Results 1 to 12 of 12
04-06-2010 #1
1967 Camaro 2005 GTO LS2: Wire fans off ECM?
I have a 1967 Camaro RS/SS with a 2005 GTO LS2 installed and it has been running great for over 2+ years. I just recently installed a new LSX style aluminum dual pass radiator with 2 electric fans on it. My last radiator/fan setup I had a switch that I would just toggle on and off as needed. This new fan setup comes with the necessary relays, wiring & a 180 NPT sensor that is supposed to control when the fans come on and off. With that said, the LS2 engine has 1 port in the driver side of the head which is used by the computer and the other one I was using for my electrical temp gauge. Now I have the 180 NPT sensor and no where to install it. I tried making a T piping out of NPT which I believe will do the trick.
I was wondering, since the computer is already using one of the ports for the temperature, is there any way to tap into the computer or wiring and have it turn on and off these fans some how?
I have been searching on the internet for a while for some answers and haven't found anything concrete. Any help, guidance or suggestions would be greatly appreciated. Thanks in advance.
