View Full Version : $2 "vinyl" top
Bjkadron
02-13-2010, 05:49 PM
My Duster Had a vinyl top that was mostly rotted off... So I took it off the rest of the way. But under the top looked bad. So I sanded it down and masked it off... And with 2 $0.98 cans of flat white spray paint I now have a presentable car! Let me know what you think! And I'll post more pictures soon. You can see more of the whole car and my other projects on the thread in my signature.
Before:
https://static1.pt-content.com/images/pt/2010/02/dusterstuff003-1.jpg
Masked up:
https://static1.pt-content.com/images/pt/2010/02/dusterstuff004-1.jpg
Painted:
https://static1.pt-content.com/images/pt/2010/02/dusterstuff006-1.jpg
Done:
https://static1.pt-content.com/images/pt/2010/02/dusterstuff008-1.jpg
Side view:
https://static1.pt-content.com/images/pt/2010/02/dusterstuff009-1.jpg
thetoystore
02-14-2010, 08:40 AM
not bad and i'm sure it looks beter than the vinyl. would be great for a driver that you plan to fix anyways
elitecustombody
02-14-2010, 09:16 AM
should have spent $4.99 a can,
Bjkadron
02-14-2010, 06:40 PM
Yeah... Mainly I didn't want it to rust... and the glue that held the old top on looked horrible! I don't plan to do much to this car... Just the disc swap and stuff so I can drive it everywhere, do fun stuff, and get to school and work. Have to save money for my other project.
Bjkadron
02-14-2010, 06:46 PM
Why? I've had just as good of results with walmarts' cheap paint as I have with the expensive ones. As long as I want a limited selection of colors.
Mr Nick
02-14-2010, 07:42 PM
Looks sharp!
Is that sanding dust, or over-spray on the hood..?
manicmechanic
02-14-2010, 08:17 PM
Looks sharp!
Over-spray. Not to bad an like you said it keeps it from getting to much worse. If you find that that doesn't hold up in the weather you might try Bumper Coater instead, either from Dupli-Color or SEM.
It would more than likely be in black though.
elitecustombody
02-14-2010, 09:28 PM
cause most of the cheap rattle can paint is always watered down,and requires more coats to get the coverage,
terryr
02-14-2010, 10:00 PM
I did the same with a car. They wanted 600 bucks for a vinyl top, so I peeled off the pelt and used a roller to apply white rubber undercoat and some blue rust paint. Looks identical.
Bjkadron
02-15-2010, 10:04 AM
Ahhh! Thanks for the tip! I did notice that it wasn't covering very well. Mostly this was just an experiment. If I wanted it real nice I would have used one of my hvlp sprayguns or one of the Really! nice ones (Iwata, etc.) that I have access to at the shop.
Bjkadron
02-15-2010, 10:07 AM
If it doesn't hold up I'll just do it right with regular paint and a spraygun. This is My "flog-it" car... Drive it everywhere and beat on it like a rental! It doesn't have to look real pretty. That is why I'm building my other one.
Jim Nilsen
02-15-2010, 01:26 PM
You can get textured paint these days that would give you a vinyl type look and you can probably put it right over what you have done after 60 days just in case the paints aren't compatible chemically until it is fully cured.
Looks good and should keep the interior a lot cooler !
Bjkadron
02-15-2010, 05:00 PM
That is just it. I hate vinyl tops! haha. Thanks for the tip though. Might help someone else who is wanting to do something like this.
