View Full Version : seam sealer and body panel adhesive? on brands
brans72
04-28-2010, 12:15 PM
I ran by the autobody suppy shop today to do some looking what I could buy local. They had some 3M seam sealer called fit fast I believe and 3 different body panel adhesives one was a 3M,other 2 where Speed Grip and Duramix. I was wondering if anyone here could help me out on which ones to buy. Thanks Brandon
minendrews68
04-28-2010, 12:55 PM
I like the 3M panel adhesive really works great, I believe it's 8115.
Carl
brans72
04-28-2010, 01:11 PM
Yeah worth the like 35 bucks? Figured buy local save on shiping not to mention get it that day!
dhutton
04-28-2010, 04:16 PM
I've also used the 3M 8115 with good results. I also use their two part seam sealers. They have thick bodied one and a self leveling one. The gun can be expensive but they have a lower cost one at autobodytoolmart.com
rrstroker71
04-28-2010, 05:07 PM
We use the Kent products, there self leveling seam sealers are great and thier adhesive system works better than the 3M they have a 5 minute, 15 minute and 45 minute set.
brans72
04-28-2010, 05:23 PM
Kent huh maybe I need to do some local checking on them got any product #'s you have used? Brandon
rrstroker71
04-29-2010, 04:03 AM
Flex-E-6000 seam sealer, Part#
P-10491
Panel Adhesive/sealer
P-10638
We use the Flexible foam part # 8463 to replace the factory material between hood panel/ bracing Roof panel to roof braces between quarters and wheel houses etc. It works good as a anti rattle and sealer. It also does not dry hard. it stays flexible and repells water
brans72
04-29-2010, 05:41 AM
dang I need to find a gun to borrow from someone or rent it for a short period of time.
LSx_88_Ciera
04-29-2010, 05:51 AM
In the body shop I worked we used Fusor for adhesive and 3M for seam sealer.
As a test we took 2 1sq foot pieces of patch panel and bonded them together with a 1" overlap then clamped them up in the frame rack and pulled them apart. Fusor was the only one that the metal ripped before the bond separated.
200horse
04-29-2010, 06:46 AM
international epoxies and sealers (IES) is another great brand. There tubes are a full 10 onces not 7. Price is aound $ 35 a tube great stuff
