View Full Version : 1965/1966 mustang..wheels too big?
streetrods
03-21-2010, 03:19 PM
Anyone have a picture of a 65 or 66 mustang coupe with 20s tucked under the back ? Just wondering if it would look okay if it was low enough...?
I was going with 18x10s but I got a deal on these 20x10 boyd smoothies and thought I might try it with 18s up front...
67greengt
03-21-2010, 08:34 PM
I'm guessing you'll be mini-tubbing the back to fit the 10" wheels, I would say that the 20x10 could be okay if you tucked the wheel better in the back, maybe 2 or 3 inches lower in the back. What kind of suspension are you planning on running in the front/back? Are you planning any other body mods, side skirts flares etc?
streetrods
03-22-2010, 09:39 AM
yeah it's mini tubbed so the width isn't a problem.. once the car is put back together it should drop a couple of inches....
No other body mods planned
spaghettio
03-22-2010, 12:05 PM
i have a mustang project also. im planning on going with 18s in the back
Bryce
03-22-2010, 04:37 PM
I think 20s are too big and there is a lack of performance in that size. A 17 is perfect.
That white 67 or 68' fastback that was a SMOY finalist had 24's? in the back...Stance is more important that wheel size IMO. You need to have them tucked! Mustang's are kinda close in size to Nova's, after deliberating for months I finally pulled the trigger for a 18/19 combo.
jconde
03-24-2010, 08:20 PM
hi i have a 68 coupe trying to get a 19x10 on the rear do you have any pic's of the mini-tub work you did or if not can you kinda give me an idea of what you had to do thanks jeb conde
Bryce
03-24-2010, 09:43 PM
I think the 68 will fit a 275 on a 10" wheel without a minitub
67greengt
03-26-2010, 10:13 AM
depends on the car... it seems as though every car varies quite a bit.
I haven't talken any pics of the mini tub, but I can tell you how to do it.. it's pretty straight forward.
You want to cut the inner wheel tub out by starting with a tape line along the seam of where the inner/outer wheel tub are welded together. The tape line will give you about an inch of lip left of the inner wheel housing to weld your new tub to for strength; from your cut along the tape line you want to go about 4" inward towards the inside of the car. You'll notice the biggest gains in the front and rear corners on the wheel wells as the factory ones are tapered. This will allow you to retain your factory interior panels. Based on my 295/35/18's I can still fit my interior panels and I may even go a bit more just to have some more room. I'll take some pics when I get a chance.
Hope this helps
Let me know if you have any questions
Tom
67greengt
03-26-2010, 11:09 AM
Hope this helps
Tom
streetrods
03-26-2010, 05:40 PM
I bought two new inner wheel wells... cut the old ones long..then moved them in towards the gas tank about two inches each side... then trimmed the edge of the rear frame rails and welded in support.
with a 68 you should have more room but I know on a 66 the springs are the first problem you run into.. I did a 3 inch spring relocation on mine.. next time I'll just do a four link though...
youngandfree
03-28-2010, 11:39 AM
Check this out. 18's in front and 20's in back. Pretty sweet ride.
http://www.autoworksracing.com/AWRacing/eurostang/slides/101_0291.html
pro-touringAK
03-28-2010, 12:43 PM
saw the car at their shop in August. It is a sweet look.
streetrods
03-28-2010, 05:31 PM
Thanks! Looks good.. not a fan of the whole look but the wheels work well.. Small tire...probably a 25 sidewall or something..
streetrods
03-28-2010, 06:29 PM
okay...so those are 20x8.5 on the back of that car with 255 35 20s... and 17s up front... If I go with a 285 30 20 on my 10s I will have about the same sidewall... also think 18s up front will look better than 17s with 20s.. But who knows I can't pull the trigger on the 20s yet...
ballajb
04-09-2010, 09:10 AM
I was just at a rim shop yesterday ordering my 18x8's (do you think i will have a problem with fitting them? and what size tires should i go with?) but i saw a 1967 mustang on 22" rims. I took pics so here it is:
37352
37353
ballajb
04-12-2010, 09:15 AM
I just got my 18x8s on my car this weekend. The backspace of the rim is 4 1/2. The tires i went with are 225/40/R18.
