View Full Version : Flywheel for LSX 454 8 bolt crank
Powermad
02-25-2010, 11:26 AM
Anyone know where I can get a flywheel, clutch and pressure plate to fit behind my LSX 454? The crank has 8 bolts versus the standard 6 bolts on other LS motors.
I am running a Tremec T-56 Magnum six speed behind the LSX.
Thanks. Stan
jknox67
02-25-2010, 04:51 PM
Try part number 24240678 from gm performance for your flywheel. Fits lsx 454 8 bolt crank. The flexplatee is 12622564. Not sure about the clutch. Good luck!
Powermad
02-25-2010, 06:32 PM
Thanks!
andrewb70
02-26-2010, 04:31 PM
Is it 8 or 9 bolts? What crank does GM use on that engine? LS9 crank?
Powermad
02-26-2010, 05:31 PM
It's an 8 bolt. I don't know which crank they used, only that the motor I just received has an 8 bolt crank.
GMJim
02-28-2010, 10:32 AM
LSX 454 crate engine uses an 8 bolt crank.
Pre 2009 LS series use 6 bolt. 2009 and up LS, LSA and LSX use 8 bolt. LS9 crank uses a 9 bolt flywheel.
Hope this helps.
andrewb70
03-01-2010, 12:08 PM
Hope this helps.
Thanks for the info!
Powermad
03-01-2010, 03:43 PM
Just sent GMJim a PM.
Thanks for the info Jim.
GMJim
03-01-2010, 03:52 PM
This just keeps getting more complicated!:pat:
andrewb70
03-03-2010, 06:13 PM
Yes, but its no different than when GM went to the 1986 pattern. I am just wondering why the change now. It's not like there were issues of failure with the 6 bolt pattern. Just thinking out loud.
