View Full Version : Underbody problems !!!
Olav
04-11-2010, 12:57 AM
When I started on my car I sand blastered it, zink, primer and black epoxy paint. Now the epoxy is peeling of so I have to blast it again to get it clean. I started grinding but i will not get the result I want and there are some reallly difficult areas to reach without removing suspension, brake lines and sub frame. Anyway I will make a rotiresse blast it again....
Have anyone used Eastwood chassisblack or is it better to use gloss paint. I heard that POR15 is better suited for "rusted"/ corroded underbodys.
Cleaning and repairing the damaged areas is no option or using underbody coating to cover the repairs...
What have you used ?
Olav
Denvervet
04-12-2010, 08:54 PM
Epoxy sticks like crazy so must be something it is over that is coming off under it. You mentioned zinc primer then epoxy. Did you do that? If so, that's a problem. bummer either way for you.Good luck
Olav
04-24-2010, 11:33 AM
Taken the rear suspension off and sub frame. Made a frame for the body so it will be easy to work with.
elitecustombody
04-24-2010, 11:47 AM
Blast,etch primer and or epoxy primer
rrstroker71
04-24-2010, 03:00 PM
Blast, epoxy prime with a good primer, BASF, PPG DP or equal. Epoxy or etch stick very good so either it was not preped right or thier was another material between the the metal and primer.
Olav
04-24-2010, 09:56 PM
I will use this epoxy. http://eng.hagmans.com/produktinfo/p...lska/11160.pdf
And semigloss top coat, the painter I'm gona use for the outside body told me to use " truckpaint". They use it on trucks and it's more durable and don't chips easy
The problem is between the Zink primer and primer. I think if i had used wash primer/ etch primer over the Zink this would not happend. Anyway its to late now.....
rusty428cj
04-25-2010, 03:25 AM
All you need to use is SPI black epoxy www.southernpolyurethanes.com (http://www.southernpolyurethanes.com)
Olav
11-17-2011, 11:56 AM
513865138751388Finally blastered. I work at a ship yard ( www.gmc.no ) and the company next door is building steel constructions for offshore oil industry. They have a good blastring and painting shop that we also use. I asked them to do this job for me. No problem!!!
MIKE67
11-19-2011, 12:48 PM
That is so nice having access to a great sandblasting room with downdraft floor! I hand sanded my floor with the back end hung from an A-frame engine hoist.
Olav
11-19-2011, 01:03 PM
Turned out very well. The guy who did it had been sandblasting for many years. But not on cars, mostly offshore constructions, so he was very provd of this job. With no warping of panels or so. He used fine grit and low pressure.
Yesterday it was primed with Zink
When I blastered the body my self first time it was in a old workshop and sand/ grit all over the floor. And body on 2 supports so I had to blast everything from the underside. That time it was completly covered with thick undercoat and rust. When you blast the coating it melts and everything becomes a mess. Ohh! I hate it....
Olav
11-21-2011, 09:37 AM
Finally in primer and back at the machine shop at my work.51491
64impala
11-21-2011, 04:02 PM
I used KBS Rust Seal. Had great results. Then I coated over that with Monstiliner Bed Coating. Good luck
scotzilla
11-28-2011, 08:54 AM
ppg dp - the only way to go!
scotzilla
11-30-2011, 07:37 AM
then take it to linex and do this
https://static1.pt-content.com/images/pt/2011/11/IMG_1273-2.jpg
https://static1.pt-content.com/images/pt/2011/11/IMG_1271-1.jpg
https://static1.pt-content.com/images/pt/2011/11/20111128095434-1.jpg
https://static1.pt-content.com/images/pt/2011/11/20110817105059-1.jpg
Olav
03-03-2012, 01:54 AM
56181Well after 2 coats of epoxy acid/ wash primer, body shutz in rear wheel housings and rear panel. 2 coats of 2K 50% gloss "truck paint" . Hopefully it will last longer this time. Time to bring the car home from work. Since I have got a new job i probably have to do it anyway....
grenade inspector
03-03-2012, 05:17 AM
I didnt think you were supposed to paint over zinc primer, I thought that was for inside panels being welded together etc where you dont want rust but cant get after assembly.
