ho428
03-24-2010, 07:20 AM
Starting mocking everything up, looks like I'll need a 3/8-1/2" spacer in the rear until I get the disc rotor installed. It being thicker than the drum will help, but it'll still be tight.
8" x 17" front with 4 1/2 BS, 245/40/17
9" x 17" rear with 5" BS, 275/40/17
Hoosier R6's
The inner fender on the rear is going to be tight, the section width of the 275 is narrower (11" vs 12") than what I was running but I had a 4" BS then. The sidewalls flexed a lot on the 15" bias, and the inner would rub under hard cornering, I'm hoping the shorter 17" sidewall won't do that.
https://static1.pt-content.com/images/pt/2010/03/100_3587-1.jpg
Hoosier R6's
