View Full Version : I'm going Twin Procharged
Procharmo
04-03-2010, 02:20 PM
This is the SBC twin F1C gear drive winging it's way across the Atlantic from Terry at the Supercharger store.
It's not here yet but these pics have wet my appetite...
Memphis
04-03-2010, 04:18 PM
Nice! It would look pretty with twin F3Rs :D
Supervette
04-04-2010, 08:48 AM
wow does he make one for twin D1sc's. that is so awesome I really want one!
Supervette
04-05-2010, 04:10 PM
This might be a dumb question, but what would happen if you ran a smaller procharger with a bigger one? Like a staged turbo setup. does it kind of work the same?
wicked68
04-07-2010, 01:39 AM
holy crap dude - that looks like its going to be sick!
Procharmo
04-13-2010, 01:43 PM
LOL! You would need a pretty wide car for that, not to mention a drive chain that could hold the 5000hp you'd make.!LOL!
Procharmo
04-13-2010, 01:52 PM
I may well do that but with both the same size. From the outlet of one to the intake of the other. You get twice the pressue....Parrallel you get twice the volume, but too much volume can mean pressure as well.....
AIR is Procharger's industrial sister company. Notice the spec's 15psi 5000cfm parallel and 40psi 2500cfm series..
Thing is using gas you can't really do much with 80 PSI even with inter blower intercooling hence parallel staging is what most do. Now if it were a diesel.!!!!!
Procharmo
04-15-2010, 12:03 PM
Got it!!!!
Supervette
04-16-2010, 05:32 AM
I got it. Parallel looks like the way to go much more CFM and less boost pressure it appears according to the graphs. What kind of fuel system is feeding this beast?! This is one of the coolest projects I've ever seen. by the way thanks for the explanation on that its not everyday you get good graphs like that to look at. :) Im also wondering how your fitting that engine with the prochargers on the front and wedging it in the engine bay. You must have a lot of fabrication done on the front end of the car?
Procharmo
04-16-2010, 12:35 PM
Thanks for the inspiration. I'm sure people are following this project but as all the other twin Procharged cars are Outlaw Drag Radial 2500 - 3000hp Monsters. I thought I have a go and control the boost to allow me to drive it on the street round corners at below 1000hp, and then turn up the boost via waste gates for some fun.
Back in '94 people said I was crazy to buy a Procharger (Brand new company) and run a 700hp car on the street. 18 years later 700hp street cars are common, so I thought I'd make this build future proof!!!!
This was....cutting edge in '94 especially in the UK. Remember Prochargers website had one page back then......https://static1.pt-content.com/images/noimg.gif
I've got my doubters but you have given positive vibes so I'll crack on....
DeltaT
04-18-2010, 09:49 PM
Maybe those AFR 235's are going to turn out to be too small after all! You are a sick man :)
Where does the radiator end up?
Jim
Procharmo
04-22-2010, 03:13 PM
The radiators have been split and will be run in parallel....a third may be added if needed in series.......
This is as far as I have got!!!
67 ls1 vert
04-22-2010, 03:22 PM
I was just going to ask about the radiator too. Looks interesting.
DaviRotten
04-22-2010, 04:09 PM
Tits
DJW32
04-22-2010, 08:52 PM
How big is the motor?
turbo kid
04-26-2010, 08:50 PM
Love it!Any up dates?
Procharmo
05-16-2010, 02:27 PM
It's tiny Dart 406. I didn't fancy a real big small block...
Procharmo
05-16-2010, 02:29 PM
http://www.nastyz28.com/forum/showthread.php?p=1951550
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/5BwKKgCnMao&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5BwKKgCnMao&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Vegas69
05-16-2010, 02:34 PM
What are your goals on the track?
Procharmo
05-17-2010, 12:37 AM
I'd love to drive 150 - 250 miles to the strip and rip of low eights in RWYB. Not looking to fully cage or install chutes. Then possibly enter this competition we have over here called Ten of The Best. TOTB consists of unlimited modified cars running the cones for time then a 1/4 mile run followed by a 2 mile high speed run. Currently its dominated by modified Vipers and Skylines. You need mid eight quarters, low times on the autocross and 205 - 215 mph top speed run to be competitive.
