View Full Version : BBC and Edelbrock Quadrajet carb
Gregster
02-08-2010, 10:47 AM
I have a Edelbrock Quadrajet carb that a friend gave thats brand new, it is a 1904 model 795 cfm. Does anyone know anything about these and do I need to tune it or just run it as is? I have a Pat Musi 402 BBC 480 hp 480 torque., in a 69 Camaro 5 speed TKO 600 12 bolt 3.73 rear.
-Greg-
Jim Nilsen
02-08-2010, 05:09 PM
-Greg-
call Edelbrock to be sure, they have a great tech line and if it is not correct you can send it to them with the return authorization number they will give you and it will get turned around pretty fast unless things have changed in the last 10 years.
Shaker455
02-14-2010, 10:39 AM
Greg,
Can you post a pick as the number you posted look to be an Edelbrock copy of a Carter and the Edelbrock Qjet is completely different.
If it is in fact the Qjet then they have out of production with Edelbrock for awhile and usally from the ones I've worked on need quite a few mods to work properly.
Jeff
Gregster
02-14-2010, 11:28 AM
Hi Jeff, Attached are some pics and it is a 1904 Edelbrock as you can see on the plate on the side, if you have any info I would really appreciate it.
-Greg-
https://static1.pt-content.com/images/pt/2010/02/okmq0p-1.jpg
https://static1.pt-content.com/images/pt/2010/02/v49uhl-1.jpg
Jim Nilsen
02-14-2010, 05:39 PM
I forgot to add that Edelbrock will flow bench the carb and have it tuned as close as you can get it out of a box.
Have you called them yet!
Shaker455
02-14-2010, 11:11 PM
Greg,
Good pics.
Have you taken it apart to see what size jets & rods are in it?
I have specs on the the 1910 performer RPM model
Also, what have you done to tune it to your combo?
Jeff
Gregster
02-15-2010, 09:14 AM
Actually nothing other than put it on. I haven't driven it yet because I am pulling the trans back out to put a different clutch fork in.
Shaker455
02-15-2010, 09:50 AM
I see,
God idea to break it down and see what size jets & rods are in there....keep us posted!
67 455 Bird ragtop
03-03-2010, 11:46 AM
If it hasn't been changed from the factory you should find it had .050 rods and .073 jets.
Gregster
03-04-2010, 08:41 AM
Is this a good start or do you think it needs to be changed. Or how can I tell if it needs to be?
Shaker455
03-05-2010, 03:14 PM
Edelbrock did not stick with one calabration on those units so it's best to break it down and measure every aspect.
At the time they had quality issues and those carb didn't sell so in the end they dropped them.
