    Results 1 to 11 of 11
      AUSTIN
      1951 Chevy Sus-please No Mustang2
      After trolling the board for a while, I finally decided to register.
      This is my first post.
      I am building a 1951 chevy styleline deluxe 2dr sedan
      I picked the car up 2 months ago and have completely stripped it down. I plan in the next few weeks to remove the shell and begin blasting the frame. Upon completion I would like to begin installaion of my dana IRS. The next problem is to tackle the 55 year old front suspension. This is where I have a delima...
      I have no experience with mustang/pinto suspension
      After alot of research, I have come to the conclusion that this tpe of front suspension is not the best handling, but just the best "packaged"
      I need other suggestions...I am willing to clip it
      Track width 57" +/- .125 hub to hub
      Thanks in advance
      Jared
      May 2002
      Northern California
      hey
      welcome to the site and congrates for registering.
      We did a 49 Chev with a 73' Camaro front end and came out very well, After that we grafted an 85 Corvette front engine/suspension cradle to a 50 Ford pick up frame, that worked out even better. In both cases put the engines in there right places.
      Depends on what you can get your hands on I suppose.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      AUSTIN
      I am a CAD designer and will draw plans before any work is done
      I was wondering what kind of clearance issues arose when grafting the camaro suspension
      Indianapolis, Indiana
      51' Chevy suspension
      Have you considered using a first gen subframe? DSE has a car on their website, I think it is an older Oldsmobile that they put a first gen sub in with all of there goodies. Also since all you are using is just the middle section of the frame you could probably score one that the mounts are rusted out for a decent price.
      May 2002
      Northern California
      No clearance issues at all, we cut the original frame back to where the rear of the camaro frame ended it was boxed .The width was close. A new TCI firewall was made up for it.
      The problems with a 1st gen subframe is geometry, as known can be better, the rear steer box location can make it difficult to get the right steering column angle and the track width may not be wide enough for some older cars.
      But yes 1st gens are easy to find.
      Elgin, IL
      Scott's Hot Rods can make what ever you need.
      Good Luck
      Dan
      AUSTIN
      Thanks I Appreciate The Suggestions Please Feel Free To Add Other Feedback As All Suggestions Are Considered
      What Would You Do?
      NY
      Progressive Automotive builds kits for Vette based ft and rear suspensions. Probably the most customer service oriented company out there.
      May 2002
      Northern California
      Sorry, I sounded like you wanted to tackle this yourself. Me i'd do it myself, what type of experience do you have?
      Edmonton, Alberta, CANADA
      I did a 1951 GMC half ton.. I grafted on a '77 Camaro front end.... beauty!
      AUSTIN
      Quote Originally Posted by MrQuick
      I plan to do everything myself,however I m not great with an arc welder
      so I plan to have a friend who is watch and make sure I dont mess it up
      I have also heard that s10 frames are very close dimensions. Would anyone suggest this.