There are plenty of mid eight single F2 Procharged street cars. Even a few high seven semi-street cars too but the more I modify the suspension for the 1/4 the worse the autocross handling becomes. Hence the need to have high power with a lot of control over the boost curves!!!!!
Procharmo
05-25-2010, 04:31 PM
Saw this over on YB, they say it has good "street manners"....
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/kbGCwl8THoY&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/kbGCwl8THoY&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Great inspiration for my baby street version...
67 ls1 vert
05-25-2010, 08:14 PM
cool vid. wonder it made?
Procharmo
05-25-2010, 11:07 PM
Somewhere around 1600hp on less than half boost, 17lbs....should be able to get 50lbs when they change the gear drive ratios...
Procharmo
06-01-2010, 09:04 AM
Getting there!!!
Procharmo
06-07-2010, 12:07 PM
Progress vid..
MODERATOR: Language in video not appropriate.
wicked68
06-07-2010, 04:41 PM
[QUOTE=Procharmo;681429]Progress vid..
Fu$%! lol
79PonchoUK
06-10-2010, 01:59 AM
I only doubt your sanity.
You can't really listen to people in the UK though, it's so full of tuning bull**** it's hard to keep your own head straight at times. :lol:
Nice work on the build - will you be just using it on the street or can we see you heading to any tracks north of london? Would be great to see this beast in person.
79PonchoUK
06-10-2010, 02:05 AM
For some reaon I missed the rest of this thread.
This at ten of the best would be great to see. You'll need a LOT of boost control.....those autox tracks are tight.
The way those skylines go, you could turn up with two thirds the power they have and still beat them. Granted, they're quick, but they take a while to get quick, if you know what I mean. I think you'll have the event wrapped up as long as you can tame that power through autox.
Procharmo
06-10-2010, 04:18 AM
Thanks 79PonchoUK, sometimes I spend time justifying my goals online, sometimes I feel it's not worth explaining. But here goes!
There are so many drag racers that feel you need 18" wide slicks, a four link and a 25 point cage just to run 10's yet there are others running 7's with leaf springs and 275 tryes.
There are cars with just the Hotchkis TVS and Kumohs tearing up the auto cross yet some have mini tubs, 335's and 315's on the front and can't hang with the others, even with the same driver!.
So many refuse to embrace anything new or have a irrational fear of failure. Thanks again for the encouragement and seeing beyond the "Why" question.....
I'm sure the Wright Brothers must have had similar issues.
Here's some of my favourite video's showing individuals who must have been asked "Why".....
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/F9xM-UM-vhw&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/F9xM-UM-vhw&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/mwb0VLJl3Jw&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/mwb0VLJl3Jw&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
https://static1.pt-content.com/images/pt/2010/06/0906chp_01_z1973_chevy_camarowith_cowl_h-1.jpg
https://static1.pt-content.com/images/pt/2010/06/0906chp_02_z515_big_block_enginewith_a_p-1.jpg
https://static1.pt-content.com/images/pt/2010/06/0906chp_09_zcal_tracspart-1.jpg
https://static1.pt-content.com/images/pt/2010/06/0906chp_07_zmickey_thompsontires-1.jpg
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/_9CxKFk1fUs&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/_9CxKFk1fUs&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/wQM68JmFJ_k&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/wQM68JmFJ_k&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Procharmo
06-10-2010, 03:33 PM
Fu$%! lol
Sorry!!!
79PonchoUK
06-11-2010, 03:49 AM
I want to take my car to autocross here in the midlands.
A few years ago I took my V6 capri and was told by the autocross organiser that it might be too cumbersome for the course. I disagreed, turned up and put in very respectable times....beating MX5s, porsche 944s etc.
I know for a fact that the trans am would be quicker despite its size and weight, but I know for a fact that when I take it there I'll get smirks.
Every time i watch TOTB I think to myself how much better a well turned out muscle car would be at the event. Particularly if it had the spending those skylines and evos do. It's a car that has some better fundamentals than either...space for huge tyres, a big engine to begin with and the dimensions to hold it all together.
I really think that if you're capable behind the wheel, your car will trounce the TOTB competitors and shut a few people up for good. Particularly those I speak to at le mans...."that overweight tank couldn't negotiate ASDA car park without spinning off, let alone a race track."
Righto.
