View Full Version : Need Help,Throttle Cable Set Up For 4150
Gitter Dun
04-27-2010, 08:41 PM
I cant find any pictures of a killer throttle cable setup. And what throttle pedal
CarlC
04-28-2010, 05:04 AM
The Lokar cable and a six-cylinder throttle linkage works quite well.
ZZ430
04-28-2010, 05:35 AM
I like to use the 24" Lokar cable, bracket and and universal pedal.
https://static1.pt-content.com/images/pt/2010/04/4438082045_71ce1ed4e6_o-1.jpg
https://static1.pt-content.com/images/pt/2010/04/4461247038_9686a092d0_o-1.jpg
Another pretty cool setup is the Jegs bracket.
https://static1.pt-content.com/images/pt/2010/04/4458892376_baccfcb471_o-1.jpg
https://static1.pt-content.com/images/pt/2010/04/4458119463_0a22c71ed3_o-1.jpg
Gitter Dun
04-28-2010, 10:51 AM
Awesome guys thanks, need to order something today, that 24" lokar set up looks cool.
cheapthrillz
04-28-2010, 11:14 AM
CSR makes a good looking bracket too....
Vegas69
04-28-2010, 11:35 AM
Do yourself a favor and don't use the lokar bracket. You're a racer like me. It won't hold up to the constant full throttle blasts. I had one for about 1500 miles and I lost full throttle multiple times. The little stud that keeps it stationary bent. I ended up using my Lokar cable and an AED bracket much like the Jegs bracket above. Dual throttle return springs and bullet proof performance on the track.
MonzaRacer
04-30-2010, 05:35 AM
Strange Ihave never had any issues with Lokar, nor any of the chinese made stuff ffrom any other company.
Vegas69
04-30-2010, 06:46 AM
I beat my junk pretty hard...
cheapthrillz
04-30-2010, 06:53 AM
:bsjerk:
Vegas69
04-30-2010, 07:29 AM
Let's hear your expert opinion. Gaetano is a road racer not a show tourer. LOL Do you have a problem with me sharing my experience with a inferior part for the race track? Please enlighten me to your wisdom.
Gitter Dun
04-30-2010, 12:50 PM
Dam, that Lokar stuff showed up yesterday and I un-packaged it!! Oh well, Back to the Summit catalog. Well at least I could still use the cable. Thanks Vegas69.
Vegas69
04-30-2010, 04:00 PM
Summit will take anything back! Make sure not to cut the cable until you install your new bracket. They are in completely different locations. I have a 1.5 -2 inch drop base.(can't remember) I had to shave the cable housing knob to clear the air cleaner. Plan on using the big top hole on your throttle lever. It makes for a long/easy throttle. Anything below that will make for a shorter/hard throttle. (maybe you'll like it but I didn't) I couldn't feel the secondaries and full throttle like I wanted. Then you can adjust your spring tension to your liking. Really is the hot set up for a reliable good feeling throttle.
Gitter Dun
04-30-2010, 06:19 PM
Sweet, Thanks. I pushed my motor back to May 17th for delivery since my headers aren't showing up until the 18th so I have time.
Then its Buttonwillow on June 5th-6th and Spectre341 Challenge on the 25th-26th
Flying to Indiana on the 13th to witness and document the dyno session.
