Thumpin'66
03-24-2010, 08:20 PM
Hey guys,
I am planning to run 1" narrower track width per side on my 66 by shortening the A arms. I know all the reasons why I shouldn't but I am looking for any advice on setting it up as properly as possible.
I plan on SPC uppers with 1" shorter sleeves and shortened UB lowers plus either my stock disc spindles with tall screw in BJs or an L&H tall spindle.
I want to fit Z51 brakes behind my 17" wheels (because I want to, that's why) and I need the extra inch for reduced wheel backspacing. It will give me a bit deeper dish on the front too and I like the look.
Anyhow, how can I verify that this will work? I know there is simulator software out there but would I only use that after the front end is mocked up? I just want to buy the correct parts as far as steerign arm, spindle, etc. I plan on adding a splined sway bar too. Would I need to relocate my upper arm mounting pad on the frame rail to optimize things?
Any advice is appreciated and criticism is ok as long as you don't beat me up too bad.. https://static1.pt-content.com/images/pt/2009/11/smile-1.gif
