View Full Version : Shocks bottoming out or?
Steelrat
04-15-2010, 05:27 PM
On my 70 Nova I thought it was my Slide A Links causing the banging bottoming out feeling on bumps, bridge transitions, and even the occasional manhole covers. I removed the slide a links and still have the same issue. How do I tell if the shocks are bottoming out or if they are topping out, meaning they dont extend enough and cause the bang?
Thanks.
fordsbyjay
04-15-2010, 05:47 PM
Is it hitting the bump stop? To check the shocks put a zip tie on the shaft and when the shock compresses it will slide up to how ever much it compresses.
JRouche
04-15-2010, 08:46 PM
Thats one of the better tips to check shock travel. Cinch the tie wrap down tight and go for a ride. Then take a looksee. Cheap, and easy. Good tip. JR
Bryce
04-16-2010, 11:06 AM
can you measure the shock travel to full compression. if so, compare that to the distance to the bump stop. You should hit the bumpstop first and compress maybe 3/4" before the shock bottoms out.
you can always figure out a way to lower the bumpstop so you make contact sooner so nothing else is bottoming out.
