View Full Version : Long rear lug nuts
FroopieLoopies
02-12-2010, 08:04 AM
I have a 69 camaro--I'm running 18x8 18x10 boze shifters with the BFG KDW's. The rear lugs are extra long and I am trying to see if there is something I can do to cover them or change how it appears. Any comments will be appreciated!
buickfunnycar.com
02-12-2010, 09:02 AM
I noticed them sticking out in your post yesterday but I'm not certain longer lugnuts would look good with that style wheel.I've tried that look myself and wasn't pleased.
Have you thought about cutting them...?
6'9"Witha69
02-12-2010, 09:05 AM
How long? My rears are 4" long 1/2"x20 with open nuts. I leave them as is. It makes tech inspection easy. If you want to pretty it up, take an open ended nut, back it out to the desired length and use it as a guide to cut it short. Then backing the nut off helps clear the burr. Then you can run closed end nuts.
FroopieLoopies
02-12-2010, 02:10 PM
makes a lot of sense thanks man
