View Full Version : Foil Bubble Insulation
Wicked
04-19-2010, 05:08 AM
So I had a guy come by and give me a free estimate on some outrageously expensive gutters for my house. In return I received a hot water heater blanket for each of my two hot water heaters.
The stuff is like bubble wrap covered in polished aluminum foil.
My guess is it works better for heat than sound and will would work better in lower temperature application(i.e. not the center tunnel near the exhaust).
I did a search(hard to search for) and found one guy using in his headliner.
Is anyone else using this kind of product?
I was thinking door panels, behind interior trim(a, b, and c pillars)and under carpet under seats(where feet will not crush the bubbles).
What do you guys think?
Brad
WEAVER
04-19-2010, 05:49 AM
It will not keep sound down and the heat factor sucks,Don't use it for cars. When we have pulled out older interiors from the tweed days I see it in the cars all flattened out.
Wicked
04-20-2010, 08:11 AM
10-4.
Thanks.
Joker69Camaro
04-20-2010, 09:42 AM
x2 used it on the camaro's headliner about 9 years ago, It will be completely replaced with dynaliner when the time comes.
