View Full Version : Thinking about taking the leap to a 6.0L LQ engine
Taylor1969
04-16-2010, 01:00 PM
Hey all,
Thinking about ditching my current SBC 383/LS1 T56 Combo in favor of an LS based engine.
I have started compiling a list of parts needed for the swap... what am I missing?
ATS Motor Mounts 140
ATS Crossmember 349
Dynatech Headers 400
Engine 800
Cam 600
Oil Pan 400
Flywheel/Clutch 1000
Intake/Ignition 649
Other 400
Alternator bracket 167
Chris
TnBlkC230WZ
04-17-2010, 02:12 PM
If you already have the T-56 installed, why do you need a new crossmember? The position of the transmission shouldn't move.
GM now sells an LS oil pan for 60's - 70's muscle cars. It is only $136 at the CrateEngineDepot and it includes the pan, windage tray, mounting hardware and dipstick.
camcojb
04-17-2010, 06:08 PM
it probably will, mine did with ATS mounts. It moved forward which required me to lengthen the driveshaft 1-1.25" also. There was no way to move the engine further back either, the rear of the passenger head was less than an inch from the firewall.
Jody
dhutton
04-18-2010, 04:16 AM
That is the LH8 Hummer pan and it sits way too low in a first gen F body. There is a guy on ebay selling a nice cast factory style conversion pan that will work well. It is a little pricey but given how much he must have spent on tooling it is a fair deal.
Don't forget you will need an EFI compatible gas tank with pump and pressure regulator etc.
SatisTraction
04-19-2010, 07:09 AM
1st of all you need to make sure that ATS mounts will work with the dyna tech headers. i suggest buying whatever mounts work with your headers.
ats mounts are made for ats headers with rack and pinion steering.
93Polo
04-19-2010, 07:55 AM
Ron at Vengeance on Ls1tech had a Autokraft aluminum pan for sale in the Southern Section classifieds. It may save you some money.
93Polo
04-19-2010, 07:57 AM
Does the pan have any baffling for oil control? The autokraft pan has 4 trap doors in the sump for oil control.
dhutton
04-19-2010, 08:56 AM
I think ATS mounts and headers are set up for the Lee box (or any first gen box), not rack and pinion.
Don
Taylor1969
04-20-2010, 05:44 AM
Don
Yep - someone on here was using the exact setup and that is what pushed me there... that and the new dynatech pricing ($400 for coated headers).
bijanmaleki
04-28-2010, 07:00 PM
Driveshaft, fuel pump, etc. You going carbed?
94SNGLTURBO
04-29-2010, 04:07 AM
you will need the wiring hanress, if your doing a/c a sanden compressor,