37400
Bryce
04-12-2010, 11:37 AM
why only a 225? Looks good. I think you could have gone much wider. 245 in the front and 265 in the back.
ballajb
04-12-2010, 11:41 AM
the shop was saying that wider than 225 would especially since i am goin to be lowering the car. in the rear, if i lower 2 inches the 225 is just right where i wont have my fender cutting into the tire
ballajb
i will probably be burning up those rear pretty fast, and when i do maybe i will try 235 n see how that goes
Bryce
04-12-2010, 01:23 PM
just to give you an idea. I have 245s on all four corners of the 65 mustang. and a 265 drag slick in the back for track days.
ballajb
04-12-2010, 01:31 PM
i think i might just have to see about that 245s cause if i can go wider i would like that
windsor
04-13-2010, 02:53 AM
toooo biiiiiig.
No bigger than 18" please.
spaghettio
04-13-2010, 01:54 PM
heres mine. just a trial wheel- its 285/18. mini tubbed though.
https://static1.pt-content.com/images/pt/2010/04/IMG_0180-1.jpg
https://static1.pt-content.com/images/pt/2010/04/IMG_0179-1.jpg
streetrods
04-15-2010, 07:37 PM
With 4 1/2 backspacing you will have trouble if you lower it too much... a 5 inch backspace 18x8 would be perfect on a 66 with stock width rearend..
streetrods
04-15-2010, 07:57 PM
Here is a 66 I did a few years back with a 17/18 combo... the rears were 18x8 with 4.5 backspace...tires were 245 35 18s... however I put a maverick rear in it which is a little narrower..and when I put 1/4 skins on it I pulled them out about 1/4 inch each side... so there is no way you could put 4.5 bs wheels on a stock 66 mustang and drop it like this one..
https://static1.pt-content.com/images/pt/2010/04/196620-1.jpg
https://static1.pt-content.com/images/pt/2010/04/196622-1.jpg
streetrods
04-15-2010, 08:03 PM
And here is a 66 I lowered this week.... it has a stock 66 rear end... the wheels in back are 18x8 with a 4.75 backspacing....tires are 245 40 18s.... It is a very tight fit to the outside... had to grind the 1/4 panel lip some.... a 5 or 5.25 backspace wheel would make it easier...
https://static1.pt-content.com/images/pt/2010/04/66white2-1.jpg
https://static1.pt-content.com/images/pt/2010/04/66white3-1.jpg
https://static1.pt-content.com/images/pt/2010/04/66white-1.jpg
jfoster
04-16-2010, 05:47 AM
^^^ Nice - I like that fox body too.
ballajb
04-16-2010, 07:10 AM
streetrods what kind of springs are you using? because i would like to lower my car just about that much
Z06killinSBF
04-16-2010, 12:25 PM
Mine has 4.5 BS on 17x8 with 235/45 17's stock everything just lowered.
ballajb
04-16-2010, 12:29 PM
i have to do that asap
streetrods
04-16-2010, 03:46 PM
Fronts are stock with a 1 1/2 coils cut and shelby a arm mod... rear was dropped 3 inches
streetrods
04-16-2010, 03:49 PM
You can lower some with a 4.5 bs but you will not be able to tuck tire like mine with that... I'm having enough trouble with a 4.75 bs
Cannon
04-16-2010, 05:07 PM
just mini-tub it, a 245 is weak! I would go with no bigger than a 17" too cause not only are tire choices much better, but prices are way cheaper in a 17".
gearheads78
04-16-2010, 05:22 PM
That tire/wheel size combo made me throw up in my mouth a little. 17/20 looks like ass on 85% of applications.
I would do a 17/18 or 18/19 on yours if you want a stagger
streetrods
04-16-2010, 05:48 PM
18" tires are not that much more than 17s... I can get 285 30 18's for $3 more per tire than a 275 40 17....
Z06killinSBF
04-17-2010, 05:43 PM
Mine rubs on incline turns.
