View Full Version : Guldstrand mod... how accurate??
BuddyP
04-29-2005, 07:56 PM
Dumb question here... How accurate do the holes need to be? Basically here's what happened. I layed the templates out on the subframe, got all the pilot holes drilled and when I was all set and done, my left front holes is .060" higher than the Right front hole. So, do I weld in that hole and redrill? Can I get away with ovaling it? Basically did I F- up majorly or will a full alignment take care of it being out of wack? Didn't know how accurate the original holes were to begin with.
Buddy P
04-29-2005, 11:06 PM
I wouldn't worry about it.
I don't know how accurate the GM subs were built.
Don't oval the hole if it is at the finished size now. If you need to file a little to make the bolt fit, then you can file the lower side a little to correct it.
BuddyP
04-30-2005, 05:31 AM
Well, they are drilled right at .437 right now and I guess stock was .440 or .444. So it only leaves me a few thousands to file. Didn't know it it'd throw caster off too much or not.
Thanks, I feel a little better
