View Full Version : Pro Touring Bandit
Trev
04-22-2005, 02:17 PM
I have been a long time reader on this site, but never really been one for posting much. I thought you would like to see some progress on my Pro Touring 77 Bandit Trans Am. Before any Trans Am fans start to panic, this car is a clone. There is not going to be much of the original car left anyway. Here is a picture of the 511 IAII based Pontiac motor just sat in the Wayne Due subframe. The car will have a TKO600 from Keisler and you can see the Baer brakes. The body is at the paint shop right now, and I hope to have it back in a week or so. For now I can ammuse myself assembling the subframe and drivetrain.
ProdigyCustoms
04-22-2005, 02:58 PM
I love it, how about the one in the background?
Roger Poirier
04-22-2005, 08:41 PM
Looks very good so far. What engine are you using? Who's control arms? I also like the car in the back gound. R.P.
Andrew McBride
04-23-2005, 03:51 AM
great looking suspension set-up. I lookforward to seeing more pics.
Trev
04-24-2005, 09:47 AM
Here it is with the TKO600 installed. The engine is a 511 Pontiac IAII block with Edelbrock heads. Front suspension is 84 Corvette on a Wayne Due subframe.
The chassis on the floor behind is an SRIII tube frame for my 64 Corvette (next project) and the red T/A is my driver.
Ralph LoGrasso
04-24-2005, 11:01 AM
Lookin' Good!! Keep us updated. I love bandits!
The Humbler
04-24-2005, 02:15 PM
What kind of headers are those? What kind of horsepower are you looking to make with 511 set up?
Trev
04-24-2005, 06:49 PM
Headers are a modern remake of the HO racing Tri Y set up from the 80s.
Motor should make 525 horsepower with enormous torque!
70ptta
04-25-2005, 09:42 AM
hey trev how do you like the frame so far? how much was it if you dont mind? is it the c4 or c5 front suspension? i have a 70 trans am i am toying with but cant make up my mind on what suspension to use. thanks
Steve Chryssos
04-25-2005, 11:07 AM
Looks great!! You should send a email to Hot Rod. I remember reading not too long ago that "..they are waiting to see if someone builds a "bandit" pro-touring car...." Looks like that someone is you.
Trev
04-26-2005, 03:50 PM
70ptta,
I have to say that I have some issues with the frame. Waynes work is very nice, but I don't think he had done a 2nd Gen Firebird before as he made some substantial mistakes. I hate cutting into such a clean piece, but I have to to make it work. Plus Wayne is over 3000 miles away, so it is not like I can easily send it back! Frame cost me over $3,000. It uses 84 (C4) suspension.
70ptta
05-06-2005, 06:01 PM
hey what were the mistakes wayne made cause i am looking into buying that frame and id like to try and get those fixed before buying it
70ptta
05-27-2005, 07:48 AM
any update on this project
70ptta
06-22-2005, 02:51 PM
what ever happend to this bird
70ptta
10-04-2005, 02:31 PM
whats up trev whats new with your bird
Pzary3233
10-05-2005, 04:22 PM
I'd like to know as well! How is it coming? the 77 and 78 T/As are some one of my favorite body styles of T/As!! 69's being first then the 70-73s
johnm
10-25-2005, 03:34 PM
I have the frame for the 78 T/A too, I am mocking it up now, and am having to make some adjustments to mine as well. So Far, the motor has been too far forward, but not that big of a deal. On mine, the core support doesn't fit. I either have to notch the frame on the front a ton, or cut into the core support/make a new one from tubing. Trev, I would really like to talk to you to find out what problems you are having, and how you fixed them. That would really help me out bunches.
John
Roadrage David
10-26-2005, 10:06 PM
Motor should make 525 horsepower with enormous torque! TREV great to see a poncho bandit pro touring in the making . did you made a typing error , as 525 hp for that set up is way below its potential!!!!! unless you chooce to . do you have any engine specs . the Indian adventure II block together with the MR1 block can handel 6 times that amound of hp . i gues your comp at 9.6 with a mild XE cam ..
BEEBE
10-27-2005, 12:11 PM
DAVID, I was thinking the same thing !
With a set of stock cast iron heads it should make around 520 hp .
With a set of mild ported Elde's or KRE's it would make aroung 650 hp.
Roadrage David
10-27-2005, 01:13 PM
BeeBe i thingk its a 4.25 stroke p dude crate engine made to LAST. insted of going for its full potentional . its build for years of maytiens free running .a whize chooice!!!, as 525 horse with GOBS of Injun torque is plenty on the streets . i myself have a MR1 engine layout for the 69 GTO . witch will be on the wilder side .
79TransAm
10-27-2005, 01:29 PM
I'm doin sorta the same thing but mins is a 79 T/A. I'm not going all out like he is though since i dont have that sorta $$$. I figured with what i wanna do its gonna cost me approx $20k. Which will take me atleast 2-3yrs. I'll probably build the engine, do the interior primer it and drive it on the weekends till i can affoard the money for the suspension & braking system. I'm going with SSBC brakes front and back they will be small enough to fit my stock snowflakes on. The cars gonna be a total sleeper, i plan on NO visual exterior or interior sign of it being modded. But once its on a lift or the hood is popped it will be apparent, or of course when i hit the gas. :)