1500ccturbo3whl
04-25-2010, 08:07 AM
18s look rite on mustangs, plus can get to sit nicer with less rubbing issues
[QUOTE=streetrods;659868]And here is a 66 I lowered this week.... it has a stock 66 rear end... the wheels in back are 18x8 with a 4.75 backspacing....tires are 245 40 18s.... It is a very tight fit to the outside... had to grind the 1/4 panel lip some.... a 5 or 5.25 backspace wheel would make it easier...
StreetRods,
This is the set up I'm looking for. Is that 17's on the front? If so, is there a reason why you don't use 18's in the front? Also what kind of wheels are these?
67rstbkt
05-05-2010, 08:03 AM
Thanks[/QUOTE]
I believe the wheels are called Rocket Booster's by Rocket Racing wheels
DANG!! That is a clean little coupe that sits right! Nice work! Talk about instant attitude!
streetrods
05-08-2010, 04:18 AM
You can put 18s up front if you want to... I just like the staggered look myself...
streetrods
05-08-2010, 04:22 AM
Thanks! maybe you can make me a set of wheels I can borrow for the 66 I'm working on now?? ; ) I have mini tubs in it so a 19x10 and 18x7 setup would be awesome!
xxXKowalskiXxx
08-18-2010, 10:16 AM
Hey there streetrods, I apologize for the unsolicited email, but I was hoping to ask you questions about your vehicle build.
Let me start w/ some background. I bought my 1966 Mustang coupe in 1998 while serving onboard the USS Caron, stationed in Virginia Beach, VA. The car was pretty bare bones, the engine not so great and tons of rust. Over the years I have invested a bit of funds into getting the motor and sheet metal to a solid state. Now it's time for some serious changes / upgrades to the suspension, brakes, wheels and tires.
I saw a photo of your 1966 coupe that you had recently lowered. This is the same year and color of my car and I would very much like to mimic the stance and wheels of your car.
So my questions, may seem redundant, but I am trying to cover all bases and build this car w/o breaking the bank and more importantly without making purchases that may later prove to not fit with parts on the car now...that's my big fear.
So, let the questions begin:
1. How do you like the staggered look and do you feel 18" tires in the front are too much?
2. What brand and model # front shocks are you using?
3. What brand and model # rear shocks are you using?
4. Are you running stock rear leaf springs? If not, what are you using?
5. Are you still using stock brakes? Are they drum? If not, what brand of aftermarket brakes do you use and what are the model or kit #s ?
6. Did you upgrade the master cylinder? to what?
7. I am very much going to use the same tire and wheel combo, but am concerned that it won't fit on a stock drum brake setup....thoughts?
8. Did you make any mods to the rear diff or axle?
9. Anything you would do differently now that you've gone through a build out?
I really appreciate your (and anyone else's) help guiding me through my 66 build out.
Mr. Din
08-24-2010, 04:50 AM
will 18x7 all the way around with 4in back spacing fit ok on a 65 mustang coupe? Will plan on lowering the front 1in and the rear 2ish inches.
eatapeach
09-20-2010, 07:44 PM
Not mine....dont know who's. The pic was sent to me by a friend.
18x8 & 20x9 and 2" drop coils is all the info I have on it.
I think it would look better if it was lowered some more.
bages
10-15-2010, 02:35 AM
Awesome car!! That is a great colour, it doesnt look like an original one though. Do you mind me asking what colour that is?
Hey eatapeach can you tell me what that scoop is off originally? I think I saw the same thing the other way around on a fastback once?
latamud
10-15-2010, 06:09 AM
19x10 rear, 19x9 front, 285/30 all around.
77thor
10-15-2010, 06:39 AM
IMO, the 20's look terrible... don't go bigger than 18's.
streetrods
10-15-2010, 05:57 PM
the color was factory it is Sauterne Gold met. code z
bages
10-15-2010, 08:49 PM
streetrods Im seriously addicted to your car, that colour is nuts!! Do you have any others you can post? Out in full sun? (I know that doesnt necessarily make for a good photo but would like to see how it changes the colour)
Thanks for the info !!
