View Full Version : Need Help ASAP, Ordering New Leafs Today!
ATAK, Inc.
03-31-2010, 02:58 PM
I'm going to order Hotchkis rear leafs for my '69 Camaro from Classic, got to order tonite for 20% off.
My question is; 1-1/2" or 3" drop? I'm using a Wayne Due frame with QA-1 coil-overs, want a nice low stance. I will be using 275-40-17 tires on all 4 corners to start (25.7" tall). Will It sit proper with the 1-1/2" drop? Is 3" too much?
I know these are fairly subjective questions but want to hear from anyone running these springs, or at least these amounts of drop.
Anything is greatly appreciated.
Hotchkis
03-31-2010, 04:02 PM
The 69 Camaro below is lowered 3" in front and 3" in rear running 245/45/17 tires
1967 Camaro is running a Hotchkis 1.5 TVS (http://www.hotchkis.net/search.html?Search_Keyword=80015) System and Tubular Control Arms. Tire size is 225/45/17 & 245/45/18
Rod
03-31-2010, 04:04 PM
3 inch rear leafs
ATAK, Inc.
03-31-2010, 04:36 PM
Thanks for the quick response guys!
I think that sums it up, 3" lower will do better to tuck the wheel/tire in the rear. Any issues with ride quality with the 3" drop?
Or, can I run the 1-1/2" drop and use 1" spacers?
TitoJones
04-01-2010, 09:46 AM
I'd do the 3 inch drop over a lowering block version. Also get a good shock to pair with the leafs, the Bilstien is one of the best for the money. Don't forget that most 3" drop springs are referencing a factory ride height as a starting point; a car with sagging springs might be lower than the replacement spring will be. These things were 4x4's by factory spec ride height.
Tyler
ATAK, Inc.
04-05-2010, 06:27 AM
Tyler
Thanks Tyler!
Using the reference to what the factory car specs are painted a good visual as opposed to my 41+ year old mono leafs, which have as much sag as a 90 year old woman! 3" drop it is! Would have stopped by, but you are no longer in Vegas, I was down for a visit and am heading back north to my own private Idaho today!!! At least going to get more work done on the car. Hit a Royal Flush when we went out the one time to gamble, on $20 is all I played, and it was dealt to me... very wierd, But good!
Hotchkis
04-05-2010, 07:58 AM
The 3" spring rides great, not really any different than the 1.5" spring - sporty yet still very comfortable. Like Tyler said, the Bilstein is a great shock when paired with this spring - they are definitely worth it over the auto parts store generic stuff.
ATAK, Inc.
04-06-2010, 09:07 PM
Just got back from Las Vegas, what a brutal return drive! 19 hour drive spanning 1,067 miles, going thru Utah when a winter storm hit! And of course it snowed a little up here too. At least today was nice, and was my birthday, the big 5-0!
I'm sold on the 3" drop, thanks for the input, exactly what I needed. I am going to hold off for about a month to get the springs/shocks so I can get the posi unit and diff gears, 3.73 or 4.11, at the same time and do it right the first time!
To think I was going to settle with 3.08 gears and an open rear to start! Would rather take a little longer and be happy with the car when rubber meets the road!
