View Full Version : good budget rear disk brake
lt1chevelle
02-09-2010, 05:59 PM
a lot of guys with camaros are running the newer camaro/vette rear brakes(ls brakes as some call them) can this also be done one a 65 chevelle(a body) since most rear ends are about the same? or is there a different braket u need to use?
gearheads78
02-09-2010, 06:00 PM
98-02 LS1 brakes is the way to go
lt1chevelle
02-09-2010, 06:55 PM
So is there a cErtain bracket for a 10bolt so the rear brakes will work on a chevelle
2wd s-10/blazer rear discs work on a-body rears too. Basicly a direct bolton just like LS1 rear disc.
DAVE68
02-09-2010, 09:50 PM
Check out Kore3's website, they will have the bracket you need.
lt1chevelle
02-10-2010, 10:34 AM
Thanks. I knew there was a place that sold the braket just forgot the name. Thanks agin
gearheads78
02-10-2010, 10:53 AM
Unless your are using Corvette stuff you don't need any bracket. A spacer to center the caliper is all you need for the LS1 setup.
lt1chevelle
02-10-2010, 12:01 PM
for the rear brakes? whats the caliper mount to if u dont have the bracket? car has drumbs on it now
ProBell
02-10-2010, 12:45 PM
I have a complete C4 setup for sale. Asking $300. It has brackets for a 9" but Kore 3 will have the ones for a GM rear if you could not modify the ones I have. Not a lot to them. Randy
Randy67
02-10-2010, 01:13 PM
The backing plate for the LS1 brakes has the caliper mount on it, similar to the S10 brakes shown above. The S10 brakes allow 15" wheels to fit while the LS1 brakes usually require a 16" wheel or larger.
silver69camaro
02-10-2010, 02:46 PM
How thick are those caliper mount brackets?
lt1chevelle
02-10-2010, 03:29 PM
Thanks for the info I see how it works now
ProBell
02-11-2010, 03:36 AM
I would guess a 1/4" but will try to measure tonight. Randy
sebtarta
02-11-2010, 04:03 PM
Question, can you use the C6 calipers with the LS1 rear brake? Meaning the C6 calipers with the Ls1 rotors and e-brake shoes.
gort69
02-19-2010, 07:08 AM
You can use the standard C6 caliper on the Ls1 backing plate. Use Ls1 pads and rotors, C6 anti-rattle springs. IIRC, the C6 has a slightly smaller piston diameter.
sebtarta
02-19-2010, 07:31 AM
So it would be better off just buying a used LS1 rear set then.
Thank you, off to find a set.
zbadone
04-06-2010, 03:02 PM
Will a setup from a 96 Trans Am work on a 79 Z-28? It has staggered shocks on it, so would I have to get one different calliper for it?
sebtarta
04-06-2010, 04:40 PM
Yes you will need two left calipers
What you can do is go to a Napa and ask for a left caliper, and swap your right caliper for it. They won't know (usually)
71 chevy
04-08-2010, 10:18 PM
question - will the ls1 rear brakes work with 15" rally wheels?
Chevy Kid
04-09-2010, 01:32 AM
Nope, need at least 16".
Tim
71 chevy
04-09-2010, 09:32 AM
DARN. I already bought them
64Chevelle
04-09-2010, 11:25 AM
I've heard some 15" wheels should work with the "LS1" brakes, but I can't confirm it...
ProBell
04-09-2010, 12:01 PM
The C4 rear brakes I have for sale will fit under a 15" wheel.
John Wright
04-09-2010, 12:05 PM
One advantage with those LS1 vs the C5 brakes....a workable ebrake. You can make the C5 ebrake functional too, but it is much more involved and can be expensive.
zbadone
04-12-2010, 04:22 PM
one more question???? It looks like the 98 Trans Am rear discs have an internal drum brake as a parking brake. Is this possible to use on my 79 Z with staggered shocks or would I be better off with 96 Trans Am discs with the caliper parking brake?
Cannon
04-12-2010, 04:45 PM
in order to use 15" wheels with those LS1 brakes, you need to grind down the fins on the caliper, go to LS1tech.com and search for grind caliper or something and you should see a write up on it.
MonzaRacer
04-14-2010, 10:47 AM
Just adapt on the 98-up S/T Blazer/S10 rear brakes, they work great and also clear 15 in wheels and do everything you will need and you can get them either way on front or rear of axle.
I am going to run them on my 84 Caprice with the 355mm Corvette front brakes and on my 77 Monza with either the 325mm or 340mm fronts. Fronts on both will be with Kore 3 brackets. Rears are nearly bolt on (actually if I can find good 4x4 Blazer rearend I hope to get all of it for cheap/free for 77 Monza).
Skip Fix
04-18-2010, 12:25 PM
So how different are the Blazer calipers than the Vette rear calipers?
19,69camaro
04-19-2010, 02:06 PM
So it sounds like the ls1 camaro brakes are the way to go. Im still in between either putting a 8.5" 10 bolt or a 12 bolt in.
Which one would be easier to mount to brakes to?
Is there a difference between BOP and chevy rears?
Are the bolt holes for the backing plates the same on either housing?
And as stated above do you even need a bracket to make the ls1 brakes work?
I looked into the KORE3 website but they say that the parking brake will not work with their corvette Big Brake bracket kit.
Sorry for all the question but there is a lot of conflicting information out there and its hard to tell what is bs or not
04-19-2010, 06:28 PM
Some BOP rears have non c-clip axles so the bearing comes out withthe axles. Year specific.
Housing ends are the same but you will need a 1/4" spacer behind the backing to center the caliper on the rotor.
vince
19,69camaro
04-19-2010, 07:40 PM
Awesome thanks for the help.
