View Full Version : too much oil?
GRNOVA
05-02-2010, 09:33 AM
Is there suppose to be this much oil on the intake and under the blower? I did find the gasket on the blow off valve was half way missing? Would this cause this also where is the oil coming from? Click on pic for slideshow
https://static1.pt-content.com/images/noimg.gif (http://s300.photobucket.com/albums/nn13/tnt342/65%20nova/?action=view¤t=47d0b91c.pbw)
fishtail8
05-02-2010, 05:13 PM
Where are you running your PCV setup to? The carb?
GRNOVA
05-02-2010, 05:23 PM
I am running it to a vacuum pump and out of the pump to a breather can. Before it was right out of carb. Just added vacuum pump!
fishtail8
05-02-2010, 05:36 PM
What it could have been doing is sucking oil out of the valve cover. If there isn't much of a baffle inside the cover, it is possible to get a fair bit of oil out of the cover. I ended up putting a restrictor in my PCV hose. It seemed to help my issue. Yours seems similar, maybe someone else will chime in with either a yay or nay.
Bet that car snorts eh?
GRNOVA
05-03-2010, 02:43 AM
I am going to look into the baffles today, might need to add better ones.
GRNOVA
05-03-2010, 06:50 PM
Well the valve cover at the PCV had no baffle but at the breather there was one so I switched the valve cover around and now the baffle is under the PCV. I am running Shogun breathers so there is a check ball inside the breather. Lets see if this change helps.
GRNOVA
05-04-2010, 03:33 PM
Do I have to eliminate the breather on the breather can when I run a vacuum pump. Does the system have to be completely sealed?
GRNOVA
05-18-2010, 02:57 PM
Don't think I need the vacuum pump any longer. I Took the car in last Friday to see if they could figure out the excessive oil leaks since I have tried everything I know (which I am finding out is not as much as I thought when I comes to engines!!)Today, I got a call from the speed shop about the rings being shot. He said this is causing pressure in the crankcase, which was forcing oil out of every gasket. What a bummer I'm just trying to get the car ready for MMC and all this s**** keeps happening. Now I need to line hone and re ring the block in 1.5 weeks. Just waiting on the price. Maybe someone is trying to tell me something????:seizure::seizure::seizure::seizure:
