View Full Version : Low pressure tire monitor
SSChevelle
02-09-2010, 10:59 AM
Is anyone running a TPMS on their car? Im considering running one but cant find any good kits.
Vegas69
02-09-2010, 11:09 AM
Why in the world would you want that on you car?
jy211
02-09-2010, 11:13 AM
x2?
SSChevelle
02-09-2010, 11:17 AM
After almost wrecking a car at over 100, with low profile tires because a nail punctured a front tire. Id like to know if they go low on pressure.
James OLC
02-09-2010, 11:27 AM
I guess the counter to that would be Why wouldn't you want that on your car? There is really no down side to using a wireless TPMS that I can see. I actually have one for the OLC but couldn't use the sensors with the HREs. We're going to try to make them work with the new wheels.
jy211
02-09-2010, 11:45 AM
That's good reason! :idea:
ProBell
02-09-2010, 12:29 PM
I will get the info off the one I run on my slicks. It tells you the air presser as well as tire temp. A good tool at the track. Randy
Vegas69
02-09-2010, 12:38 PM
It depends on the system. I've owned 3 cars that utilized it. 1 of 3 was overly sensitive and drove me out of my mind. I can definitley see the benefit of monitoring tire pressures on the race track. My C5 corvette had a decent setup that read it by 1 psi increments. My BMW's are either low tire or flat tire. Is that something you can work into the Racepack?
SSChevelle
02-09-2010, 01:04 PM
Thanks Pro. Im not real keen on the TPMS, but im running 35 series tires and would like at least aheads up if a tire is starting to go flat.
monza
02-09-2010, 01:14 PM
Off subject.... NEW WHEELS? Did I miss that somewhere?? when where what?
James OLC
02-09-2010, 02:50 PM
The cheapo aftermarket version I have reads in 1 psi increments and is self contained. Before I put those to work I'm going to talk to Racepak to see if they have done anything - my guess is no. To work with the IQ3 they would need use 4 sensors from a common hub (which is no big deal) but they would have to translate the data from the "OEM" packaging into CANBUS data format which is where I think it will fall apart. I wish it would work though.
:smoke:
Some changes are coming... some announcements are coming... but to answer your question: soon, here, and can't say...
TEXAS PAUL
02-09-2010, 04:42 PM
see below
TEXAS PAUL
02-09-2010, 04:53 PM
I just put a set of Orange TPMS brand set of p409s on my 18x9 aftermarket wheels, I have had no problems. I decided on this brand when I went to SEMA and talked to the makers. The cheapest price I found was on AMAZON for $120 for a set of 4. Discount tire charged me $15 a tire for mounting and balance. The main reason I got them was because the valve stem is in the inside of the wheel and they are a b***h to get to and check the pressure.
https://static1.pt-content.com/images/pt/2010/02/IMG_0157-1.jpg
https://static1.pt-content.com/images/pt/2010/02/IMG_0159-1.jpg
https://static1.pt-content.com/images/pt/2010/02/IMG_0160-1.jpg
Nine Ball
02-10-2010, 07:20 PM
I'm a dealer for Orange Electronics, if you are interested in that system shown above. Contact me and I'll get you a price.
Tony
FroopieLoopies
02-11-2010, 08:17 AM
I guess I dont drive mine enough to need those; however, it would be pretty cool!
Jim Nilsen
02-11-2010, 08:48 AM
So if someone steals your wheels ,will you know where they are?
ProBell
02-11-2010, 06:13 PM
Tony
I am running the Orange Electronics sensors in my slicks. They work well. Can I run multiple sensors in a few sets of wheels? For example 2nd set of slicks or street tires.
What would a 2nd set of sensors cost?
Thanks Randy
Nine Ball
02-12-2010, 07:04 AM
Randy, Orange came out with a new TPMS programmer unit recently. It allows you to program each sensor with a previous one's code. That might allow you to program as many sensors as you want to mimic eachother.
Another idea is to get a Bartec or any other TPMS reprogramming unit. Then each time you install a new set of wheels you just go through the typical OEM reset procedure. Those vary in price, usually between $100-300.
http://www.bartecusa.com/wheelrite_tech300.htm
As for sensors, they vary in price depending on the part number required. Anywhere from $25 to $60 each, it seems.
Tony