DriverzInc
10-16-2010, 09:04 AM
Hell yeah, those wheels are pretty sweet looking!
tonyferland
06-08-2011, 05:47 AM
Wow sick set up, I am new to this site and just got my dads 66 Mustang that he has had for 42 years. Now its time to get this Mustang back on the road with a new look. I want to run a set up like this one but need some help with suspension set up. Any help would be great. Great site!!!
Greasy63
06-08-2011, 11:29 AM
20x10's would b awesome back there!
im trying to convince one of my buddies to P/T his newly bought '67 Stang!! but he likes the ol'skool muscle look though..... :cough: boring :cough:
Mean looking Stang! What is the wheels size and offset in the front?.
Thanks fot your reply.
gsxrken
11-16-2011, 07:51 PM
Cool car - Like the rim choice and stance. What are the flares from
sr73bu
11-16-2011, 08:03 PM
wow! sick car! are those the Parnelli Jones wheels?
-Sean
streetrods
12-01-2011, 10:53 AM
My lastest 66 project for those who are not following my build thread....18x10s and 18x7s Mini tubbed
https://static1.pt-content.com/images/pt/2011/09/1966black5-1.jpg
https://static1.pt-content.com/images/pt/2011/09/1966black6-1.jpg
https://static1.pt-content.com/images/pt/2011/09/1966black7-1.jpg
https://static1.pt-content.com/images/pt/2011/09/1966black8-1.jpg
https://static1.pt-content.com/images/pt/2011/09/1966black9-1.jpg
dougnugent1
12-03-2011, 06:10 AM
Beautiful Car. What is the off set of your wheels. I am building a 65 fastback and really like your car. What mod did you do to the front suspension?
CruizinKev
12-03-2011, 06:24 AM
is it just me or the front wheels are different than the rears? rears looks like eagle 225 and fronts like coys c-57 :dunno:
streetrods
12-03-2011, 09:21 AM
Rears are 5" backspace..fronts that are on it right now I think are a 4.25 bs....Has the shelby mod and lowering springs..2008 mustang 12.5" brake conversion
streetrods
12-03-2011, 09:22 AM
Yeah the fronts are coys they are off of my sons Fairlane...Waiting for Eagle to make the 18x8 with the offset I want
CruizinKev
12-03-2011, 12:07 PM
oh yeah I'm also waiting :cheers: Eagle also got me backordered for few months already on the Eagle 225's
Nick LoPiccolo
12-11-2011, 08:48 PM
[QUOTE=streetrods;859367]My lastest 66 project for those who are not following my build thread....18x10s and 18x7s Mini tubbed
beautiful car. what color that? would you be able to tell me the color code. thank you.
DJ Mabe
12-12-2011, 04:55 PM
Great looking black coupe! The 10 inch wheel looks so good under that car. Below is a picture of my set up. 18x7's w/235's up front and 18x10's w/295's out back. No mini tubs.
dougnugent1
12-13-2011, 10:46 AM
Very nice car. Thanks for sharing the pictures.
SM69Mach
12-13-2011, 11:10 AM
Beautifel car DJ. Love the stance. My brother has a 68 vert as well.
streetrods
12-13-2011, 11:21 AM
Don't know the code other than it's black : )
streetrods
12-13-2011, 11:22 AM
Great looking car DJ.. No way of getting 10s under a 66 without mods thats for sure
DJ Mabe
12-13-2011, 07:11 PM
Agreed for sure! Thanks for the compliments guys! I didn't pay any attention to the 65-66 call out in this thread. I just saw a post about Mustangs on this site and got a little excited. Good to see a few more Mustangs getting modded to be driven.
Z06killinSBF
12-19-2011, 05:48 PM
Thats fine, go ahead and rub it in with your ability to run wide wheels stock...
Beauty of a car, I love everything about it.
1968deluxemustang
03-06-2012, 06:22 PM
how did you lower the front end??? and are the front 18X8?
dougnugent1
05-17-2012, 03:34 PM
The post got really quite. Please post more pictures of your wheel combo on 1965/66 mustangs. I am looking for a picture of 18/19 combo and 18/20 combo.
