View Full Version : vintage air with stock pump
lt1chevelle
02-21-2010, 05:52 PM
i was wondering if i got vintage air could i use my stock compressior that came with the lt1 or would i have to use the supplied one that vintage air puts in there kit??
crustysack
02-21-2010, 06:49 PM
pretty sure you can use any compressor- you may have to make up custom a/c lines though
Twentyover
02-21-2010, 08:00 PM
pretty sure you can use any Fixed Displacement compressor- you may have to make up custom a/c lines though
Fixed it for you
lt1chevelle
02-21-2010, 10:45 PM
what do u mean fixed displacement? also is there a kit you guys would recommend getting since ill be using my compressior and making my own lines?
lt1chevelle
02-21-2010, 11:19 PM
would i want the sure fit one but only the evaporator kit since ill be using the compressor from the lt1 and making ac linehttp://www.vintageair.com/catalog09/09%20VintageAir%20Catalog%2040.pdfs?
Lawrence
02-22-2010, 03:08 AM
I had the LT1 compressor and a Vintage Air kit on my Camaro, worked perfectly.
lt1chevelle
02-22-2010, 09:22 AM
what kit did u get from VA?
130fe
02-22-2010, 09:50 AM
The LS type are variable displacement compressors, the LT ones are Fixed. Sometimes the variable ones don't work "properly" with the VA setup. Give Frank at Prodigy a call and he can set you up with a kit without compressor (if that what you want). BTW, consider the GenIV surefit one over the other models if you get one.
