View Full Version : Weight Savings From Auto To Manual
toofun
04-22-2005, 04:19 AM
Anyone know what the weight savings if any would be from switching from a th-350 to a m-21? When you factor in all the parts involved between using the two, is there that much of a savings in weight?
Mark
TOOFUN
Hurst – Scott
05-11-2005, 10:53 AM
Muncie typically weigh in the 70+ lbs range. Not sure of weight of the t-350
For the record the new Tremec TKO 5-speeds weigh 110 lbs, extra weight is worth having the 5th gear.
Hope it helps
Scott
www.ClassicChevy5Speed.com (http://www.ClassicChevy5Speed.com)
PH: 760-230-2045
You also have to include the weight of the bellhousing/scattershield, clutch fork and clutch mechanism. Converter and flexplate vs. Clutch and flywheel. Cooler lines vs. cluth pedals etc.
CoryM
05-29-2005, 10:00 AM
look here for a good idea.
http://rcboat.com/Brian's%20stuff/camaro_database.htm My ST10 was 90lbs dry with shifter.
