View Full Version : Looking for the bestTermal heat barrier matt
Roadrage David
03-06-2010, 02:07 AM
for in a 2007 C6Z06 gt3 24 hours lemans type corvette. must be thin light weight self ahiesif and keep al the heat out of the cokpit of the car firewal + compleat floor. Thanks
Jim Nilsen
03-06-2010, 06:51 AM
Anything that has ceramic in it will be the best. Fiberfrax is a blanket material I have used on furnaces and incinerators and comes with a foil if you want. It is very light and comes in many thicknesses of insulation and foil but can be a bit messy when removing and replacing because it tends to lose some fibers.
The ceramic refractory type mud works well too but is also a pain to install.But it really works the best.
The ceramic cloth that is woven and foil faced would seem to be what you are looking for and the easiest to work with.
I did get fair heat reduction from my damplifier from 2nd skin but I am thinking you will need more than that. You could however use it on both sides and get the reflective action of the aluminum to help.
Roadrage David
03-06-2010, 06:59 AM
is that stuff the same as dynamatt???
wmhjr
03-06-2010, 07:19 AM
ANT will probably chime in here, but Damplifier Pro is a bit better performing according to the specs than Dynamat Extreme - but neither is really a heat barrier. It does provide some help in that area, but it's not it's primary purpose IIRC. Luxury Liner does work in that area, but it's kind of thick and heavy and may not suit your purposes. Not sure.
Yoda4561
03-06-2010, 02:26 PM
Secondskin has a new product out just for that purpose. It's a self adhesive, 1/4" thick thermal barrier call Thermal Block, check it out on their website. http://www.secondskinaudio.com/viewproduct.php?id_product=355#tab3 the 6 sq. foot panel weighs 1 pound.
chunger
03-06-2010, 07:27 PM
What about the Lizard Skin ceramic coating? They have a video on their website showing a electric grill that they've coated 1/2 of the cooking surface, which is cool to the touch, and the other half is cooking eggs.
I've never used it, but it looks impressive.
camarorad
03-06-2010, 08:35 PM
we used areogel behind stainless covered with a kevlar gold foil on a project. you can see it on Kirkham motorsports web page under the billet chassis book and go to chapter 8
www.kirkhammotorsports.com (http://www.kirkhammotorsports.com)
tazzz25906112
03-07-2010, 07:21 AM
Very cool product no pun intended LOL.....