Thanks, Doug
Z06killinSBF
05-17-2012, 07:36 PM
I'll be posting up pics of my 17x10.5 w/315's once I get the wheels in, but this is all I have right now.
https://static1.pt-content.com/images/pt/2012/05/552846ed-1.jpg
dougnugent1
05-18-2012, 12:22 PM
That looks really nice. Will you please post a picture of the front wheels also.
Thanks, Doug
kmcanally
05-19-2012, 03:56 AM
That looks awesome...you obviously been hacking and cutting on your car?
kmcanally
05-19-2012, 04:11 AM
The fronts are 18x8 w/5.17" backspacing +.25 spacer and 245/40. The rears are 18x9 w/5.94" BS and 275/40.
59518
kmcanally
05-19-2012, 04:14 AM
I tried running 18x10 w/295 tire but it rubbed too much at this ride height.
59519
59520
Z06killinSBF
05-19-2012, 05:03 AM
Yes sir, check out my project thread. I have always loved your car btw.
acb70
06-26-2012, 08:53 PM
These all look great, does anyone know what cut stock coils with supposedly 4" drop look like? Thanks thinkin about putting it on my car on a '66 hardtop with anywhere from 14" rims to 18in.....
dexterdog
07-23-2012, 05:15 AM
I have a "66 Mustang that I had planned to put 18x8 with a 4.75" b.s. in the rear but I would like to go wider. I don't mind mini tubbing it but at what point will the rear leaf springs interfere?
Z06killinSBF
07-25-2012, 12:03 PM
The tubs can only be moved in about 2" before you hit the frame and need to relocate the leaf springs.
Wheel tubs moved onto the frame
https://static1.pt-content.com/images/pt/2012/05/7ed78dc8-1.jpg
315 doesn't fit
https://static1.pt-content.com/images/pt/2012/05/657aa2fe-1.jpg
So I narrowed the frame
https://static1.pt-content.com/images/pt/2012/05/db7682ac-1.jpg
dexterdog
07-26-2012, 05:29 AM
315 doesn't fit
So it looks like you welded in some square stock and then cut out the frame rail section. Did you re-weld the mini tubs to the new frame rail section and relocate the leaf spring hanger brackets to the new frame rail section? Was there any issues? Are you using the OEM 8" rear? This looks like the route I want to take without spending a pretty penny on a 4 link at this time. Should I be looking into a different rear end as well?
dexterdog
07-26-2012, 07:25 AM
I should have read your build thread before responding so quickly. The expoder 8.8" is a good idea. I should lean this way as well as they are a dime a dozen. I have gone back and forth with what I want to do with this car whether to get it going as far as paint and interior and slap some nice wheels on it since I am the type that wants it now but I think ultimately I won't be satisfied. I will be watching your build thread closely and may be picking your brain in the near future.
Z06killinSBF
07-27-2012, 10:09 AM
Sounds good. It's slow going now because of school but I'll try to get some work done to it before too long. Right now I'm waiting to order wheels, so that I can narrow the rear end, so I can start hanging sheet metal again. It's a viscous cycle.
EricButler
09-01-2012, 09:14 PM
315 doesn't fit
That is going to look sick when you get it done. I just bought the mini tubs for mine and the TCP G-link with the offset lower arms for mine. I plan on doing the install soon. Hoping to run an 11.5inch wheel on a 68 coupe with a 315/35/17.
Z06killinSBF
09-02-2012, 04:11 AM
Thanks, the 68 should eat up the 315's better than the early cars. These cars are sooo small.
LowFast
09-02-2012, 07:15 AM
Pffff, too small? Nothing some cutt'n and weld'n can't solve. I crammed 315's under a 65 Falcon, make it happen! :nopity:
Z06killinSBF
09-02-2012, 08:53 AM
Yup, I'll be fitting wheel tubs today if I can stop finding stuff that needs repaired first. Like the numerous brackets that were left unwelded or the fact that my passenger outer wheel tub was only braised in two locations. It's the tidy work that eats up my time.
rexabrown87
09-05-2012, 12:10 PM
how much is the front lowered and how much is the back lowered?
rexabrown87
09-05-2012, 12:48 PM
hey how much is the front and back lowered??????????
1968deluxemustang
09-16-2012, 08:16 PM
I wanna put 18X9.5 boss 338 with a 5.01" back spacing on the 68 stang you think i could, with out rubbing?
Angelo
01-07-2013, 03:23 PM
shortened rear end with custom machined aluminum spacers to find the sweet spot696796968069677
akaaka50
03-01-2013, 02:38 PM
'66 Stang with 17x7 American Racing Daytona's....
kencobra
03-17-2014, 06:48 PM
Any updates? I am about to order some 18 x10.5 and was wondering what BS you are going with. I was thinking 5"
Z06killinSBF
04-21-2014, 09:48 AM
Whatever the 94-04 mustang deep dish wheel is, I forget right now.
https://static1.pt-content.com/images/pt/2014/04/image_zpsc0a4208f-1.jpg (http://s9.photobucket.com/user/Z06killinSBF/media/image_zpsc0a4208f.jpg.html)
https://static1.pt-content.com/images/pt/2014/04/DSC_0145_zpsc2a52a08-1.jpg (http://s9.photobucket.com/user/Z06killinSBF/media/DSC_0145_zpsc2a52a08.jpg.html)
kencobra
04-21-2014, 11:03 AM
Thanks, ordered my Boze 18x10.5 and 17x7 a few weeks ago. Your car is looking good and sitting right, congrats.
joe28443
04-29-2014, 03:53 AM
What kind of front suspension mods have y'all done to tuck 18" wheels with no rubbing?
kencobra
06-26-2014, 05:06 PM
I mini tubed and moved in the rear frame rails. Going with a 4 bar suspension.
kencobra
06-26-2014, 05:11 PM
Would you do the 235's on a 7" rim again? Just got in my Boze Lateral G's for my '66 coupe 18x10.5 and 17x7.
DJ Mabe
07-03-2014, 04:22 AM
I would. No issues and the car handles great. I have rubbed a couple of times under hard braking/cornering but keep in mind my car is a 67.
Zenk 1420
04-21-2015, 05:27 PM
I like the yellow 66 with staggered wheels posted earlier on! Great builds too!
stangreen
04-22-2015, 06:48 AM
111863111864111863111864111863
I like the yellow 66 with staggered wheels posted earlier on! Great builds too!this is a couple pictures of mice 17 by 11 rims 315 3517 also have another picture of my 17 by 12 inch rims with 345 forty's 17
Zenk 1420
04-22-2015, 07:01 AM
111863111864111863111864111863this is a couple pictures of mice 17 by 11 rims 315 3517 also have another picture of my 17 by 12 inch rims with 345 forty's 17
Holy dish! looks awesome!!
GTOtzel
04-22-2015, 08:02 AM
18x8 up front 20x11 out back with a 305 Nitto NT05 DSE deep tubs and ridetech 4 link. Relocated lower 4-link bars to inside frame rails.
111873111874111875
TexasTechX1
04-23-2015, 06:25 AM
67 RS Camaro taillights? surprisingly doesn't look bad!
capshaw21
05-30-2017, 01:05 PM
where did you get the wheels from?
scootr117
02-26-2018, 05:57 AM
I found this post from a web search and was interested in learning how the OP lowered this white 66? I sent him a PM and haven't gotten a reply..
I'm also curious if it is drive-able at this height or is in bagged.
Does anyone have any background or experience getting a 65-66 this low?
streetrods
02-26-2018, 07:23 AM
Info is on post 32 in this thread
scootr117
02-26-2018, 09:01 AM
Thanks.... really nice cars.
My 66 was originally Saturine .... The other car you posted makes me think seriously of going back to that color!
How drive-able was the white car. I'm going to guess the rear has 2" drop leaf springs and a 1"block with a C notch ?
BrianD
04-22-2020, 06:46 PM
Did this green 66 mustang have a 90s 5.0 efi?
I bought it a few years ago from Lake Charles.
BrianD
04-22-2020, 06:49 PM
Did this 66 end up in Lake Charles La??
streetrods
04-23-2020, 05:20 AM
Replied to your pm
StangItUP
04-10-2024, 07:23 PM
Did you ever put 19X10' wheels on this new build. I know it's been a lot of years.
