View Full Version : Hey 69 Camaro guys! Did you see these yet?
TitoJones
03-17-2010, 12:12 PM
We had a press release in CHP about our new Phantom side marker lenses, but I totally forgot to put anything up on the boards.
These are injection molded polycarbonite lenses that replace the chrome bezel on the front and rear of the 69 Camaro. (We offer a sheetmetal cutting template for those who would want to add these to anything else)
Here is our show display with multiple painted lenses with the llight both on and off. This is the way they come from us; black smoked lens.
lights off:
https://static1.pt-content.com/images/pt/2010/03/334sxep-1.jpg
lights on:
https://static1.pt-content.com/images/pt/2010/03/14lt2k6-1.jpg
Close up of the back side of the lens:
https://static1.pt-content.com/images/pt/2010/03/2b2jjt-1.jpg
These are super easy to install as well. You just remove the barrel nuts from the factory bulb housing, and remove the chrome surround from the car, and re-install our Phantom lens in its place.
https://static1.pt-content.com/images/pt/2010/03/2yyqa85-1.jpg
https://static1.pt-content.com/images/pt/2010/03/vjhj-1.jpg
https://static1.pt-content.com/images/pt/2010/03/2vwuuzc-1.jpg
More to come....
Tyler
Mr.VENGEANCE
03-17-2010, 12:15 PM
cool!
TitoJones
03-17-2010, 12:28 PM
The best part?
You can paint these to match the color of the car so they blend in. On a black car simply install them. On other color cars you can do all sorts of neat tricks: (keep in mind these are taken in braod daylight, night will make them much brighter.)
https://static1.pt-content.com/images/pt/2010/03/28ksgok-1.jpg
Here is blue with the lights off:
https://static1.pt-content.com/images/pt/2010/03/20j1qv8-1.jpg
Blue with lights on:
https://static1.pt-content.com/images/pt/2010/03/a9lm9t-1.jpg
Red with lights off:
https://static1.pt-content.com/images/pt/2010/03/2qjal8p-1.jpg
Red with lights on:
https://static1.pt-content.com/images/pt/2010/03/23ua845-1.jpg
Silver with masked off window, lights off:
https://static1.pt-content.com/images/pt/2010/03/2ducql4-1.jpg
Silver with masked off window, lights on:
https://static1.pt-content.com/images/pt/2010/03/107kpsp-1.jpg
All silver with lights off:
https://static1.pt-content.com/images/pt/2010/03/34erepd-1.jpg
All silver, lights on:
https://static1.pt-content.com/images/pt/2010/03/6ocxhe-1.jpg
These will require a slight modification to install on the front as the shape of the sheetmetal is slightly smaller than the back. A quick grind with a dremel to our lens will make it pop right in.
These will also fit 69 Chevelle. They are $95.00 for a set of 4 and are in stock at the moment.
Any questions?
Tyler
Rod
03-17-2010, 09:58 PM
Man that's really
https://static1.pt-content.com/images/pt/2010/03/I_jizz_in_my_pants_by_HOLIMOUNT-1.jpg
ooooppps
I bet those will fit my 68! have you tried them on yours?
yodas little brother
03-18-2010, 08:01 AM
pretty cool
JEFFTATE
03-18-2010, 08:54 AM
Those look good Tyler !!
TitoJones
06-17-2010, 02:01 PM
We have a new way to install a set of our Phantom lenses onto any car- We now offer a stamped steel plate weld-in patch panel:
https://static1.pt-content.com/images/pt/2010/06/fyianb-1.jpg
https://static1.pt-content.com/images/pt/2010/06/281a9nt-1.jpg
https://static1.pt-content.com/images/pt/2010/06/jsyrg0-1.jpg
You can get a set of 4 weld-in patch panels and Phantom lenses for $190. The panels are $95 per 4 as are the lenses. You will still need either the 68 or 69 Camaro backing lens to complete the install (the amber and red colored bulb holders.)
Tyler
Mark68
06-18-2010, 04:25 AM
Will these fit a 68 with no modifications and if not, do you plan on making a set that does?
slownova73
09-06-2010, 01:39 PM
anything like this for us Nova outcast's?? 68-74???
DPG3
09-21-2010, 08:54 PM
thats pretty chill
protour73
10-02-2010, 06:38 PM
2nd Gen Camaro planned? :fingersx:
