View Full Version : H4 Relays - Supplier
bigboi
02-13-2010, 08:25 PM
Anybody know where I can order a few relays that are used in the H4 wiring conversion kits? One of my relays is messed up. My low beam went out so I swapped the wires over to the high beam relay and I got low beams again (when high beam was switched on).
I know there is probably a place I can pick up the relays for a few bucks online. Can someone link me to a vendor?
Brian
chevelle327c5
02-14-2010, 06:06 AM
I'm working on this coversion right now and I bought the relays at my work... if i remember right the part # is ru115 (standard).. basic 5 pole relay with a mounting bracket.
bigboi
02-14-2010, 12:55 PM
Yep gotcha... For some reason I couldn't remember the exact name of them last night. Thanks dude... I just ordered a few of them.
Brian
bigboi
02-15-2010, 08:02 PM
One more question... I am pretty sure I know the answer to this but I figure I would ask just to make sure.
I am going to replace both relays in my wiring conversion kit for the H4 lights. I see they offer relays anywhere from 30-70amp. I went ahead and picked up a couple 70amp relays. I am going to assume from the reading I have done you want an amperage that will handle the load needed. If I am going to run 100/80watt H4 lights then I probably want the bigger 70amp relays - is that correct?
Why would you go with a 30amp? I guess for a smaller load application?
Any insight on this topic would be great. Thanks!
Brian
