2Bad4Ya
03-04-2010, 04:24 PM
We replaced the quarters last yr on the 68 & we did not use full quarters. We used 80% quarters and seamed it to the car above the rear quarter body line.
Today I noticed some bubbling on the driverside rear quarter up in the seam area. I coated the underide of the weld seam back before we put the inner fender in, but could not get to the section above the plate that extends out from the hing area (I dunno how to best describe it).
Anyways it just so happens that the one area I was not able to coat from the underside is now producing some bubbles under the paint. I figure it is most likely rust since I have not had any other bubbling or other issues with the paint.
How is the best way to tackle this issue, and is the fact I can not coat the underside of the weld going to cause me problems in the future?
Is it an issue that a welded area may not have a coating/protection and could cause rust on the backside... could that cause rust on the outside? if So how can I prevent that in a situation where I can not get to the unprotected backside?
I assume to fix the outside I will need to grind out any filler in that area and a bit out and then treat the metal and refill and paint/feather that area?
Suggestions etc... appreciated, just a couple of shadetree mechanics doing it at home.
