View Full Version : 68 hidden vin
mls0923
03-29-2010, 02:12 PM
I'm new here and looking for some help. I have a 68 Camaro which I bought with a missing vin tag at the window. I found the hidden partial vin at the heater box. The weird thing is this: the partial vin reads "8U119780" . I do not see anywhere where a U was ever in any vin, and the number sequence does not match what a 68 should be. The last 6 numbers on the title vin is 383246, which is in line with the sequences. Am I missing something? I thought the last 6 in the hidden vin should match the title vin. Also I have heard there is a complete vin number hidden on the car somewhere, but the DMV or state police will not tell where to find it. Is there any truth to that? If so where to look. Thanks, Mike
chevyhector
03-29-2010, 02:31 PM
Sorry Mike, I wish i could help you.
RobM
03-29-2010, 02:59 PM
ask on camaros.net
SpicerMTR
03-29-2010, 03:56 PM
There should also be a stamped # under the cowl panel. With the panel removed, as you look at the section below the windshield, there are openings to allow the air into the cowl section. Between the opening on the passenger side of the cowl and the center opening area there is a piece of metal for support, and in that section there is a number stamped there too.
mls0923
03-29-2010, 04:30 PM
That number was illegible, but what I have learned is that is the same as the number on the heater section. I am wondering if the partial vin indicates that the car was originally a Firebird and not a Camaro, since the only plant using the U code was a firebird plant. If so then I got screwed.
vintageracer
03-29-2010, 05:25 PM
IF you have a U in the VIN then the car is a Firebird with Camaro sheetmetal. Lot's of those getting built here in the south.
U stands for the Lordstown Ohio plant which built Firebirds.
What does the trim tag on the firewall list or is it also missing?
If the hidden VIN has a U in the VIN, the VIN tag is missing and the trim tag is missing you can bet that you have a Firebird with Camaro sheetmetal installed.
BonzoHansen
03-29-2010, 06:59 PM
might help:
http://www.camaros.org/numbers.shtml
TonyHuntimer
03-29-2010, 09:40 PM
There isn't a complete vin posted anywhere on a 68 Camaro...only partials on the engine, transmission, firewall below heater blower motor, and top of cowl panel under the removable cowl panel cover.
The VIN you have on the firewall should match the last 8 characters on the vehicle title. If they don't, the title is for another car and the person you bought the car from probably got "taken" and sold it to you...or he knew what was going on and sold it to you hoping you would never look.
Does the title say that the car you bought is a Camaro?
A very rare possibility is that the firewall section was cut from a Firebird and welded to a Camaro. You'd have to inspect the areas around the panel and see if it's been tampered with or shows signs of replacement. What numbers are on top of the cowl panel?
Most likely you have a Firebird with Camaro panels welded onto it. It happened a lot in the past and continues to happen when people can't be happy enough owning a Firebird.