Procharmo
06-12-2010, 02:32 PM
Thanks for the encouragement. Sounds like you and I encounter similar doubters. Mary's 2nd Gen is a testament to the fact that the cars can be made to handle without straying too far from stock style suspension. A similar movement is taking place in drag racing and there are many racers upset by stock appearing cars on small tyres (No tubs/leaf springs)) putting in very fast times that were previously reserved for purpose built machines.....(slicks)....
Gtrpunk23
06-27-2010, 09:31 PM
p1sc/d1scs would bolt right up to that. An f1 is the same bolt pattern but it the housing is like half an inch thicker. I recenlty bolted an f1 in place of my p1sc with no problems.
Procharmo
06-30-2010, 09:17 AM
p1sc/d1scs would bolt right up to that. An f1 is the same bolt pattern but it the housing is like half an inch thicker. I recently bolted an f1 in place of my p1sc with no problems.
You're right Twin P1SC's will support over 1200hp all day long. But I guess they'd come on sooner in the rpm range than a single larger blower....
LineUPP
08-18-2010, 09:34 AM
bad ass setup!
Procharmo
08-21-2010, 03:11 AM
bad ass setup!
Thanks for the complement, I've still not fired up yet, been wiring and starting to filler her up with fluids......Depending on whether I upgraded the front Brakes from Baer 2 piston 13" rotors to Baer 6P 13" rotors or ditch the 17" wheels for 18" and go 14" rotors the chosen option will dictate how much longer this all takes.
Knowing my luck by the time i get it to the event some billionaire will turn up at TOTB with a Bugatti Veyron Super Sport and put down 265mph top speed, 9 sec quarter and the fastest track time LOL!.
XLexusTech
08-21-2010, 04:54 AM
OH God that looks awesome..
uk68327
08-21-2010, 01:39 PM
WOW:drool: you have been busy!
Veyron Super Sport rocks, but hey, give me a Camaro any day :rotfl:
Procharmo
09-17-2010, 01:26 PM
Veyron Super Sport is the king but £2,000,000.00!!!!!!
Mark look out for an "it's alive" video soon. I had my lap top stolen and all my old youtube stuff's been deleted. Luckily they didn't take the car or any parts.
Procharmo
09-19-2010, 06:01 AM
It's alive.......http://www.youtube.com/watch?v=NgWrcDRt3wo
uk68327
09-19-2010, 06:47 AM
Sorry to hear about your laptop, scumbag thieves! Glad they did not take the car/parts.
Your car sounds awesome! :jump: Making excellent progress! and here's me thinking my Golf G60 sounded loud hehe :D
P.S. Good job you didn't sneeze going into that garage, you would have hit it - that's is a tight fit! Are you a qualified contortionist? :D
67 ls1 vert
09-19-2010, 05:45 PM
Love the engine set up.
Now you need to make the garage door a little wider so you don't scratch that thing!! LOL Man, that's close.
59twin turbo el camino
10-08-2010, 10:48 AM
what a great car do you get ,i love it .and the twin procharger set looks awsome . hope to see you sometime on santapod next year. greetings jacco,
Procharmo
10-09-2010, 04:13 AM
Hi Jacco, thanks for the compliments. I really do hope to get to the Pod because your TT Camino is off the hook......Trust me mine is a bit of a junker close up. I can see the engineering and attention to finish in yours is so extreme.
David
2blownstangs
01-14-2011, 09:29 AM
anymore pics of the set-up?
Procharmo
01-14-2011, 11:33 AM
Here is the build thread. http://www.theturboforums.com/smf/index.php?topic=139462.0
Thanks for asking. I'm stalled at the moment waiting to get a better dual needle carb, suspension and tyres. Hope to run it this year and will post video's then...
2blownstangs
01-14-2011, 12:02 PM
Nice, thanks for the reply. I know what it feels like to wait on parts bro. Can't wait til it's done
68camotion
01-16-2012, 08:13 PM
I'm still trying to figure out why the dual setup? What's the advantages over a single large procharger?
Procharmo
04-20-2012, 04:13 AM
The jury is out on that one. Air volume, pressure, heat and the power to drive them are all variables that can be advantageous or hinder performance depending on the overall configuration.
For me it was more attractive than selling a smaller one to buy a bigger one.
I simply bought an additional small one.
