View Full Version : Baer Brakes
notagn
05-01-2010, 08:03 PM
Thinking about buying the Baer rear disk serious street kit. Is it a good working kit? Has to be better than rear drums right? I am leaning toward this kit since it seam to be aboout the smallest rear disk setup.
notagn
05-04-2010, 11:02 AM
Nice catch, I have done the same work to the front of my car as well with my 83 just finished up a 9'' install on the rear except the brakes of course. This will be my first year out with a 421 small block with a procharger about 15 to 18 lbs of bost and a frame notch. Just a little excited to get out!!!!!!
Apogee
05-04-2010, 01:07 PM
I don't know what the Baer kit you're looking at costs, but you might also want to consider the Ford Explorer/SVO kit with the internal parking brake. You may have to redrill the rotors for the 5x4.75 wheel pattern, but that's not too difficult. I'm fairly certain it fits inside a 15" wheel as I assume you're wanting to run drag radials, hence the desire for the smallest rear disc kit possible?
Tobin
KORE3
notagn
05-06-2010, 06:20 PM
yes that is the reason for the small kit. Thanks for the reply but the baer kit is on the way. Fingers are crossed!!!!!!
notagn
05-08-2010, 06:39 AM
thats nice to Know I hear the wilwood kits brake kit is not the best for the parking brake.
ryeguy2006a
05-21-2010, 07:41 PM
You should just go with the LS1 rear brakes, much cheaper than baer, plus you can keep you ebrake. 2 cents
