View Full Version : Autocrossing Pontiac - need oil accumulator?
Aguila1
04-13-2010, 05:34 AM
I'm planning to enter '79 TA autocrossing at an SCCA event for the first time. Should I run an oil accumulator, as Moroso or Canton makes? Or is this a non-issue on a short course? I run Castrol Syntec in my warmed-over Pontiac 455, stock oil pan. The car handles much better than stock with stiffer springs, big swaybars and poly mounts; but I only run on 245 BF Goodrich Radial TAs on the stock 15x8 wheels. Should I just keep an eye on the oil pressure gauge? I've driven the car hard in the mountains and have not detected excess wear in oil analysis.
Vegas69
04-13-2010, 05:42 AM
Road racing is where you may encounter problems. I doubt you have to many in autocross. Take it out to a parking lot with a passenger and simulate an autocross while they watch the gauge.
Lowend
04-13-2010, 06:13 PM
Those tires, I doubt you'll be able to generate the sustained G's to really cause a problem.
You are much more likely to have an EVAC issue where you barf oil out of the valve cover.
That said, an accumulator is rarely a bad thing
Pro Stock
04-15-2010, 12:15 AM
Ditto on the accumulator not being a bad thing, it's great insurance and a great way to pre-oil your engine before start up
Dale
Roadrage David
05-06-2010, 10:20 AM
Altho im going to use a oil acumulator it in my new engine configuration for my 68 firebird. i resendly did a 25 min road race going full out on a former F1 track and the oil presure never dropt. i have the Milowdon 7quarts oil pan with the windage tray pacage. on my 461 ci cvms injun engine... I do run a Star mashine evac vacume pump with internal bijpas, works great!!!!!!!!!!
Scott Parkhurst
05-07-2010, 12:44 PM
Check out Canton's road race pan for Pontiacs. I used one on my 601 and it fit great. I never got the rest of the car together, but that pan was trick!
Tom Welch
05-08-2010, 04:42 PM
Use the Canton roadrace pan, it has the internal baffles and trap doors to keep the oil around the pickup, the stock pan will allow oil to get away from the pickup on fast right hand turns.
