View Full Version : Here is my Cam/Engine Specs any recommendations for improvements?
obengston
04-23-2010, 08:23 AM
I wanted to give my engine specs and see if anyone had any recommendations to improve the performance/HP. I added alot of info on the car was not forsure. I know there are so many performance guys on this site that you sometimes need info to evaluate. I was told I should be around 500 HP fly wheel?? But is there something here that is worth taking a look at? I would like to eventually put a pro charger on it or even NOS. Please give me your recommendations and opinions. I would like to run the 1/4 in the 11's Thanks Oscar
Engine is SBC 383 with the following.
1. Heads dart pro 1 aluminum 215 64cc / behive springs / 7/16 studs / Intake – Exhaust 2.05 – 1.60VJ Comp Retainers / 150 seat pressure / Spring Hgt 1.750 Harland Sharp Roller Rocker 1.5
2. Custom Ground Hydraulic Roller Comp Cam:
Gross Valve Lift Intake: .570 Exhaust: .574
Duration @ .006 Tappet Lift: INT: 289 EXH: 306
Open Closed
Valve Timing @ .50” Lift: INT: 12BTDC 44 ABDC
EXH: 50 BTDC 14 ATDC
These specs are for cam installed at 106.0 Intake Centerline
Duration @ .50 INT: .236 EXH: .245
Lobe Lift INT: .3800 EXH: .3830
Lobe Separation: 107.5
3. Intake Open plenum Professional Product "Hurrican"
4. 30 over Mahlie forged flat top pistons
5. Carburetor: AED HO (Holley) 750HO
6. Dynatech ceramic coated 1 3/4 stepped to 1 7/8 / 3" SS dual exhaust
7. Distributor: MSD Pro-Billet GM HEI w/MSD 6AL
8. Compression ?? 10-8
9. Rear end Moser 12 bolt with posi 373 / 17 crager / 275/50 rear /caltracs /
10. tranny Turbo 350 w/3500 stall
11. electric fan
Lowend
04-23-2010, 12:23 PM
That's a pretty good match-up. I would tend to widen out the lobe seperation on the cam a little - probably more in the 110-112 Range. The 108LS you are sporting now is going to have a REALLY nasty idle and probably be a bit sluggish off the line.
I would say that if you are really wanting to do a supercharger, than the compression needs to come down to sub 9.5-1 But you can always swap to larger chamber heads later to do that.
Don't run the MSD HEI, you are better off with a small cap Pro-Billet Distributor like the 85551. Run an 8207 E-Core coil
Pro Stock
04-23-2010, 12:32 PM
Ditto except for the MSD, if you already have it keep it, if not either brand will work fine. Depending on what kind of rear tire that you run you should be able to run high elevens.
Dale
obengston
04-23-2010, 12:42 PM
Sounds good. I already have this set-up. As far as the HEI whats the benefit to the other set-up. Funny you mentioned it, because I was thinking about changing to a smaller one (clearance issues), but I did'nt know there was a benefit to it. The engine runs good pretty responsive was just thinking there might be something I'm overlooking. With like the cam set-up compared to my heads ect or something that would give it more. I know know that my compression is high to go procharger, but I was thinking I could get away with 5-6 psi. As far a NOS I have read that the 10-8 I would be okay. But again I'm pretty new to the performance part. One of the reasons I'm turning to you guys to evaluate my set-up. Also with what I have would it benifit me to use 1.6 roller rockers vs my 1.5. I also have seen people run both 1.5/ and 1.6??
obengston
04-23-2010, 12:44 PM
Dale, I see you say I should be able to run high 11's thats good news to me. I will get what ever set it takes, any suggestions?
Pro Stock
04-23-2010, 07:11 PM
I would go ahead and buy the 1.6 to 1 rockers, check piston to valve clearance before you run them, different ratios are a great way to fine tune your cam to your combination. Start out by trying the 1.6's on the intake with the 1.5's on the exhaust then try this in reverse and then run the 1.6's straight across and see which combo runs the best, The best way to do this would be on a chassis dyno, if you don't have access or the $$ then you will have to go to the dragstrip or use seat of the pants method.
Dale
Lowend
04-23-2010, 09:34 PM
If you already have the HEI - than keep it. I would consider moving the coil off of the distributor cap to help with heat saturation.
In my experience 1.6 rockers by themselves won't buy you anything but potential valvetrain problems, that thing's already throwing the valves up near .600 and that's more than enough.
I'd say, save the ProCharger money; with that kind of compression you are already somewhat pushing your luck with pump-gas. The combo is pretty solid, go drive it.
If you really want to spend some cash, consider a F/I conversion and dyno tuning
obengston
04-24-2010, 05:35 AM
All sounds good. I so soaking in all this good info. Hopefully it will help guide me on my next plan of action. As with all this its never enough. LOL Especially when I have a son that has a fox body mustang that I just can't allow him to stay ahead of me. LOL
Scott Parkhurst
04-24-2010, 08:41 AM
I'd second the cam suggestion and also recommend an Air Gap to fatten up the bottom end and midrange..!
