11-17-2010, 06:45 AM
The housing ends for the early 8.2/8.5 10-bolts and 12-bolt c-clip passenger car housings are the same.
As for the link to Nick's build above, he appears to be running the CTS-V calipers on a 355mm C6 Z06 rotor. This is something commonly done on the LS1 F-body applications since it's a direct bolt-on deal for those knuckles, so pressumably you could bolt them up using LS1 conversion brackets or some derivative thereof. That said, the CTS-V radial pad height is 60mm [2.362"] and the C6 Z06 rotor annulus width is 52mm [2.047"], so until someone explains to me how running an 8mm pad to rotor mismatch is a good idea, we'll stay away from that type of setup. That Brembo caliper really does require a wide annulus rotor and just because it can be run on a medium annulus rotor like the C6 Z06, doesn't necessarily mean it should IMHO.
Tobin
KORE3
JanneM
11-25-2010, 11:47 AM
First gen camaro with 2010 brembo front brakes 14" rotos and 18" wheels
https://www.pro-touring.com/attachment.php?attachmentid=42474&d=1290707068
https://www.pro-touring.com/attachment.php?attachmentid=42475&d=1290708415
wrkcar
11-25-2010, 10:50 PM
Can you give us some info on your setup?
JanneM
11-26-2010, 03:46 AM
Parts i used in my project:
First gen camaro drum brake spindles and hubs. spindle upper backing plate mount must be machined same lavel as lowers.
2010 camaro rotors and calibers. Rotor center hole must be machined 2,782"
Wheel studs 1/2"
Caliber brackets are self made.
wrkcar
11-28-2010, 12:29 PM
Can you post pictures of your brackets
JanneM
11-30-2010, 12:08 AM
Picture of brake caliper bracket, this is only hand made model.
Final brackets will be lasercut models
